OF 1.7 installation problem "command not found error"
Old   October 6, 2010, 10:49
maysmech's Avatar
maysmech is on a distinguished road
Ubuntu 10.04
maysmech is offline   Reply With Quote
Old   October 6, 2010, 10:57
Retired Super Moderator
Bruno Santos
Hi Maysam,
But that package does exist:libreadline5-dev at packages.ubuntu
Try this:
sudo apt-get update
Then try again installing the package.
If it still doesn't work, possibly you disabled the repository that has that package. Go to Synaptic and re-activate the repository (I think it is the "main lucid" repository). And while you're in Synaptic, you can install the package from there!
Best regards,
Bruno
Old   December 8, 2010, 14:13
Default .
  #23
shyam
ksp1717 is on a distinguished road
Hi
I followed the wiki tutorial which you have posted in one of your posts and followed it exactly.
I am trying to compile a new solver chtIcoMultiRegionFoam
And no matter what I do I end up getting the following wmake:command not found error
Can you please help me
Thanks
Shyam
UPDATE: I successfully compiled the solver in Fedora 13 with OpenFoam 1.7.1. Have not tested it yet. But i m still having problems with ubuntu. Going to use fedora for now.
ksp1717 is offline   Reply With Quote
Old   December 11, 2010, 08:07
Bruno Santos
Hi Shyam,
Mmm, how exactly did you install OpenFOAM in Ubuntu? Did you build from source or did you install from the Debian packages?
Because the error "wmake:command not found error" is usually related to not having the OpenFOAM environment variables properly set up, namely running:
. ~/OpenFOAM/OpenFOAM-1.7.1/etc/bashrc
Best regards,
Bruno
[GAMBIT] Gambit Installation Serious Problem,,,,, devesh.baghel ANSYS Meshing & Geometry 2 February 22, 2010 08:29
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
Problem with Fortran installation. skarp CFX 0 August 4, 2007 08:09
installation problem Dr C.Bhasker Siemens 1 September 13, 2006 08:01
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
