[foam-extend.org] Error compiling OpenFOAM-1.6-ext
Like Tree6Likes
Old   June 22, 2011, 10:48
Martin Beaudoin
mbeaudoin will become famous soon enough
I took a look at your compilation log files, and you have a bunch of errors you need to solve, one by one, first one first, and not only the last error you are reporting.
Some comments:
- You are probably missing some -dev packages for OpenGL. Try compiling Paraview as a stand-alone package using the instructions provided by Kitware. It might help pinpointing the missing packages.
- Some of your compiler settings seems to be off. Your installation of 1.7.1 is probably conflicting.
From your log file:
/home/tibornyers/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/libccmio-2.6.1/libadf/..//config/linux_2.4-x86-glibc_2.3.2/qmake: error while loadi
ng shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
- You are having problems downloading packages from the Internet
From your log:
Download mesquite-2.1.2.tar.gz from : http://software.sandia.gov/~jakraft/mesquite-2.1.2.tar.gz
--2011-06-17 09:30:39-- http://software.sandia.gov/~jakraft/mesquite-2.1.2.tar.gz
Resolving software.sandia.gov... failed: Name or service not known.
wget: unable to resolve host address `software.sandia.gov'
So basically, instead of focusing on the last error message you've got, open your log file with a text editor, and go hunting for the string "error". Solve the problem you find one by one, first problem first.
Martin
Originally Posted by Toorop View Post
Some progress, finally!
With the instructions you suggested - QT_BIN_DIR and the soft linking between make and gmake - I was able to compile the ThirdParty package except for paraview. I have the same error now as post #96.
I have update the scripts as well cuz some urls in the AllMake scripts of the ThirdParty are out of date, maybe it helped as well, I'm not sure.
If I compile the 1.6ext with the current state, I get some solvers, which is great. I also receive some errors and the compilation stops at some point.
Thank you all for the great help!
mbeaudoin is offline   Reply With Quote
Old   June 22, 2011, 10:51
Eysteinn Helgason
eysteinn is on a distinguished road
Originally Posted by ubald View Post
Sadly I Stage3 as problem downloading:
Updating the ThirdParty environment variables before building package metis-5.0pre2
Download metis-5.0pre2.tar.gz from : http://glaros.dtc.umn.edu/gkhome/fet...5.0pre2.tar.gz
--2011-06-15 10:33:05-- http://glaros.dtc.umn.edu/gkhome/fet...5.0pre2.tar.gz
Résolution de glaros.dtc.umn.edu... 160.94.77.162
Connexion vers glaros.dtc.umn.edu|160.94.77.162|:80...connecté.
requęte HTTP transmise, en attente de la réponse...404 Not Found
2011-06-15 10:33:05 ERREUR 404: Not Found.
I ad to download it from an other source:
ftp://ftp.uni-frankfurt.de/pub/Mirrors2/gentoo.org/distfiles/metis-5.0pre2.tar.gz
The location of metis-5.0pre2 seems to have change.
It can be fixed by editing ThirdParty/AllMake.stage3
line 62 and change the url from
to
That is adding the OLD/
Btw I also had to do :sudo ln -s /usr/bin/make /usr/bin/gmake
Then running AllMake and sourcing again and trying to compile OF16ext and sourcing once more and then compiling again and it worked.
Running Ubuntu 11.04
/Eysteinn
eysteinn is offline   Reply With Quote
Old   June 22, 2011, 11:06
Martin Beaudoin
Yup, that tutorial seems to be in problem.
You can get a pretty good overview of the list of tutorials currently in problem here:
http://openfoam-extend.sourceforge.n...enFOAM-1.6-ext
Of course, depending on your system, even on your compiler, your mileage may vary.
I invite you to run the test harness on your machine, and to post the results on the openfoam-extend CDash service.
Just take a look here for a starter on the test harness: OpenFOAM-1.6-ext/testHarness/README.txt
Martin
But the tutorial test tutorials/incompressible/icoDyMFoam/turboPassageRotating
dos not seam to work properly did any bothy had this problem ??
(I modify it to run on 2 processor change decomposePar and Allrun -> runParallel icoDyMFoam 2)
Maybe, there is something I did rung in decomposing in t processor ??!!
the other work correctly : mixer2D movingBlockRBF movingConeTopo mixerGgi
Regards
Old   June 23, 2011, 07:37
Tibor Nyers
Toorop is on a distinguished road
Hi Martin,
Thanks for taking the time to have a look at my logs.
I have resolved the errors on the first 4 of the ThirdParty AllMake stages (0-3). So there's no package downloading woe any more as I said @ 120. The ParaView compiling fails like jajcevic reported some pages before.
Linking CXX executable ../../../../bin/GenericFilteringCxxTests
../../../../bin/libvtkRendering.so.pv3.8: undefined reference to `vtkOSOpenGLRenderWindow::New()'
collect2: ld returned 1 exit status
make[2]: *** [bin/GenericFilteringCxxTests] Error 1
make[1]: *** [VTK/GenericFiltering/Testing/Cxx/CMakeFiles/GenericFilteringCxxTests.dir/all] Error 2
[ 45%] Built target vtkVolumeRendering
make: *** [all] Error 2
error: Bad exit status from $HOME/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.eJh8MM (%build)
What modifications do the paraFoam script needs so one could use the pre-built ParaView 3.10.1?
Thanks!
Toorop is offline   Reply With Quote
Old   June 30, 2011, 11:49
flowris is on a distinguished road
Dear forum,
I am trying to compile OF-1.6-ext. My ThirdParty is done, but I get linking errors while building src:
+ wmake libso meshTools
make: *** No rule to make target `lnInclude/pointIndexHit.H', needed by `directMapped/directMappedPolyPatch/directMappedWallPolyPatch.dep'.  Stop.
I already tried to remove src/OpenFOAM/lnInclude, but the same error comes back.
What can I do to make correct links?
flowris is offline   Reply With Quote
Old   July 1, 2011, 06:57
Antonio Liggieri
alfa_8C is an unknown quantity at this point
Hello Foamers,
I found a compact, and thus very helpful procedure for compiling OpenFOAM-1.6-ext on OpenSuse 11.4 64bit.
http://www.cfd-online.com/Forums/ope...1-4-64bit.html
I proceeded all the steps and it went well until step 16. But as soon as I execute the global Allwmake script in the $WM_PROJECT_DIR I got a lot errors. All the OpenFOAM files/libraries which are needed for compilation are not found. The error is for all libs the same as the following:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/LES/LESModel -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/yPlusLES.o -L/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lincompressibleLESModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/lga19/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/yPlusLES
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: cannot find -lincompressibleLESModels
make[3]: *** [/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/yPlusLES] Error 1
make[2]: *** [yPlusLES] Error 2
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/yPlusRAS.o -L/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
-lincompressibleTransportModels -lincompressibleRASModels -lbasicThermophysicalModels -lspecie -lcompressibleRASModels -lfiniteVolume -lmeshTools -lsampling -lOpenFOAM -liberty -ldl -lm -o /home/lga19/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/yPlusRAS
/usr/lib64/gcc/x86_64-suse-linux/4.5/../../../../x86_64-suse-linux/bin/ld: cannot find -lincompressibleTransportModels
make[3]: *** [/home/lga19/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/yPlusRAS] Error 1
make[2]: *** [yPlusRAS] Error 2
make[2]: Target `application' not remade because of errors.
make[1]: *** [wall] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [postProcessing] Error 2
make: Target `application' not remade because of errors.
This must be some very "global" error. Has anybody an idea?
Thank you in advance for any hint,
Toni
alfa_8C is offline   Reply With Quote
Old   July 4, 2011, 06:17
When I update my version with git pull, I sometimes have incorrect symbolic links. My "agricultural" solution is to delete the .dep file and lnInclude folder in question, and then recompiling works (wmake make the delete files again correctly). This is a nasty job, because I have to watch the printout of the compilation, interrupt it when an error occurs and then find the files.
Another solution is to delete ALL of the .dep files an lnInclude folders, and the compile everything again.
Is there a more intelligent way to deal with this?
Old   July 4, 2011, 08:02
Raimonds Vilums
argonaut is on a distinguished road
Originally Posted by boger View Post
When installing from an rpm (specifically for openmpi, although I suspect the same will be true for any rpm), I get this error:
error: can't create transaction lock on /var/lock/rpm/transaction
As a summary for the problem discussed in the posts #74-#79, I solved this by creating a file "~/.rpmmacros" with text
%_rpmlock_path	%{_dbpath}/__db.000
argonaut is offline   Reply With Quote
Old   July 7, 2011, 05:16
I finished building the ThirdParty and src, but when I run applications/Allwmake, I get errors for libmesquite:
+ wmake all solvers
make[2]: `/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/PODSolver' is up to date.
make[2]: `/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/dnsFoam' is up to date.
make[2]: `/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/potentialFoam' is up to date.
make[2]: `/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/laplacianFoam' is up to date.
make[2]: `/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/sixDOFSolver' is up to date.
make[2]: `/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/scalarTransportFoam' is up to date.
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/engine/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/specie/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/reactionThermo/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/compressible/turbulenceModel -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/laminarFlameSpeed/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/sampling/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64GccDPOpt/XiFoam.o -L/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
         -lengine -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -lbasicThermophysicalModels -lreactionThermophysicalModels -lspecie -llaminarFlameSpeedModels -lfiniteVolume -lmeshTools -llduSolvers -lOpenFOAM -liberty -ldl   -lm -o /home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/XiFoam
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -IXiModels/XiModel -IXiModels/XiEqModels/XiEqModel -IXiModels/XiGModels/XiGModel -IPDRModels/dragModels/PDRDragModel -IlaminarFlameSpeed/SCOPE -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/engine/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/sampling/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/specie/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/reactionThermo/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/compressible/RAS/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/laminarFlameSpeed/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicFvMesh/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/triSurface/lnInclude -IlnInclude -I. -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64GccDPOpt/XiModel.o Make/linux64GccDPOpt/newXiModel.o Make/linux64GccDPOpt/fixed.o Make/linux64GccDPOpt/algebraic.o Make/linux64GccDPOpt/transport.o Make/linux64GccDPOpt/XiEqModel.o Make/linux64GccDPOpt/newXiEqModel.o Make/linux64GccDPOpt/Gulder.o Make/linux64GccDPOpt/instabilityXiEq.o Make/linux64GccDPOpt/SCOPEBlendXiEq.o Make/linux64GccDPOpt/SCOPEXiEq.o Make/linux64GccDPOpt/XiGModel.o Make/linux64GccDPOpt/newXiGModel.o Make/linux64GccDPOpt/KTS.o Make/linux64GccDPOpt/instabilityG.o Make/linux64GccDPOpt/PDRkEpsilon.o Make/linux64GccDPOpt/PDRDragModel.o Make/linux64GccDPOpt/newPDRDragModel.o Make/linux64GccDPOpt/basic.o Make/linux64GccDPOpt/basicXiSubXiEq.o Make/linux64GccDPOpt/basicXiSubG.o Make/linux64GccDPOpt/SCOPELaminarFlameSpeed.o Make/linux64GccDPOpt/PDRFoam.o -L/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64GccDPOpt \
         -lengine -lmeshTools -lcompressibleTurbulenceModel -lcompressibleRASModels -lbasicThermophysicalModels -lreactionThermophysicalModels -lspecie -llaminarFlameSpeedModels -lfiniteVolume -ldynamicFvMesh -llduSolvers -lOpenFOAM -liberty -ldl   -lm -o /home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64GccDPOpt/PDRFoam
/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt/lib/libmesquite.so.0: undefined reference to `std::_List_node_base::_M_unhook()@GLIBCXX_3.4.14'
/home/jmatthei/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64GccDPOpt/lib/libmesquite.so.0: undefined reference to `std::_List_node_base::_M_hook(std::_List_node_base*)@GLIBCXX_3.4.14'
Old   July 7, 2011, 05:25
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
What gcc version are you using?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   July 7, 2011, 09:00
Antonio Liggieri
Hello l_r_mcglashan
isn't it possible to define the compiler in file
~/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh
by setting the following variable?
compilerInstall=System
or
compilerInstall=OpenFOAM
Old   July 7, 2011, 11:27
I am indeed using the system compiler:
gcc (Ubuntu 4.4.3-4ubuntu5) 4.4.3
Old   July 7, 2011, 11:47
How was mesquite compiled? It looks like GLIBCXX_3.4.14 comes with a later gcc version. Try googling it.
Old   July 14, 2011, 19:18
Rachid bannari
bannari is on a distinguished road
I got the following error with AllMake.stage3.
Any idea?
Package name :
Package URL :
RPM spec file name:
Additional flags :
Making package using RPM.
rpm_build: missing SPEC file for package scotch-5.1.10b. Aborting.
Installing package:
Uninstalling using RPM: -linux64GccDPOpt.x86_64
Installing using RPM file: /home/bannari/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/-linux64GccDPOpt.x86_64.rpm
erreur: échec de l'ouverture de /home/bannari/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/-linux64GccDPOpt.x86_64.rpm: Aucun fichier ou dossier de ce type
Done installing package
Package name :
Package URL :
RPM spec file name:
Additional flags :
rpm_build: missing SPEC file for package ParMetis-3.1.1. Aborting.
Installing package:
bannari is offline   Reply With Quote
Old   October 27, 2011, 21:26
albem is on a distinguished road
Hi Cris
Could please tell how you installed OpenFOAM-1.6-ext, I am having a lot of problems in Fedora 15, 64 bit
Thank you
Alberto
Originally Posted by cnsidero View Post
Ya, it is fairly new - I am brave ;-). Actually I looked closer and Paraview was not getting built/installed correctly either. So perhaps there is something different in RHEL 6.0
FWIW, I managed to get 1.6-ext built and installed (not Paraview). In the mean time, I opt'd to use system OpenMPI instead in the provided package. Although this wasn't without it's difficulties. Redhat [I'm guessing] decided to either drop the openmpi-devel package and/or not include the compilation tools (e.g. mpiCC) in their openmpi package. So I had to build a new RPM from the SRPM provided on openmpi.org.
albem is offline   Reply With Quote
Old   October 28, 2011, 01:26
Hello Martin
Any news about installing OpenFOAM-1.6-ext on Fedora 15, 64-bit system, I have tried to install it, and it is being a nightmare!, I always get
gcc 4.6.1
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/lib64/ccache/gcc
CRITICAL ERROR
Any help is welcome!
Thank you
Alberto
Originally Posted by mbeaudoin View Post
Hello Chris,
The very long path you are seeing in the log file is fine. This is not the problem.
> I am running RHEL 6.0 x86_64.
This RedHat operating system is fairly new. The rpm based compilation recipe for the Third Party package was not tested on that system.
I guess something changed with the way rpms are build on RHEL 6.0, or something in the spec files is not general enough. However, according to your post, the fact that all the other Third party packages are successfully being built on the same system is a bit baffling...
I don't have access to a RHEL 6.0 x86_64 system, but maybe I can replicate the problem with the latest version of Fedora.
I know however that all is fine on a Fedora 14 32-bit system. I will check on a 64-bit system, just in case...
Martin
Old   April 25, 2012, 12:22
Disabled
anon_c is on a distinguished road
hi foamers i am installing oepnfoam 1.6-ext on opensuse 12.1
after some problems about misquite2.1.2 i changed as many people do to 2.99
then after thirdparty Allmake.stage3:
common.h:84:28: fatal error: mpi.h: No such file or directory
it seems that he is not finding the openMPI instalation but
thirdparty Allmake.stage3 gives:
Starting ThirdParty AllMake: Stage2
Package name : openmpi-1.4.3
Package URL : http://www.open-mpi.org/software/omp...i-1.4.3.tar.gz
RPM spec file name: openmpi-1.4.3.spec
Additional flags :
Updating the ThirdParty environment variables before building package openmpi-1.4.3
Package openmpi-1.4.3 is already installed
Done ThirdParty AllMake: Stage2
sathya123 likes this.
anon_c is offline   Reply With Quote
Old   January 20, 2016, 15:56
Karnataka
sathya123 is on a distinguished road
I have faced a similar problem in my installation. Namely,
"db/IOstreams/Pstreams/IPread.C:29:17: fatal error: mpi.h: No such file or directory"
Any ideas foamers?
sathya123 is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 13:46
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 18:55
