June 28, 2010, 16:05 |
problem with new OF170 paraview instalation
angel
Rep Power: 17 |
I have installed OF170 as Ubuntu/Debian pack installation, but when I try to view run paraFoam i obtain the following warning:
anmartin@anmartin2:~/foam/floatingObject$ paraFoam --> FOAM Warning : From function dlLibraryTable:pen(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 78 could not load /opt/openfoam170/lib/linux64GccDPOpt/libincompressibleTurbulenceModel.so: undefined symbol: _ZN4Foam11regIOobject6renameERKNS_4wordE --> FOAM Warning : From function dlLibraryTable:pen(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 78 could not load /opt/openfoam170/lib/linux64GccDPOpt/libdynamicMesh.so: undefined symbol: _ZTIN4Foam5token8compoundE --> FOAM Warning : From function dlLibraryTable:pen(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 78 could not load /opt/openfoam170/lib/linux64GccDPOpt/libsurfMesh.so: undefined symbol: _ZN4Foam11regIOobject6renameERKNS_4wordE Someone know what is the problem Best regards |
June 28, 2010, 19:38 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings anmartin,
Which Ubuntu version are you using? I believe the Debian packages have only been tested with Ubuntu 10.04! But fear not, there is a very neat trick with this version ParaView version that comes with the packages
Best regards, Bruno
June 29, 2010, 18:06 |
angel
Rep Power: 17 |
Thank you very much Bruno,
It looks like better for interdymfoam simulation, but I still continous with the problem with the new version 1.7 and the tutorial example of multiphase> floatingObject, this is the case that produce me the problem Floating point exception that crash the simulation and produce the paraFoam error. best regards. Angel |
June 29, 2010, 19:29 |
Bruno Santos
Rep Power: 128 |
Hi Angel,
I'll try that tutorial ASAP, but for now it feels like that tutorial floatingObject is suffering from the same syndrome that the motorBike case had when OpenFOAM 1.6 was released: the motorBike case had a bug in the settings files that was later fixed in 1.6.x. But like I said, I'll try it ASAP, but if somebody else knows this problem and the respective solution, please step in! Best regards, Bruno
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 05:36 |
problem with new OF170 using floatingObject tutorial example | anmartin | OpenFOAM Running, Solving & CFD | 1 | July 1, 2010 02:09 |
Yet another Paraview problem | gascortado | OpenFOAM | 5 | February 21, 2010 07:39 |
problem with running parafoam & paraview | padmanathan | OpenFOAM | 3 | June 12, 2009 08:30 |
[OpenFOAM] Problem with Colors in ParaView | sven | ParaView | 1 | May 31, 2009 09:13 |
