missing vtf3.h BPatch.h papi.h
Old   July 24, 2012, 06:28
Illya Shevchuk
linch is on a distinguished road
Hi Bruno,
mpi-default-bin & mpi-default-dev did the job. I've got lots of warnings
UOPwrite.C: warning: use of old-style cast
but no erors and mpirun works,
Thank you very much!
Illya
P.S. I've just compiled OF 2.1.x on another WS with the same Debian. There were no problems this time with the compilation of the OF-internal openmpi, but there were also a lot of "old-style cast" warnings.
linch is offline   Reply With Quote
Old   July 24, 2012, 15:45
Retired Super Moderator
Bruno Santos
Hi Illya,
Finally!
I've got lots of warnings but no erors and mpirun works,
Don't worry, those are normal. It's only a matter of coding elegance vs time necessary to remove those warnings...
WS: work space? Maybe workstation? Mmmm... then my guess is it's either due to one of two reasons:
  1. Your first work space/station is contaminated somehow; for example, the Intel compiler and the custom MPI might not be directly visible on the new one.
  2. The system/default MPI clears any doubts that OpenFOAM might have
Either way, a clean Debian installation in a virtual machine had already revealed itself to be as simple as following the same instructions as for Ubuntu
Best regards,
Bruno
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam-installation/80787-missing-vtf3-h-bpatch-h-papi-h.html
Posted By For Type Date
Albert's Useful Computer Tips: gcc and OpenFOAM This thread Refback October 16, 2013 06:46
Missing Term in RAS-Models ngj OpenFOAM Bugs 17 February 29, 2012 08:05
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
Missing output files stefanke OpenFOAM Running, Solving & CFD 4 September 8, 2006 05:51
Missing tets along line when meshing with ICEM CFD Georges P. Côté CFX 6 March 23, 2006 01:34
