Are OSIG TurboMachinery libraries able to work under OpenFOAM-1.6-ext? |
March 2, 2011, 04:25 |
#21 |
Niels Nielsen
Rep Power: 27 |
1.6 ext versions of transientSimpleDyMFoam and turboPerformance library.
Linnemann PS. I do not do personal support, so please post in the forums. Last edited by linnemann; March 3, 2011 at 06:32. |
August 30, 2012, 06:05 |
#22 |
Rep Power: 14 |
Hi there,
Quick question really - is turboPerformance something that will work with OpenFoam 2.1.x? Any info would be great. Cheers |
August 30, 2012, 06:30 |
#23 |
Håkan Nilsson
Rep Power: 18 |
turboPerformance has been merged with 2.0.x, and I guess that it should be possible to use that merge also with 2.1.x, or at least with minor modifications. I didn't test though.
See: http://openfoam-extend.svn.sourcefor...boPerformance/ Håkan |
August 30, 2012, 07:02 |
#24 |
Rep Power: 14 |
Just downloaded and compiled this version in 2.1.x - works brilliantly! Exactly what I'm looking for and makes things neater.
Many thanks for the link. |
May 9, 2013, 20:54 |
#25 |
任芸
Rep Power: 17 |
Because the website posted by Hani cannot be linked now. If you upload the turboPerformance on version-2.1.0 to share, I will appreciate it ! Thanks, Yun Ren |
May 17, 2014, 02:25 |
turboPerformance for openfoam 2.3.0
#26 |
Mohammed Ameenuddin
Rep Power: 12 |
Hello everyone,
I am trying to use Sig turbomachinery library turbo performance for OpenFOAM 2.3.0, but when I compile the libraries of 2.0 as given in link below I get many errors. Are there any such libraries that I can use for OpenFOAM 2.3.0. http://openfoamwiki.net/index.php/Sig_Turbomachinery_Library_turboPerformance#Downlo ad_and_compile The errors are Code:
SOURCE=forces/forces.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam230/src/finiteVolume/lnInclude -I/opt/openfoam230/src/meshTools/lnInclude -I/opt/openfoam230/src/sampling/lnInclude -I/opt/openfoam230/src/transportModels -I/opt/openfoam230/src/turbulenceModels -I/opt/openfoam230/src/turbulenceModels/LES/LESdeltas/lnInclude -I/opt/openfoam230/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/opt/openfoam230/src/OpenFOAM/lnInclude -I/opt/openfoam230/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/forces.o forces/forces.C: In member function ‘Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::forces::devRhoReff() const’: forces/forces.C:77:28: error: ‘const class Foam::incompressible::LESModel’ has no member named ‘devBeff’ forces/forces.C:86:24: error: ‘const class Foam::basicThermo’ has no member named ‘mu’ In file included from /opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistry.H:242:0, from /opt/openfoam230/src/OpenFOAM/lnInclude/Time.H:42, from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.C:27, from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricField.H:601, from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /opt/openfoam230/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /opt/openfoam230/src/finiteVolume/lnInclude/volFields.H:37, from forces/forces.C:28: /opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistryTemplates.C: In member function ‘const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::singlePhaseTransportModel]’: forces/forces.C:95:35: instantiated from here /opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:178:9: error: reference to ‘Foam::singlePhaseTransportModel::typeName’ is ambiguous /opt/openfoam230/src/transportModels/incompressible/transportModel/transportModel.H:66:5: error: candidates are: const Foam::word Foam::transportModel::typeName /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:72:5: error: const Foam::word Foam::IOdictionary::typeName forces/forces.C:95:35: instantiated from here /opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:195:9: error: reference to ‘Foam::singlePhaseTransportModel::typeName’ is ambiguous /opt/openfoam230/src/transportModels/incompressible/transportModel/transportModel.H:66:5: error: candidates are: const Foam::word Foam::transportModel::typeName /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:72:5: error: const Foam::word Foam::IOdictionary::typeName /opt/openfoam230/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:195:9: error: reference to ‘Foam::singlePhaseTransportModel::typeName’ is ambiguous /opt/openfoam230/src/transportModels/incompressible/transportModel/transportModel.H:66:5: error: candidates are: const Foam::word Foam::transportModel::typeName /opt/openfoam230/src/OpenFOAM/lnInclude/IOdictionary.H:72:5: error: const Foam::word Foam::IOdictionary::typeName forces/forces.C: In member function ‘Foam::tmp<Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::forces::devRhoReff() const’: forces/forces.C:120:1: warning: control reaches end of non-void function [-Wreturn-type] make: *** [Make/linux64GccDPOpt/forces.o] Error 1 |
June 8, 2014, 15:22 |
#27 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
I've given this a try and have adapted the "turboPerformance" library to OpenFOAM 2.1.x, 2.2.x and 2.3.x, based on the source code meant for OpenFOAM 2.0.x. It is now available here: https://github.com/wyldckat/OSIG-Tur...formance-OF2.x - I've also added a link for this repository at the wiki page, in the new section "Forks": http://openfoamwiki.net/index.php/Si...formance#Forks I have only taken care of making the necessary changes to the library source code, for it to build with each OpenFOAM version. I have not tested if it's working as intended on all versions. Therefore, if anyone has the time and resources, please test this first with OpenFOAM 2.0.x and then with the version of OpenFOAM you need to use, in order to confirm if everything is working as intended! Best regards, Bruno
1.5-dev, 1.6-ext, osig, turbomachinery |
kOmegaSST in openfoam 1.6 | Gearb0x | OpenFOAM | 2 | March 3, 2010 06:02 |
Openfoam 1.6 | ar_mofidi | OpenFOAM | 1 | November 4, 2009 05:26 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
Turbomachinery at OpenFOAM Workshop Milan 2008 | hani | OpenFOAM | 0 | March 21, 2008 02:33 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
