PLease somebody help:problem while changing blockMeshDict file |
June 10, 2010, 07:49 |
Vivek Gupta
Rep Power: 16 |
I am using openfoam 1.6 on opensuse 10.3 and i am working using dieselFoamsolver.....when i tried to run the aachen bomb case it worked fine using the following blockmesh dict file::
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (-10 0 -10) (-10 0 10) (10 0 10) (10 0 -10) (-10 100 -10) (-10 100 10) (10 100 10) (10 100 -10) ); blocks ( hex (0 1 2 3 4 5 6 7) (41 41 100) simpleGrading (1 1 1) ); edges ( ); patches ( wall walls ( (2 6 5 1) (0 4 7 3) (0 1 5 4) (4 5 6 7) (7 6 2 3) (3 2 1 0) ) ); mergePatchPairs ( ); // ************************************************** *********************** // NOW I TRIED TO CHANGE THE BLOCKMESHDICT FILE TO:: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( // (Y Z X) // Quader aussen (-10 50 -10) (-10 50 10) (10 50 10) (10 50 -10) (-10 100 -10) (-10 100 10) (10 100 10) (10 100 -10) // Quader innen (-4 50 -4) (-4 50 4) (4 50 4) (4 50 -4) (-4 100 -4) (-4 100 4) (4 100 4) (4 100 -4) ); blocks ( // Innenblock hex (8 9 10 11 12 13 14 15) (25 25 50) simpleGrading (1 1 1) // Innenblock für enge Geometrie nur mit innerem Block // hex (0 1 2 3 4 5 6 7) (25 25 35) simpleGrading (1 1 1) // Randbloecke (Punkte) Vernetzung(X Y Z) NetzGrade(X Y Z) hex (0 1 9 8 4 5 13 12) (25 10 50) simpleGrading (1 0.5 1) hex (1 2 10 9 5 6 14 13) (25 10 50) simpleGrading (1 0.5 1) hex (2 3 11 10 6 7 15 14) (25 10 50) simpleGrading (1 0.5 1) hex (3 0 8 11 7 4 12 15) (25 10 50) simpleGrading (1 0.5 1) ); edges ( ); patches ( wall walls ( // Waende: Rechte-Hand-Regel, Punkte Drehsinn so, dass Wand nach außen orientiert // oben (4 5 13 12) (5 6 14 13) (6 7 15 14) (7 4 12 15) (12 13 14 15) //unten (0 8 9 1) (1 9 10 2) (2 10 11 3) (3 11 8 0) (8 11 10 9) //Seiten (0 1 5 4) (1 2 6 5) (2 3 7 6) (3 0 4 7) //Seiten für enge Geometrie nur mit innerem Block // (0 3 2 1) // (4 5 6 7) ) ); mergePatchPairs ( ); // ************************************************** *********************** // Solver worked fine upto certain timesteps but after time 700 microseconds, it showed an error :: cfd@linux-bw7o:~/OpenFOAM/cfd-1.6/run/aachen_enno_blockmesh> mpirun -np 4 diesel Foam -parallel > log & [1] 6687 cfd@linux-bw7o:~/OpenFOAM/cfd-1.6/run/aachen_enno_blockmesh> [3] #0 Foam::error :rintStack(Foam::Ostream&) in "/home/cfd/OpenFOAM/OpenFOAM-1.6/lib/linux64GccD POpt/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/cfd/OpenFOAM/OpenFOAM-1.6/lib /linux64GccDPOpt/libOpenFOAM.so" [3] #2 ?? in "/lib64/libc.so.6" [3] #3 Foam::RanzMarshall::relaxationTime(double, double, double, double, doubl e, double) const in "/home/cfd/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdies elSpray.so" [3] #4 Uninterpreted: [linux-bw7o:06694] *** Process received signal *** [linux-bw7o:06694] Signal: Floating point exception (8) [linux-bw7o:06694] Signal code: (-6) [linux-bw7o:06694] Failing at address: 0x3e800001a26 [linux-bw7o:06694] [ 0] /lib64/libc.so.6 [0x2b58661c7bd0] [linux-bw7o:06694] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x2b58661c7b45] [linux-bw7o:06694] [ 2] /lib64/libc.so.6 [0x2b58661c7bd0] [linux-bw7o:06694] [ 3] /home/cfd/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libd ieselSpray.so(_ZNK4Foam12RanzMarshall14relaxationT imeEdddddd+0x64) [0x2b5862c689 34] [linux-bw7o:06694] [ 4] [0x1ffedd0] [linux-bw7o:06694] *** End of error message *** [2] #0 Foam::error:rintStack(Foam::Ostream&)--------------------------------- ----------------------------------------- mpirun noticed that process rank 3 with PID 6694 on node linux-bw7o exited on si gnal 8 (Floating point exception). -------------------------------------------------------------------------- in "/home/cfd/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigFpeHandler(int) in "/home/cfd/OpenFOAM/OpenFOAM-1.6/lib /linux64GccDPOpt/libOpenFOAM.so" I Want to change my mesh since then calculations are more fast.....PLEASE HELP ME!! |
June 11, 2010, 18:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Vivek,
You should have posted in this particular section of the forum: OpenFOAM Meshing: blockMesh Since you have posted in the OpenFOAM Installation section, it's less likely that you will get a proper answer to your problem Personally I'm not very experienced with blockMesh, so I can't help you with your current problem Best regards, Bruno
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 12:46 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 05:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 07:43 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 16:16 |
