Building OpenFOAM1.7.0 from source
Like Tree9Likes
Old   May 14, 2012, 18:47
Matthew Denno
mgdenno is on a distinguished road
I am trying to compile OF 1.7.1 in Kubuntu 11.10 and am getting errors. I am not sure if it is important but I already have OF 2.1.0 installed and working fine.
versions:
g++ (Ubuntu/Linaro 4.6.1-9ubuntu3) 4.6.1
gcc (Ubuntu/Linaro 4.6.1-9ubuntu3) 4.6.1
flex 2.5.35
I installed the additional dependencies as suggested above:
 sudo apt-get install binutils-dev flex bison git-core  build-essential python-dev libreadline5-dev wget zlib1g-dev cmake  libpng12-dev libxt-dev libxi-dev libxrender-dev libxrandr-dev  libxcursor-dev libxinerama-dev libfreetype6-dev libfontconfig1-dev  libglib2.0-dev freeglut3-dev libqt4-dev qt4-dev-tools
The only one that I couldn't install is libreadline5-dev because it is not available in 11.10. However, I do have libreadline-dev installed, I am not sure if this is ok or if libreadline5-dev specifically is needed.
After I run:
./Allwmake > make.log 2>&1
The log file looks okay until eventually:
+ wmake all solvers
make[1]: Entering directory `/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/applications/solvers/DNS'
make[2]: Entering directory `/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/applications/solvers/DNS/dnsFoam'
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-40 -I/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/src/finiteVolume/lnInclude     -I/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/src/randomProcesses/lnInclude     -I/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/src/sampling/lnInclude -IlnInclude -I. -I/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude   -fPIC Make/linux64GccDPOpt/dnsFoam.o -L/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt \
	     -lfiniteVolume     -lrandomProcesses     -lsampling     -lmeshTools -lOpenFOAM -liberty -ldl   -lm -o /home/mdenno/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/dnsFoam
/usr/bin/ld: Make/linux64GccDPOpt/dnsFoam.o: undefined reference to symbol 'Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)'
/usr/bin/ld: note: 'Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)' is defined in DSO /home/mdenno/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so so try adding it to the linker command line
/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/openmpi-1.4.1/libPstream.so: could not read symbols: Invalid operation
collect2: ld returned 1 exit status
make[2]: *** [/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/dnsFoam] Error 1
make[2]: Leaving directory `/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/applications/solvers/DNS/dnsFoam'
make[1]: *** [dnsFoam] Error 2
make[1]: Target `application' not remade because of errors.
make[1]: Leaving directory `/home/mdenno/OpenFOAM/OpenFOAM-1.7.1/applications/solvers/DNS'
make: *** [DNS] Error 2
And the errors keep going...
Any thoughts?
mgdenno is offline   Reply With Quote
Old   May 14, 2012, 19:39
Retired Super Moderator
Bruno Santos
Greetings Matthew,
Well, OpenFOAM 1.7.1 isn't compatible with Gcc 4.6.1 See here: http://openfoamwiki.net/index.php/In...tion_.28GCC.29
You can either install Gcc 4.4.x that Ubuntu 11.10 has or make a custom build of Gcc 4.4.x or 4.5.x. For then using Gcc 4.4.x... there are a few explanations: GCC and other compiler issues with OpenFOAM - but the best one might be described here, "On how to use gcc44 in RHEL/CentOS/Rocks": OpenFOAM install on RHEL 5.5
Best regards,
Bruno
Old   May 14, 2012, 21:48
Matthew Denno
Bruno,
Thanks so much for the advice.
It is compiling now...
Matt
Old   March 5, 2022, 14:34
Default Keep geting similar errors in OpenFOAM 2.4.0
  #44
Yovanny Morales Hernández
yMorH is on a distinguished road
Originally Posted by wyldckat View Post
Greetings Matthew,
Best regards,
Bruno
I tried to install OpenFOAM-2.4.0 following the instructions of post #4, however I keep getting similar errors:
HTML Code:
g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I../solidDisplacementFoam -ItractionDisplacementCorrectionStress -I/home/qbex/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/qbex/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -IlnInclude -I. -I/home/qbex/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/qbex/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linuxGccDPOpt/tractionDisplacementCorrectionFvPatchVectorField.o Make/linuxGccDPOpt/solidEquilibriumDisplacementFoam.o -L/home/qbex/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/lib \
     -lfiniteVolume -lmeshTools -lOpenFOAM -ldl   -lm -o /home/qbex/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/solidEquilibriumDisplacementFoam
/home/qbex/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/lib/libtriSurface.so: undefined reference to `yyFlexLexer::yywrap()'
collect2: error: ld returned 1 exit status
/home/qbex/OpenFOAM/OpenFOAM-2.4.0/wmake/Makefile:149: recipe for target '/home/qbex/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/solidEquilibriumDisplacementFoam' failed
make[2]: *** [/home/qbex/OpenFOAM/OpenFOAM-2.4.0/platforms/linuxGccDPOpt/bin/solidEquilibriumDisplacementFoam] Error 1
make[2]: Leaving directory '/home/qbex/OpenFOAM/OpenFOAM-2.4.0/applications/solvers/stressAnalysis/solidEquilibriumDisplacementFoam'
/home/qbex/OpenFOAM/OpenFOAM-2.4.0/wmake/MakefileApps:39: recipe for target 'solidEquilibriumDisplacementFoam' failed
make[1]: *** [solidEquilibriumDisplacementFoam] Error 2
make[1]: Target 'application' not remade because of errors.
make[1]: Leaving directory '/home/qbex/OpenFOAM/OpenFOAM-2.4.0/applications/solvers/stressAnalysis'
/home/qbex/OpenFOAM/OpenFOAM-2.4.0/wmake/MakefileApps:39: recipe for target 'stressAnalysis' failed
make: *** [stressAnalysis] Error 2
make: Target 'application' not remade because of errors.
I am asking is those errors are related to your statements in post #42, gcc version 5.4.0. I have attached the make log to this post.
Thanks in advance for your time.
Fouch likes this.
yMorH is offline   Reply With Quote
Old   March 6, 2022, 08:09
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The errors state that you don't have flex installed. Did you use a system flex or a ThirdParty flex? I don't think that a ThirdParty flex is well tested at all.
yMorH likes this.
olesen is offline   Reply With Quote
Old   March 6, 2022, 13:02
I'm not sure about the answer to your question, I get the dependencies as posted in #4 after an initial installation failure following the instructions in OpenFOAM foundation for OpenFOAM-2.4.0 and as you can see it fails again.
I found this tread on this website Problems installing OpenFOAM 2.4.0 on Ubuntu 16.04 and there I found a step by step guide to install OpenFOAM-2.4.0,https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04 , I run all the steps in that guide and the installation run smoothly. No more errors so far.
Thanks for your answer!
Old   March 6, 2022, 14:21
Mark Olesen
Quite simply that your error shows the following
So either there is something odd with your flex installation or the lexing code in OpenFOAM itself needs some adjustment. Take a look at how the corresponding bit of code looks like in a newer version of OpenFOAM - perhaps some clues there.
Keep in mind that you are trying to compile code that is about 6.5 years old, so the amount of help you can expect will be pretty modest.
yMorH likes this.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
