Patches for OpenFOAM 1.7 on MacOS X
Old   September 20, 2011, 21:40
albem is on a distinguished road
Hi
I have installed OpenFOAM-1.6-ext on my Mac, I could compile conjugateHeatFoam solver but when I ran it I got
--> FOAM FATAL ERROR:
Attempt to cast type wall to type lduInterface
From function refCast<To>(From&)
in file /Users/hjasak/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/typeInfo.H at line 115.
It is strange to me because the directory /Users/hjasak/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude
does not exist in my Mac
I have observed that in my
conjugateCavity/constant/solid/polyMesh/boundary file
I have
FoamFile
version 2.0;
format ascii;
root "/home/hjasak/OpenFOAM/hjasak-1.3/run/coupledMatrix";
case "heatedBlock";
instance "constant";
local "polyMesh";
class polyBoundaryMesh;
object boundary;
I don't know what I could write in root, Should I write the directory where coupledMatrix is located or the directory where my heatedBlock directory is located?
Any help is welcome
Alberto
albem is offline   Reply With Quote
Old   September 21, 2011, 06:37
Assistant Moderator
Bernhard Gschaider
Originally Posted by albem View Post
Hi
I have
FoamFile
version 2.0;
format ascii;
case "heatedBlock";
local "polyMesh";
object boundary;
Any help is welcome
Alberto
The paths you are refering to are inserted into the binaries during compilation. If you compile OF yourself they will point to places you know
About the actual problem. This is not Mac-specific but a general problem (I'd propose you move to another thread. One about conjugateFoam). Have you run the tutorial using the Allrun-script? Because that does some manipulations that might fix you problem
[blockMesh] Default patches not appearing in paraview ozzythewise OpenFOAM Meshing & Mesh Conversion 9 September 22, 2017 10:51
[snappyHexMesh] internal faces between patches created with snappyHexMesh romant OpenFOAM Meshing & Mesh Conversion 0 August 17, 2009 09:40
Courant number, patches, etc oort OpenFOAM 1 July 24, 2009 19:05
[snappyHexMesh] SnappyHexMesh large number of patches written prapanj OpenFOAM Meshing & Mesh Conversion 0 July 15, 2009 09:11
radiation patches, viewfactors beams Siemens 1 March 12, 2009 08:39
