[OpenFOAM.org] OpenFOAM 1.6.x Installer for Ubuntu |
August 30, 2010, 03:41 |
#141 |
Anton Kidess
Rep Power: 30 |
I'll do some testing on Wednesday to make sure things work with paraFoamSys. But if anyone stumbles upon problems please report back here.
April 21, 2011, 21:30 |
#142 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all! How time flies...
This post is an announcement that the old openfoam-ubuntu project has been moved to the new project page: nucleation We've had this intent since around June 2010, but only now did the opportunity present itself for the move to take place. For historic reasons, here is a quote from the current message on the front-page of http://code.google.com/p/openfoam-ubuntu/ : Quote:
Keep in mind that you don't have to contribute directly, since you can clone the repositories and work from there! Best regards, Bruno
March 30, 2015, 05:58 |
#143 |
Sergey Lesnik
Rep Power: 11 |
Hello all,
I'm new in this forum but after reading a lot of threads I'am already astonished how helpful the people here are. I hope the following information also helps someone =) My aim was to install OF 1.6.x on my Ubuntu 12.04, since I've got an old code which can be compiled only with this version. After this failed, I had also unsuccessful tries with Ubuntu 9.04, 10.04 and fresh installation of 12.04. Only after using the script supplied in this thread, I was able to install OF, QT and paraview on Ubuntu 10.04 (using virtual machine under Windows). There was only one problem: the link to the qt 4.3.5 is out-of-date. I used the experimental version of the original script since it was easier to change. Here is the fix: - open "installOFexp.sh" with any text editor - find the following line: QT_BASEURL="ftp://ftp.trolltech.com/qt/source/" - replace it with: QT_BASEURL="http://download.qt.io/archive/qt/4.3/" Then I ran the script with the following settings: 1. type "yes" 2. "ok" 3. installation path: "ok" 4. log file: "yes" 5. fresh install 6. here I used the options "1 Do apt-get upgrade" and "3 use startFoam alias" (I unchecked the option of using the gcc compiler since Ubuntu 10.04 has a newer version which worked fine) 7. here I used the options 1-custom Qt, 2-custom paraview, 3-paraview with GUI 8. nothing here to select Hopefully, this can save someone's time =) P.S. Thanks to everybody who made this script! |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 05:57 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Error compiling OpenFoam 1.6.x with intel compiler icc | mak_04 | OpenFOAM Installation | 5 | October 28, 2011 08:06 |
