Installation on Fedora 12 64-bit
Old   September 23, 2010, 10:56
Default Installation on Fedora 12 64-bit
Tony
tonyuprm is on a distinguished road
I am trying to install OpenFOAM 1.7.1 on my Fedora 12 64-bit system. I have not been able to install it successfully. I followed the instructions on the OpenFOAM website. The installation runs but has many errors. Here is the last line in the terminal after trying to install:
/usr/bin/ld: cannot find -lOpenFOAM
collect2: ld returned 1 exit status
make[2]: *** [/home/tony/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT] Error 1
make[2]: Leaving directory `/home/tony/OpenFOAM/OpenFOAM-1.7.1/applications/utilities/thermophysical/mixtureAdiabaticFlameT'
make[1]: *** [mixtureAdiabaticFlameT] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/tony/OpenFOAM/OpenFOAM-1.7.1/applications/utilities/thermophysical'
make: *** [thermophysical] Error 2
make: Target `application' not remade because of errors.
When I run the "foamInstallationTest" script this is what I get:
Executing ./foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               localhost.localdomain
OS:                 Linux version 2.6.31.5-127.fc12.x86_64
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/tony/OpenFOAM                      yes       yes
$WM_PROJECT_USER_DIR /home/tony/OpenFOAM/tony-1.7.1           no        no
$WM_THIRD_PARTY_DIR  /home/tony/OpenFOAM/ThirdParty-1.7.1     yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/tony/OpenFOAM/OpenFOAM-1.7.1       yes  yes  yes
$FOAM_APPBIN         ...7.1/applications/bin/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    ...nFOAM/site/1.7.1/bin/linux64GccDPOpt  no        no
$FOAM_USER_APPBIN    ...7.1/applications/bin/linux64GccDPOpt  no        no
$WM_DIR              /home/tony/OpenFOAM/OpenFOAM-1.7.1/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...M/OpenFOAM-1.7.1/lib/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    ...nFOAM/site/1.7.1/lib/linux64GccDPOpt  no        no
$FOAM_USER_LIBBIN    ...nFOAM/tony-1.7.1/lib/linux64GccDPOpt  no        no
$MPI_ARCH_PATH       ...1/platforms/linux64Gcc/openmpi-1.4.1  yes  yes  yes
Third party software
Software Version   Location
gcc      4.4.4     /usr/bin/gcc
gzip     1.3.12    /usr/bin/gzip
tar      1.22      /bin/tar
icoFoam
WARNING:  Conflicting installations:
          OpenFOAM settings        : /home/tony/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/icoFoam
          current path             :
          CRITICAL ERROR
Summary
Base configuration ok.
*** The foam installation contains 1 critical error(s)
***     Review the output for warning messages and consult
***     the installation guide for trouble shooting.
done.
tonyuprm is offline   Reply With Quote
Old   September 25, 2010, 10:24
Retired Super Moderator
Bruno Santos
Greetings Tony,
Ah, Fedora... You better try using OpenFOAM 1.7.x (link). If I'm not mistaken, there were some changes after the release of 1.7.1 that enable the building of OpenFOAM in Fedora to be a lot smoother (link to relevant bug report)... Although it was intended for Fedora 13, but you might have updated 12 so much, that it might look more like 13 right now
Additionally, next time you run Allwmake, use:
./Allwmake > make.log 2>&1
This way you can keep a log of the build process (the first errors are usually the ones that matter ). And for reporting errors here on the forum, it's a lot easier to post the compressed log file... as long as the compressed log file isn't too big for the forum's quota
edit: Did you install the packages mentioned on this post: http://www.cfd-online.com/Forums/ope...tml#post254189 ? On that post you'll find some pearls of wisdom, but the instructions for changing the rules file is no longer needed with OpenFOAM 1.7.1 and 1.7.x.
Best regards,
Bruno
Last edited by wyldckat; September 25, 2010 at 10:28. Reason: Added link to an old post of mine...
Old   September 26, 2010, 02:33
Tony
Hi Bruno,
Thanks for your reply. I think I was having a problem because I had tried to install it before. I erased the files but was still having the problem. What I did was I ran the $HOME/OpenFOAM/OpenFOAM-1.7.1/wmake/wcleanAll script and was able to install it afterwards without a problem.
Thanks,
Tony
Qt installation in Fedora for OpenFOAM......Required Urgently...... devesh.baghel OpenFOAM 1 November 17, 2009 10:08
[OpenFOAM] Segmentation fault with paraFoam and paraview 3.6.1 on Fedora 11 32 and 64 bit nanes ParaView 2 September 11, 2009 10:12
AMD 64 bit installation maka OpenFOAM Installation 7 January 11, 2009 11:42
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
problem in installation of Fedora code peter Main CFD Forum 1 August 22, 2006 10:03
