May 16, 2010, 08:05 |
OpenFOAM-1.5 for large scale compute server
SATORU ESASHI
Rep Power: 17 |
Hi!!
Now, I try to install OpenFOAM-1.5 on large scale computer server. but, I have one problem when I carried out ./Allwmake. It is occured such as below. SOURCE=autoHexMesh/autoHexMeshDriver/autoRefineDriver.C ; g++ -m64 - Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate- depth-40 -I/work/esashi/OpenFOAM/OpenFOAM-1.5/src/ decompositionAgglomeration/decompositionMethods/lnInclude -I/work/ esashi/OpenFOAM/OpenFOAM-1.5/src/dynamicMesh/lnInclude -I/work/esashi/ OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/work/esashi/ OpenFOAM/OpenFOAM-1.5/src/lagrangian/basic/lnInclude -I/work/esashi/ OpenFOAM/OpenFOAM-1.5/src/meshTools/lnInclude -I/work/esashi/OpenFOAM/ OpenFOAM-1.5/src/edgeMesh/lnInclude -I/work/esashi/OpenFOAM/ OpenFOAM-1.5/src/triSurface/lnInclude -IlnInclude -I. -I/work/esashi/ OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/work/esashi/OpenFOAM/ OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/ linux64GccDPOpt/autoRefineDriver.o /work/esashi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/PtrList.C: In copy constructor ‘Foam::PtrList<T>::PtrList(const Foam::PtrList<T>&) [with T = Foam::featureEdgeMesh]’: autoHexMesh/autoHexMeshDriver/autoRefineDriver.C:260: instantiated from here /work/esashi/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/PtrList.C: 56: error: invalid conversion from ‘Foam::IOobject*’ to ‘Foam::featureEdgeMesh*’ make: *** [Make/linux64GccDPOpt/autoRefineDriver.o] error 1 + wmake libso errorEstimation after that, I carried out foamInstrationTest. The result represented below. Checking basic setup... ------------------------------------------------------------------------------- Shell: csh Host: rsclw13 OS: Linux version 2.6.18-92.1.10.el5_lustre.1.6.6smp ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /work/esashi/OpenFOAM yes yes $WM_PROJECT_USER_DIR .../research/g48012/OpenFOAM/g48012-1.5 yes no $WM_THIRD_PARTY_DIR /work/esashi/OpenFOAM/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /work/esashi/OpenFOAM/OpenFOAM-1.5 yes yes yes $FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes $FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no $WM_DIR /work/esashi/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes $FOAM_USER_LIBBIN ...nFOAM/g48012-1.5/lib/linux64GccDPOpt yes yes no $MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : Minimum required: 4.2.0 gcc WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.5 /bin/ gzip tar 1.15.1 /bin/ tar icoFoam 1.5 .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/ icoFoam ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_rsclw13 Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. How can I resolve that? If someone knows this problems, Could you tell me how to install? Regards!! |
May 19, 2010, 07:01 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings SARU,
Can you change from OpenFOAM 1.5 to 1.5.x? Or to 1.6 or even 1.6.x? If not, you will have to build gcc version 4.2.x (x=1,2,3 or 4 ). There should be one available in the ThirdParty folder. I say this, because the first error you have is possibly related to changes in gcc coding directives from 4.2.x to 4.3.x . Nonetheless, OpenFOAM 1.6 and 1.6.x should build well with gcc 4.3.1, which is your system's gcc version. As for the "Critical error" that foamInstallationTest reports, it's actually a glitch in the script, which doesn't account for the fact that system/user compilers can be placed anywhere... So that error shouldn't be much of a problem Best regards, Bruno PS: I didn't answer earlier, because I was hoping that someone more experienced with OpenFOAM 1.5 would step in before me...
May 19, 2010, 23:06 |
SATORU ESASHI
Rep Power: 17 |
Greetings Mr. Bruno
I appreciate your responce. Immediately, I try to change gcc version from gcc-4.1.2 to gcc 4.3.1. Best regards SARU |
k Omega SST SAS for OpenFOAM 1.5??? | barath.ezhilan | OpenFOAM Running, Solving & CFD | 3 | June 2, 2010 08:41 |
OpenFOAM 1.5 dev | LVDH | OpenFOAM | 98 | May 5, 2010 18:01 |
OpenFOAM 1.5 installation on OpenSUSE 11.0 | bigphil | OpenFOAM Installation | 16 | April 29, 2009 07:28 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 05:48 |
OpenFOAM Version 1.5 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | July 14, 2008 19:22 |
