June 30, 2010, 13:24 |
switch.H errors
Mirko Vukovic
Rep Power: 17 |
I am trying to install simpleViewer to preview the blockMesh geometry. That would help me understand the geometries in the tutorials. I installed the fox toolkit, and during the simpleViewere installation, I get the following error from an OF1.6 file: Code:
... In file included from /home/sm/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Time.H:49, from /home/sm/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude/fvCFD.H:6, from FXGLCurvedLine.H:38, from FXGLCurvedLine.C:45: /home/sm/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Switch.H: At global scope: /home/sm/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Switch.H:79: error: expected identifier before numeric constant /home/sm/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Switch.H:79: error: expected `}' before numeric constant /home/sm/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Switch.H:79: error: expected unqualified-id before numeric constant /home/sm/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Switch.H:92: error: ‘INVALID’ was not declared in this scope /home/sm/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Switch.H:98: error: ‘switchType’ does not name a type ... etc. > gcc --version gcc (OpenFOAM) 4.3.3 I suspect I am missing (messing) something, but what? Thanks, Mirko |
November 25, 2010, 08:11 |
Matthias Voß
Rep Power: 20 |
hi,
i am facing the exact same problem here. did you found a solution? neewbie |
November 30, 2010, 10:58 |
Mirko Vukovic
Rep Power: 17 |
Unfortunately no :-(
fox, simpleviewer, switch.h |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
