Openfoam installation on OpenSuse 11.1
Old   June 15, 2010, 16:54
Default Openfoam installation on OpenSuse 11.1
Paulo Bufacchi
Bufacchi is on a distinguished road
Howdy y'all
I'm trying to compile OpenFOAM 1.6.x on OpenSuse 11.1 64bits. It's been a tough job so far, but reading the threads I managed to struggle with a single error. Although it seems to be an error already reported, I could not find my way through it.
Comments are welcome. Thanks.
Paulo
Checking basic setup...
Shell: bash
Host: linux-nkui
OS: Linux version 2.6.27.45-0.1-default
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/paulo/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/paulo/OpenFOAM/paulo-1.6.x yes no
$WM_THIRD_PARTY_DIR /home/paulo/OpenFOAM/ThirdParty-1.6.x yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/paulo/OpenFOAM/OpenFOAM-1.6.x yes yes yes
$FOAM_APPBIN ...6.x/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN ...nFOAM/site/1.6.x/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...6.x/applications/bin/linux64GccDPOpt no no
$WM_DIR .../paulo/OpenFOAM/OpenFOAM-1.6.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.6.x/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...nFOAM/site/1.6.x/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...FOAM/paulo-1.6.x/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...nmpi-1.3.3/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.3 ...M/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/bin/gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.20 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/paulo/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
Bufacchi is offline   Reply With Quote
Old   June 15, 2010, 20:55
Default I made it
Paulo Bufacchi
I installed flex, copied Allwmake from OpenFOAM-1.6/applications to OpenFOAM-1.6.x/applications and it ran ok.
Thanks!
Shell: bash
Host: linux-nkui
tar 1.20 /bin/tar
icoFoam 1.6.x ...penFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
Summary
Critical systems ok.
done.
OpenFOAM Live USB based on openSUSE 11.1 created with SUSE Studio alberto OpenFOAM 40 May 23, 2010 17:15
Installation problem in OpenSuse 11.1 oort OpenFOAM Installation 4 June 30, 2009 16:56
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 15:06
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 07:28
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
