March 23, 2010, 06:39 |
compile error about FJMPI
J. Cai
Rep Power: 17 |
The linux system is "Linux bxfs1 2.6.18-164.6.1.el5 #1 SMP Tue Oct 27 11:28:30 EDT 2009 x86_64 x86_64 x86_64 GNU/Linux".
I am trying to use the system's MPI of "/opt/FJSVplang/bin/mpiexec". tar -xzf OpenFOAM-1.6.General.gtgz tar -xzf ThirdParty-1.6.General.gtgz tar -xzf ThirdParty-1.6.linux64Gcc.gtgz Edit OpenFOAM/OpenFOAM-1.6/etc/cshrc # WM_MPLIB = | OPENMPI | MPICH | MPICH-GM | HPMPI | GAMMA | MPI | QSMPI if ( ! $?WM_MPLIB ) setenv WM_MPLIB FJMPI Edit OpenFOAM/OpenFOAM-1.6/etc/settings.csh case FJMPI: setenv MPI_ARCH_PATH /opt/FJSVplang setenv FOAM_MPI_LIBBIN $FOAM_LIBBIN/mpi _foamAddPath $MPI_ARCH_PATH/bin _foamAddPath /opt/FJSVpnple/bin _foamAddPath /opt/FJSVmpi2/bin _foamAddLib /opt/FJSVpnidt/lib _foamAddLib /opt/FJSVplang/lib64 _foamAddLib /opt/FJSVpnple/lib _foamAddLib /opt/FJSVmpi2/lib/sparcv9 _foamAddLib /opt/FJSVpnple/lib/sparcv9 breaksw /OpenFOAM/OpenFOAM-1.6 ./Allwmake However, I meet the errors shown in follow. Any suggestion is appreciated. HTML Code:
make[2]: Entering directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumCO' Making dependency list for source file equilibriumCO.C make[2]: Leaving directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumCO' make[2]: Entering directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumCO' SOURCE=equilibriumCO.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/equilibriumCO.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/equilibriumCO.o -L/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \ -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/equilibriumCO /usr/bin/ld: warning: libPstream.so, needed by /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so, not found (try using -rpath or -rpath-link) /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `vtable for Foam::OPstream' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::waitRequests()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::~OPstream()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::IPstream(Foam::Pstream::commsTypes, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::exit(int)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::waitRequests()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::abort()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, long)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::init(int&, char**&)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)' collect2: ld returned 1 exit status make[2]: *** [/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/equilibriumCO] Error 1 make[2]: Leaving directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumCO' make[1]: *** [equilibriumCO] Error 2 make[2]: Entering directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumFlameT' Making dependency list for source file equilibriumFlameT.C make[2]: Leaving directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumFlameT' make[2]: Entering directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumFlameT' SOURCE=equilibriumFlameT.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/equilibriumFlameT.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/equilibriumFlameT.o -L/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \ -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/equilibriumFlameT /usr/bin/ld: warning: libPstream.so, needed by /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so, not found (try using -rpath or -rpath-link) /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `vtable for Foam::OPstream' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::waitRequests()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::~OPstream()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::IPstream(Foam::Pstream::commsTypes, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::exit(int)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::waitRequests()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::abort()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, long)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::init(int&, char**&)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)' collect2: ld returned 1 exit status make[2]: *** [/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/equilibriumFlameT] Error 1 make[2]: Leaving directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/equilibriumFlameT' make[1]: *** [equilibriumFlameT] Error 2 make[2]: Entering directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/mixtureAdiabaticFlameT' Making dependency list for source file mixtureAdiabaticFlameT.C make[2]: Leaving directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/mixtureAdiabaticFlameT' make[2]: Entering directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/mixtureAdiabaticFlameT' SOURCE=mixtureAdiabaticFlameT.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mixtureAdiabaticFlameT.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC Make/linux64GccDPOpt/mixtureAdiabaticFlameT.o -L/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt \ -lspecie -lOpenFOAM -liberty -ldl -lm -o /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT /usr/bin/ld: warning: libPstream.so, needed by /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so, not found (try using -rpath or -rpath-link) /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `vtable for Foam::OPstream' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::waitRequests()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::~OPstream()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::IPstream(Foam::Pstream::commsTypes, int, int, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::exit(int)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::OPstream::write(Foam::Pstream::commsTypes, int, char const*, long)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::waitRequests()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::abort()' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::IPstream::read(Foam::Pstream::commsTypes, int, char*, long)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::init(int&, char**&)' /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: undefined reference to `Foam::Pstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)' collect2: ld returned 1 exit status make[2]: *** [/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/mixtureAdiabaticFlameT] Error 1 make[2]: Leaving directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical/mixtureAdiabaticFlameT' make[1]: *** [mixtureAdiabaticFlameT] Error 2 make[1]: Target `application' not remade because of errors. make[1]: Leaving directory `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/applications/utilities/thermophysical' make: *** [thermophysical] Error 2 make: Target `application' not remade because of errors. + '[' '' = doc ']' [e090012@bxfs1 OpenFOAM-1.6]$ |
March 23, 2010, 08:12 |
J. Cai
Rep Power: 17 |
Hi again, I found it is because mpi/libPstream.so is NOT complied successfully. But what a pity I have NO idea to solve it. Any suggestions are appreciated.
++ '[' FJMPI = MPI -o -d /opt/FJSVplang ']' ++ cd ParMetis-3.1 ++ WM_OPTIONS=linux64GccDPOptFJMPI ++ wmake libso METISLib linux64GccDPOptFJMPI/options:5: /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/wmake/rules/linux64Gcc/mplibFJMPI: No such file or directory make: *** No rule to make target `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/wmake/rules/linux64Gcc/mplibFJMPI'. Stop. wmake error: file 'Make/linux64GccDPOptFJMPI/objectFiles' could not be created ++ wmake libso ParMGridGen-1.0/MGridGen/IMlib '/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libIMlib.so' is up to date. ++ wmake libso ParMGridGen-1.0/MGridGen/Lib '/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libMGridGen.so' is up to date. + src/Allwmake + wmakePrintBuild -check no git description found + /bin/rm -f OpenFOAM/Make/linux64GccDPOpt/global.C OpenFOAM/Make/linux64GccDPOpt/global.o + wmakeLnInclude OpenFOAM + wmakeLnInclude OSspecific/POSIX + Pstream/Allwmake + wmake libso dummy '/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/dummy/libPstream.so' is up to date. + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers + WM_OPTIONS=linux64GccDPOptFJMPI + wmake libso mpi linux64GccDPOptFJMPI/options:5: /home/g2/e090012/OpenFOAM/OpenFOAM-1.6/wmake/rules/linux64Gcc/mplibFJMPI: No such file or directory make: *** No rule to make target `/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/wmake/rules/linux64Gcc/mplibFJMPI'. Stop. wmake error: file 'Make/linux64GccDPOptFJMPI/objectFiles' could not be created |
March 24, 2010, 03:26 |
#3 | |
Mark Olesen
Rep Power: 40 |
wmake/rules/SunOS64Gcc/mplibFJMPI If I look at settings.{csh,sh} it appears that the current FJMPI settings are specific for 'sparcv9'. You'll need appropriate values there, and also an appropriate wmake/rules/General/mplibFJMP |
March 24, 2010, 04:08 |
J. Cai
Rep Power: 17 |
Hi, Mark, thanks a lot for the reply.
I look through the file of wmake/rules/SunOS64Gcc/mplibFJMPI. I am afraid this time it is temporary out of my knowledge in the linux to revise a rule. The purpose I want to use the "/opt/FJSVplang/bin/mpiexec" embeded in the system is to do a parallel calculation with more than one node. I can use the ThirdParty/openmpi-1.3.3 well only within one node with less than 8 CPU cores. So I am trying to recompile the OF-1.6. But unfortunately... Any more suggestions. with best regards, Chiven |
March 24, 2010, 04:30 |
J. Cai
Rep Power: 17 |
Hi, Mark, again, you are right, the current FJMPI settings of OpenFOAM-1.6 is for the previous version of Fujitsu MPI. Now we are using a new system with new FJMPI version. The differences between the two versions are shown as follows.
・environment variable PATH(Previous version) /opt/FJSVmpi2/bin、 /opt/FSUNaprun/bin、 INSTALL/FSUNf90/bin ・environment variable(Previous version) LD_LIBRARY_PATH_64 /opt/FJSVmpi2/lib/sparcv9、 /opt/FSUNaprun/lib/sparcv9、 INSTALL/FSUNf90/lib/sparcv9 ・environment variable PATH(This version) /opt/FJSVmpi2/bin、 /opt/FJSVpnple/bin、 INSTALL/FSUNf90/bin ・environment variable(This version) LD_LIBRARY_PATH_64 /opt/FJSVmpi2/lib/sparcv9、 /opt/FJSVpnple/lib/sparcv9、 INSTALL/FSUNf90/lib/sparcv9 |
March 24, 2010, 05:20 |
#6 | |
Mark Olesen
Rep Power: 40 |
If you want to use a newer openmpi (eg, openmpi-1.4.1), you'll obviously need to recompile it and the src/Pstream as well, but shouldn't need to recompile everything. In general, however, it probably best to be using the 1.6.x version with the current bug fixes and other enhancements. |
March 24, 2010, 06:38 |
#7 | |
J. Cai
Rep Power: 17 |
However, if the more than 8 processors are need, 2 nodes or more should be used. This time, the parallel calculation of openmpi is not good (very slow). I am sorry for not clearly express. If you are interesting in it about the details, I can send the user manual to you. This time, I am wondering how to set the openmpi for the computer. And the administrator also only know the Fujitsu Job scheduler. |
March 30, 2010, 08:22 |
J. Cai
Rep Power: 17 |
Hi, I revised the settings.csh as follows.
case FJMPI: setenv MPI_ARCH_PATH /opt/FJSVmpi2 setenv FOAM_MPI_LIBBIN $FOAM_LIBBIN/mpi _foamAddPath $MPI_ARCH_PATH/bin _foamAddLib $MPI_ARCH_PATH/lib/sparcv9 _foamAddLib /opt/FJSVpnple/lib/sparcv9 _foamAddLib /opt/FJSVpnidt/lib breaksw Code:
PFLAGS = PINC = -I$(MPI_ARCH_PATH)/include/sparcv9/mpi -DMPIPP_H PLIBS = -L$(MPI_ARCH_PATH)/lib/sparcv9 -lmpi_f -L/opt/FJSVf90/lib/sparcv9 -lfjgmp64 -L/opt/FJSVpnidt/lib -lfjidt -ljrm -lfj90i -lfj90f -lfj90fmt -lelf ./Allwmake But I met the following errors. HTML Code:
+ Pstream/Allwmake + wmake libso dummy '/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/dummy/libPstream.so' is up to date. + case "$WM_MPLIB" in + set +x Note: ignore spurious warnings about missing mpicxx.h headers + WM_OPTIONS=linux64GccDPOptFJMPI + wmake libso mpi SOURCE=OPwrite.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/FJSVmpi2/include/sparcv9/mpi -DMPIPP_H -IlnInclude -I. -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/g2/e090012/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOptFJMPI/OPwrite.o OPwrite.C:30:17: error: mpi.h: No such file or directory OPwrite.C:38: error: 'MPI_Request' was not declared in this scope OPwrite.C:38: error: template argument 1 is invalid OPwrite.C:38: error: invalid type in declaration before ';' token OPwrite.C: In static member function 'static bool Foam::OPstream::write(Foam::Pstream::commsTypes, int, const char*, std::streamsize)': OPwrite.C:81: error: 'MPI_PACKED' was not declared in this scope OPwrite.C:84: error: 'MPI_COMM_WORLD' was not declared in this scope OPwrite.C:85: error: 'MPI_Bsend' was not declared in this scope OPwrite.C:93: error: 'MPI_PACKED' was not declared in this scope OPwrite.C:96: error: 'MPI_COMM_WORLD' was not declared in this scope OPwrite.C:97: error: 'MPI_Send' was not declared in this scope OPwrite.C:101: error: 'MPI_Request' was not declared in this scope OPwrite.C:101: error: expected `;' before 'request' OPwrite.C:107: error: 'MPI_PACKED' was not declared in this scope OPwrite.C:110: error: 'MPI_COMM_WORLD' was not declared in this scope OPwrite.C:111: error: 'request' was not declared in this scope OPwrite.C:112: error: 'MPI_Isend' was not declared in this scope OPwrite.C:114: error: request for member 'append' in 'OPstream_outstandingRequests_', which is of non-class type 'int' OPwrite.C: In static member function 'static void Foam::OPstream::waitRequests()': OPwrite.C:132: error: request for member 'size' in 'OPstream_outstandingRequests_', which is of non-class type 'int' OPwrite.C:138: error: request for member 'size' in 'OPstream_outstandingRequests_', which is of non-class type 'int' OPwrite.C:139: error: request for member 'begin' in 'OPstream_outstandingRequests_', which is of non-class type 'int' OPwrite.C:140: error: 'MPI_STATUSES_IGNORE' was not declared in this scope OPwrite.C:141: error: 'MPI_Waitall' was not declared in this scope OPwrite.C:150: error: request for member 'clear' in 'OPstream_outstandingRequests_', which is of non-class type 'int' OPwrite.C: In static member function 'static bool Foam::OPstream::finishedRequest(Foam::label)': OPwrite.C:157: error: request for member 'size' in 'OPstream_outstandingRequests_', which is of non-class type 'int' OPwrite.C:162: error: request for member 'size' in 'OPstream_outstandingRequests_', which is of non-class type 'int' OPwrite.C:170: error: invalid types 'int[const Foam::label]' for array subscript OPwrite.C:170: error: 'MPI_STATUS_IGNORE' was not declared in this scope OPwrite.C:170: error: 'MPI_Test' was not declared in this scope make: *** [Make/linux64GccDPOptFJMPI/OPwrite.o] Error 1 |
March 30, 2010, 08:49 |
#9 | |
Mark Olesen
Rep Power: 40 |
For example, Code:
find /opt/FJSVmpi2 -name mpi.h |
March 30, 2010, 09:41 |
#10 |
J. Cai
Rep Power: 17 |
March 30, 2010, 23:00 |
#11 |
J. Cai
Rep Power: 17 |
Hi, good morning, Mark, thank you for the comments. With your helps, I just make a big progress.
The settings.csh is revised as follows. Code:
case FJMPI: setenv MPI_ARCH_PATH /opt/FJSVplang setenv FOAM_MPI_LIBBIN $FOAM_LIBBIN/mpi _foamAddPath $MPI_ARCH_PATH/bin _foamAddPath /opt/FJSVpnple/bin _foamAddLib $MPI_ARCH_PATH/lib64 _foamAddLib /opt/FJSVpnidt/lib _foamAddLib /opt/FJSVpnple/lib breaksw Code:
PFLAGS = PINC = -I$(MPI_ARCH_PATH)/include64/mpi/fujitsu -DMPIPP_H PLIBS = -L$(MPI_ARCH_PATH)/lib64 -lmpi_f But when I try to run the cavity tutorial using icoFoam solver, I meet a problem: HTML Code:
icoFoam: symbol lookup error: /opt/FJSVplang/lib64/libmpi_f.so.3: undefined symbol: iargc_ Code:
PFLAGS = PINC = -I$(MPI_ARCH_PATH)/include/sparcv9/mpi -DMPIPP_H PLIBS = -L$(MPI_ARCH_PATH)/lib/sparcv9 -lmpi_f -L/opt/FSUNf90/lib/sparcv9 -lfjgmp64 -L/opt/FJSVpnidt/lib -lfjidt -ljrm -lfj90i -lfj90f -lfj90fmt -lelf |
March 31, 2010, 07:27 |
#12 |
J. Cai
Rep Power: 17 |
I have known the simple means of the parameters, such as -lfjgmp64, -lfjidt, -ljrm, etc. They are the abbreviated forms of the files under the directory. And I use FLMPI rule as,
PFLAGS = PINC = -I$(MPI_ARCH_PATH)/include64/mpi/fujitsu -DMPIPP_H PLIBS = -L$(MPI_ARCH_PATH)/lib64 -lmpi_f -lmpi_f++ -lmpi_f++_mt -lfjgmp64 -lfj90i -lfj90f -lfj90rt -lfjcrt -lelf -L/opt/FJSVpnple/lib -ljrm -lple -lplecf -L/opt/FJSVpnidt/lib -lfjidt HTML Code:
icoFoam: symbol lookup error: /opt/FJSVplang/lib64/libmpi_f.so.3: undefined symbol: iargc_ |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 07:05 |
DUNS compile with VC++, VF or gcc/g77 in PC | Ali Irvi | Main CFD Forum | 17 | August 6, 2014 10:19 |
Error compile file udf | czfluent | Fluent UDF and Scheme Programming | 24 | September 26, 2009 14:24 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 22:51 |
compile the UDF | Li Jingping | FLUENT | 2 | April 14, 2003 22:18 |
