May 15, 2011, 17:49 |
of15dev
#21 |
khaled
Rep Power: 16 |
Thank you Bruno, I recive this message in the terminal window
khaled@khaled-laptop:~$ of15dev bash: /opt/OpenFOAM-1.5-dev/bin/foamCleanPath: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/bin/foamCleanPath: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/bin/foamCleanPath: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/etc/settings.sh: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/etc/aliases.sh: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/etc/apps/ensightFoam/bashrc: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/bin/foamCleanPath: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/bin/foamCleanPath: Aucun fichier ou dossier de ce type bash: /opt/OpenFOAM-1.5-dev/bin/foamCleanPath: Aucun fichier ou dossier de ce type khaled@khaled-laptop:~$ |
May 20, 2011, 15:59 |
Isolate and conquer a rogue OpenFOAM environment :)
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Khaled,
Sorry for taking so long to answer you, but this week has been hectic for me... I don't know if you've already managed to fix this issue, but here's what I suggest you do:
Then uncomment the lines you've commented, while testing any suspicious commands in the mean time... in other words, go back some of the changes you've made, while keeping an eye out for suspicious lines! And don't forget that one shouldn't try to change the OpenFOAM environment to a different version on the same terminal that one is working on, unless one knows what one is doing! Or in other words: minimum of 1 terminal window/tab per OpenFOAM version! Best regards and good luck! Bruno
May 21, 2011, 09:24 |
thank very much
#23 |
khaled
Rep Power: 16 |
Thank you bruno so much for this help. It's been a month since I'm stuck in this step. I find the suspect sentence . /opt/openfoam171/etc/bashrc in /etc/bash.bashrc file. After Commenting it and verifing that I do not recive in the terminal window /opt/openfoam171 when I run the command echo $WM_PROJECT_DIR, I added three aliases in bashrc file. It seem now that the three versions of OpenFOAM (1.7.1/1.5-dev/1.6-ext) works.
thank you again for this valuable assistance |
July 20, 2011, 08:41 |
OF-1.6-ext
#24 |
Santiago
Rep Power: 16 |
Wyldckat you seem to be my only hope right now!
I have read countless forums and instructions trying to install OF-1.6-ext and I still cannot get it to work after 3 weeks of painful work. I have Ubuntu 10.10 installed and OpenFOAM 1.6 is working fine. However I need OF-1.6-ext in order to use iciFsiFoam. I want to install it along side OF-1.6. I followed the procedure using the Synaptic Manager. When I run foamInstallationTest I get the following error: Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.4.5 Minimum required: 4.3.1 gcc 4.4.5 WARNING: Conflicting installations: OpenFOAM settings : /home/santiago/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.23 /bin/tar icoFoam /usr/lib/OpenFOAM-1.6-ext/applications/bin/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). This happens when my bashrc looks like this: alias startOF16ext='source /usr/lib/OpenFOAM-1.6-ext/etc/bashrc' . $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc I also tried changing : ${WM_COMPILER:=Gcc43}; export WM_COMPILER at OpenFoam-1.6-ext/bashrc and hit ./Allwmake but I can never get this thing to compile without errors: the errors are something like this one: /usr/bin/ld: cannot find -lreactionThermophysicalModels /usr/bin/ld: cannot find -lbasicThermophysicalModels collect2: ld returned 1 exit status make[2]: *** [/home/santiago/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linuxGccDPOpt/chemkinToFoam] Error 1 make[1]: *** [chemkinToFoam] Error 2 I would greatly appreciate any help. Thanks |
July 20, 2011, 09:12 |
#25 | |
Bruno Santos
Rep Power: 128 |
Hi Santiago,
OK, you've got this: Quote:
alias startOF16ext='source /usr/lib/OpenFOAM-1.6-ext/etc/bashrc' alias startOF16='. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc' Now, whenever you start a new terminal, run either startOF16ext or startOF16, depending on the version you want. If you then want the other version, start it on another terminal! This way you won't have these problems with one environment contaminating the other one. Last but not least, the 1.6-ext version you installed doesn't need further modifications. It should work right after you install it via Synaptic. If you modified it, then go to Synaptic, right click on the 1.6-ext packages and pick "re-install". Additionally, you should also install the openfoam-1.6-ext-dev package, since it gives you the development files for building other solvers! Good luck! Bruno
July 20, 2011, 21:18 |
#26 |
Santiago
Rep Power: 16 |
Thanks so much for answering this post. I changed the bashrc file as you said. I also re-installed all three packages: openfoam-1.6-ext, openfoam-1.6-ext-dev and openfoam-1.6-ext-doc using Synaptic. The installation shows no error.
When I run foamInstallationTest for OF-1.6 everything is cool, but when I switch using StartOF-1.6-ext (in a brand new terminal) I get this message: Executing /usr/lib/OpenFOAM-1.6-ext/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- FATAL ERROR: OpenFOAM environment not configured. Please refer to the installation section of the README file: <OpenFOAM installation dir>/OpenFOAM-1.6-ext/README to source the OpenFOAM environment. What should I do now? I really appreciate your help man. |
July 21, 2011, 05:06 |
#27 | |||
Bruno Santos
Rep Power: 128 |
Hi Santiago,
I'm starting to hate foamInstallationTest... OK, maybe not hate, simply maybe disdain... I'm going to quote myself once again Quote:
Bruno
July 21, 2011, 07:41 |
#28 |
Santiago
Rep Power: 16 |
YOU ARE THE MAN! You are right! I tested the cavity case and it works no problem! I can't tell you how much I appreciate your help! Have a great day!
July 21, 2011, 08:04 |
#29 |
Santiago
Rep Power: 16 |
Oops, there is one problem that I just noticed. When I use OF-1.6-ext everything is fine. When I switch to OF-1.6 in a new terminal and I execute paraFoam, I get this error:
/home/santiago/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linuxGcc/bin/paraview-real: error while loading shared libraries: libQtAssistantClient.so.4: cannot open shared object file: No such file or directory Any idea of what to do? |
July 21, 2011, 17:03 |
#30 |
Bruno Santos
Rep Power: 128 |
Hi Santiago,
If you can install OpenFOAM 2.0 for Ubuntu, here's what you can do: http://www.cfd-online.com/Forums/ope...tml#post314692 post #23. Well, in that post I explain how to make 1.5-dev and 1.6-ext use OF-2.0 version of ParaView. You simply have to adapt for your OF-1.6! Best regards, Bruno
July 26, 2011, 14:20 |
#31 |
Santiago
Rep Power: 16 |
Hi again Wyldckat.
Thanks so much for your help so far. The main reason why I need OF-1.6-ext is to be able to use icoFsiFoam. However, when I try to use the solver as it comes (by installing it form the Synaptic Package manger) it does not work. When I try to run icoFsiFoam i get this error: http://www.cfd-online.com/Forums/ope...tml#post317273 I checked and the files that are listed to be missing are actually present. http://www.cfd-online.com/Forums/ope...tml#post317474 As I mentioned to you in another post, I also tried to compile icoFsiFoam and I get the following: http://www.cfd-online.com/Forums/ope...tml#post317475 Again, when I checked for the missing files (tetMatrices stuff) they are present in OpenFOAM-1.6-ext/SRC/tetDecompositionFiniteElement/tetFemMatrix. I'm starting to think that the compiler is not looking into the right place (I have OF-1.6 and OF-1.5-dev installed in my system as well). Do you have any idea or suggestion on how to proceed? Thanks in advance |
July 26, 2011, 19:41 |
#32 |
Bruno Santos
Rep Power: 128 |
Hi Santiago,
3 threads to choose from... I'll simply reply here what I did to get it working:
Best regards, Bruno
July 27, 2011, 10:23 |
#33 |
Santiago
Rep Power: 16 |
Thanks man, you saved me again! It worked. For some reason the RunFunctions are not found at $WM_PROJECT_DIR/bin/tools/RunFunctions, so I did what you proposed. I did have to modify the Allrun file as indicated here http://www.cfd-online.com/Forums/ope...tml#post309684 though.
Thanks again |
July 27, 2011, 10:39 |
#34 | |
Bruno Santos
Rep Power: 128 |
You're welcome! And I'm glad I didn't have to build 1.6-ext either, because by what I've seen on the forum, it's a doozy to build the 3rd Party folder
July 28, 2011, 08:37 |
#35 |
Santiago
Rep Power: 16 |
Hi again Wyldckat
I think I'm starting to understand what the problem really is: As of now, I have OF-1.6-ext installed using the Synaptic Manager into the usr/lib folder. Now, I also downloaded the binary files and those are at $HOME/OpenFOAM/OpenFOAM-1.6-ext. I need to be able to compile some of the solvers since I need to modify them. For that I guess i need to use the binary files and therefore I need to compile OF-1.6-ext binaries. I'm trying to source the bashrc by using alias startOF16='. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc' alias startOF16ext ='. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc however that does not work since I get : bash: alias: startOF16ext: not found bash: alias: =. $HOME/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc: not found What should I include in to .bashrc? any idea of what to do? PD: it seems that some of the folders required to compile some of the solvers are missing in the OF-1.6-ext version that I installed using Synaptic |
July 28, 2011, 09:56 |
#36 | ||
Bruno Santos
Rep Power: 128 |
Hi Santiago,
When using Linux and OpenFOAM, one must pay very close attention to details! One wrong character somewhere and puff... Anyway, if you installed both packages for OF 1.6-ext, namely openfoam-1.6-ext and openfoam-1.6-ext-dev, then you shouldn't need to build your own version of 1.6-ext. Nonetheless, if you do need the latest version of 1.6-ext then yes, you will need to build it yourself! The following tutorial teaches (among other things) on how to create the solver for personal use, without the need to put it in the same folders as OpenFOAM's core code: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam The key details are:
Best regards, Bruno
Last edited by wyldckat; July 28, 2011 at 09:58. Reason: there was an extra space before the equal sign |
July 29, 2011, 23:16 |
#37 |
Santiago
Rep Power: 16 |
Thanks again Bruno, as usual very thorough and clear.
I followed your direction regarding the creation of my_icoFoam and I it works no problem. Now, I'm trying to compile a solver that can be downloaded here http://www.cfd-online.com/Forums/ope...tml#post315130 When I run "wmake all" I get the following error: santiago@santiago-laptop:~/OpenFOAM/santiago-1.6-ext/applications/solvers/testVorflexFoam$ wmake all SOURCE=testVorflexFoam.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/usr/lib/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicFvMesh/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/turbulenceModel -I/usr/lib/OpenFOAM-1.6-ext/src/transportModels -I/usr/lib/OpenFOAM-1.6-ext/src/transportModels/incompressible/singlePhaseTransportModel -I/usr/lib/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -DFACE_DECOMP -I/usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/dynamicMesh/meshMotion/tetDecompositionMotionSolver/lnInclude -IlnInclude -I. -I/usr/lib/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/usr/lib/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/testVorflexFoam.o testVorflexFoam.C:41: fatal error: tetFemMatrices.H: No such file or directory compilation terminated. make: *** [Make/linuxGccDPOpt/testVorflexFoam.o] Error 1 Now, I was told here http://www.cfd-online.com/Forums/ope...tml#post317808 that the symbolic link to tetFemMatrices.H is missing. That is exactly the case. The whole lnInclude folder is missing in usr/lib/OpenFOAM-1.6-ext/src/tetDecompositionFiniteElement. I tried creating those links but when I try doing that I get "broken" links since I am "not the owner of the files and cannot change the permissions". In reality I am the owner of the system and I use my password every time I use "sudo" Any suggestions or ideas of what to do? Thanks again man, I really appreciate your help |
July 30, 2011, 08:36 |
#38 |
Bruno Santos
Rep Power: 128 |
Hi Santiago,
I didn't know that 1.6-ext had so many rough edges.. OK, download the attached file and gunzip it. In my case, I put both packages on my user-1.6-ext folder and unpacked them both: Code:
tar -xzf solverAndTestCaseFSI.tar.gz gunzip SolverAndTestCaseFsi.patch.gz Then applied the patch and built the thing: Code:
cd solverAndTestCaseFSI/testVorflexFoam/ patch -p1 < ../../SolverAndTestCaseFsi.patch chmod +x Allwmake wmake all Now all it's left is to apply the previous instructions to the testCase... Have fun! Bruno
August 1, 2011, 14:08 |
#39 |
Santiago
Rep Power: 16 |
Thanks Bruno.
I already solved the problem by modifying the "files" file in the Make folder. I added the path to each of the "missing" symbolic link to the actual file location. I did this manually for each file. It took a little bit of time but eventually it worked. So I was able to successfully compile the solver. Thanks again |
October 7, 2011, 12:05 |
#40 |
Mark Beal
Rep Power: 15 |
Hi Guys,
I've been using OpenFoam for a few months now and thought I'd like to change to the git version (more up to date) and install the extended version (more functionality). I'm using Ubuntu 11.04. I successfully installed OF-2.0.x using the git distribution and hoped that the extended version would be along similar lines. I had problem after problem and eventually gave up and went for the cae-team package instead. That's just install and I assume it'll work fine. My problem is: The cae-team package looks quite out of date. I might be wrong but maybe 10 months or so old, so my questions are: 1) Are there any clearer instructions on how to install OF-1.6-ext on Ubuntu 11.04 using the git distribution. The OF-2.0.x instructions were quite clear and worked. I'm struggling with the third-party part of OF-1.6-ext as it's got lots of rpm related scripts that keep failing (even though rpm is stalled) 2) If I install the cae-team version, can I update it using git and recompile the updated parts, or do I have to wait for someone else to update it. Thanks in advance, EDIT: I just came across this thread and the link to the tutorial for Ubuntu 11.04. I've not tried it yet but it might at least answer my first point. Apologies for not seeing this earlier. Mark |
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 | electrosin | OpenFOAM Installation | 40 | May 31, 2016 06:11 |
Error in apt-get update for installation of OpenFoam 1.7.1 on Ubuntu 10.10 | StuntedChicken | OpenFOAM Installation | 1 | January 9, 2011 11:43 |
paraview does not work on ubuntu 10.10 maverick | sebonator | OpenFOAM | 2 | December 18, 2010 11:33 |
Installing OpenFOAM 1.6 on Ubuntu 10.4 | sda | OpenFOAM Installation | 5 | May 27, 2010 21:19 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
