#61 |
Giovanni Caramia
Rep Power: 17 ![]() |
I use opensuse 11.3 and I'm having a similar problem with AllMake.stage2. This is the end of the output:
make[1]: Leaving directory `/home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/openmpi-1.4.3' + echo '' + echo 'Generating OpenFOAM specific .csh and .sh files for the package openmpi-1.4.3' Generating OpenFOAM specific .csh and .sh files for the package openmpi-1.4.3 + echo '' + mkdir -p /home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/openmpi-1.4.3-linux64GccDPOpt.x86_64//home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/etc + cat + cat + /usr/lib/rpm/brp-lib64-linux sf@suse.de: if you find problems with this script, drop me a note + RPM_BUILD_ROOT=/home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/openmpi-1.4.3-linux64GccDPOpt.x86_64 + export RPM_BUILD_ROOT + test -x /usr/sbin/Check -a 1000 = 0 -o -x /usr/sbin/Check -a '!' -z /home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/openmpi-1.4.3-linux64GccDPOpt.x86_64 + echo 'I call /usr/sbin/Check...' I call /usr/sbin/Check... + /usr/sbin/Check /home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh: line 67: /home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/etc/openmpi-1.4.3.sh: No such file or directory errore: Stato d'uscita errato da /home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.1FRj0B (%install) Errori di compilazione RPM: Stato d'uscita errato da /home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.1FRj0B (%install) Package openmpi-1.4.3 is already installed Done installing package openmpi-1.4.3 ======================================== Done ThirdParty AllMake: Stage2 ======================================== |
#62 |
David Boger
This may look similar to the problems in the previous posts involving openmpi, but I think it is different.
I successfully installed 1.6-ext under openSUSE 11.1 by cloning the git repo and installing the ThirdParty libraries using the AllMake script. Everything seemed to go okay with openmpi, and I'm able to run the interFoam/laminar/damBreak case in parallel, for example; however, a problem arises when I try to link a separate executable of my own with the openmpi libraries. I compile my executable using Autotools and a configure command that includes the command line option --with-mpi=$MPI_ARCH_PATH, where MPI_ARCH_PATH is /mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt. During the linking process I get these errors: Code:
libtool: link: warning: library `/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libmpi.la' was moved. /usr/bin/grep: /mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/openmpi-1.4.3-root/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libopen-rte.la: No such file or directory /usr/bin/sed: can't read /mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/openmpi-1.4.3-root/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libopen-rte.la: No such file or directory libtool: link: `/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/openmpi-1.4.3-root/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libopen-rte.la' is not a valid libtool archive Code:
/usr/bin/grep: /mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/openmpi-1.4.3-root/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libopen-rte.la: No such file or directory /usr/bin/sed: can't read /mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/openmpi-1.4.3-root/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libopen-rte.la: No such file or directory libtool: link: `/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/openmpi-1.4.3-root/mnt/disk4/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libopen-rte.la' is not a valid libtool archive ... So ... any ideas on how to get out of this? The README.ThirdParty discusses relocating the RPM root installation directory. Do I need to re-install from the RPM following that advice (i.e. even though openmpi seems to otherwise be "working" now)? Thanks, David
David A. Boger |
#63 |
Martin Beaudoin
Rep Power: 22 ![]() |
Hello David,
Would you mind sending me a little autotools/automake preconfigured test case, where the main program simply calls MPI_Init() and then exits? That way, I could rapidly test this problem when trying to link with the openmpi libraries installed under the 1.6-ext Third Party Pack. Martin |
#64 |
David Boger
Martin- Thanks. That sounds great. I'll work on putting something together.
David A. Boger |
#65 |
Mathieu Olivier
Dear Martin,
I had an issue while compiling the ThirdParty package using the system openmpi (on ubuntu 10.04). The compilation of scotch complains about a missing mpi.h file... Changing the line 42 in the "scotch-5.1.10b_patch_0" file : +CCD = gcc -I$(MPI_HOME)/include by either +CCD = gcc -I$(MPI_HOME)/include/mpi or +CCD = gcc -I$(OPENMPI_INCLUDE_DIR) solved the problem. Just to let you know... Regards, Mathieu |
#66 | |
Daniel WEI (老魏)
Rep Power: 21 ![]() |
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
#67 |
Mathieu Olivier
Dear Daniel,
I actually use the SYSTEMOPENMPI option in my prefs.sh file : export WM_MPLIB=SYSTEMOPENMPI Mathieu |
#68 | |||
Daniel WEI (老魏)
Really, that's quite strange.. You see, you said when you set
there are lines Quote:
#69 |
Mathieu Olivier
Well, it seams that the compiler only sees $MPI_HOME (+CCD = gcc -I$(MPI_HOME)/include) which points to /usr/include on my system. And since the link to the system openmpi include directory is /usr/include/mpi on ubuntu 10.04, I need to modify the "scotch-5.1.10b_patch_0" file... unless I am missing something else...
#70 |
Daniel WEI (老魏)
Oh, I see. Thanks for explanation. I always check the building time of every parts, and I found, openmpi usally does not take very long time, it is quite fast now, it is paraview and openfoam are the real big monsters. Since then, I start to use NOT the system openmpi.
Regards,
#71 | |
Mathieu Olivier
+CCD = gcc -I$(MPI_HOME)/include by +CCD = gcc -I$(MPI_HOME)/include/mpi and the compilation of scotch worked. Mathieu |
#72 |
Chris Sideroff
There have been no replies or suggestions regarding 'karamiag' and 'ashishnedungadi' issues with openmpi error during stage 2. I want to add my name to the list of people with the same issue.
All the output from stage 2 in a log file exceeds the upload size limits for the forums so here's the last 20 lines with error: Code:
... /opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/openmpi-1.4.3-linux64GccDPOpt.x86_64/opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib/libopen-rte.la:libdir='/opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/openmpi-1.4.3-linux64GccDPOpt.x86_64/opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/lib' Found '/opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/openmpi-1.4.3-linux64GccDPOpt.x86_64' in installed files; aborting error: Bad exit status from /opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.abfac7 (%install) RPM build errors: Bad exit status from /opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.abfac7 (%install) Installing package: openmpi-1.4.3 Uninstalling openmpi-1.4.3 using RPM: openmpi-1.4.3-linux64GccDPOpt.x86_64 Installing openmpi-1.4.3 using RPM file: /opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/openmpi-1.4.3-linux64GccDPOpt.x86_64.rpm error: open of /opt/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/RPMS/x86_64/openmpi-1.4.3-linux64GccDPOpt.x86_64.rpm failed: No such file or directory Done installing package openmpi-1.4.3 ======================================== Done ThirdParty AllMake: Stage2 ======================================== |
#73 |
Giovanni Caramia
Hi Chris,
I hope this help: abaut my last post, I think the problem is in the command + mkdir -p/home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILDROOT/openmpi-1.4.3-linux64GccDPOpt.x86_64//home/tecnici/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linux64GccDPOpt/etc where /home is repeated twice, so this command creates directories in the wrong path. I tried to fix this but with no success. |
#74 |
David Boger
New machine, new problem. When installing from an rpm (specifically for openmpi, although I suspect the same will be true for any rpm), I get this error:
error: can't create transaction lock on /var/lock/rpm/transaction
Thanks, David
David A. Boger |
#75 |
Laurence R. McGlashan
Rep Power: 23 ![]() |
I found this a while back:
http://www.nordugrid.org/documents/r...everybody.html Although I don't know if OF-1.6-ext will work.
Laurence R. McGlashan :: Website |
#76 |
David Boger
Thanks Laurence. That's a very helpful link but unfortunately does not mention transaction locks. Every mention I can find of transaction locks is solved by someone saying "oh, I forgot to be root", but I thought the plan here was not to require that. Plus, I have already installed successfully on two other machines (with different OS) where I was not root.
David A. Boger |
#78 |
David Boger
Yes- I think that does help! On the machine where I am unable to install, the lock path is hardwired to /var/lock/rpm/transaction, whereas on the machine where I am able to install, it is set to %{_dbpath}/__db.000. Since the install command specifies a local dbpath, and it's not being used to define the lock path, I'm guessing that's the problem. I'll let you know once I get some help changing it.
Thanks! David
David A. Boger |
#79 |
David Boger
For the record, changing the rpm lock path fixed the problem. I subsequently ran into another error (discussed here) - removing the __db* files from the local rpm database appeared to resolve that problem.
Thanks Laurence!
David A. Boger |
#80 | |
Chris Sideroff
From what I've found it seems to build the openmpi binaries and libraries in the BUILDROOT dir Ok but fails to create the .rpm file. Hence the 'open' error in my last post. I'm going to dig around more to see why it did not make the rpm but it wasn't obvious in the AllMake.stage2 output. Maybe at this point I will direct my inquiry toward Martin Beaudoin (the author of the build system) ... Martin, you have some hints about determining why the rpm wouldn't get built? |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 13:46 |
OpenFOAM Version 1.6 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 27, 2009 18:55 |
