[OpenFOAM.org] OpenFOAM 1.6.x Installer for Ubuntu |
June 25, 2010, 05:31 |
#121 |
Jesper
Rep Power: 16 |
Hi Bruno,
It worked! I just ran the new script without removing the downloaded thirdparty files and it went through smoothly. Fantastic :-) So far I've only tested the cavity case, and it seems ok. Thanks a lot. -Jesper |
June 25, 2010, 05:59 |
Help
#122 | |
Xiaoguang Yang
Rep Power: 16 |
I did as you requested.But failed. I attached the report. It seemed that the library was not right. I do not know how to solve it. Please help me. Thanks a lot. Best regards, xiaoguang Yang Executing /home/xiaoguang/OpenFOAM/OpenFOAM-1.6.x/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: xiaoguang-desktop OS: Linux version 2.6.31-22-generic-pae ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/xiaoguang/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/xiaoguang/OpenFOAM/xiaoguang-1.6.x no no $WM_THIRD_PARTY_DIR .../xiaoguang/OpenFOAM/ThirdParty-1.6.x yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/xiaoguang/OpenFOAM/OpenFOAM-1.6.x yes yes yes $FOAM_APPBIN ...1.6.x/applications/bin/linuxGccDPOpt yes yes yes $FOAM_SITE_APPBIN ...penFOAM/site/1.6.x/bin/linuxGccDPOpt no no $FOAM_USER_APPBIN ...1.6.x/applications/bin/linuxGccDPOpt no no $WM_DIR ...oguang/OpenFOAM/OpenFOAM-1.6.x/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...penFOAM/site/1.6.x/lib/linuxGccDPOpt no no $FOAM_USER_LIBBIN ...AM/xiaoguang-1.6.x/lib/linuxGccDPOpt no no $MPI_ARCH_PATH ...penmpi-1.3.3/platforms/linuxGccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.4.1 Minimum required: 4.3.1 gcc 4.4.1 /usr/bin/gcc gzip 1.3.12 /bin/gzip tar 1.22 /bin/tar icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/xiaoguang/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/icoFoam current path : CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
June 25, 2010, 06:08 |
#123 | |
Xiaoguang Yang
Rep Power: 16 |
Sorry, the report is too big. I attached the part containing 'error'. Best regards, xiaoguang Yang |
June 25, 2010, 07:34 |
I can't install OpenFOAM
#124 |
MAMERI Abdelbaki
Rep Power: 16 |
Hi all, i tried a several times to install openFOAM (my config is two Opteron dual core and 4Go ram). I always have critical, since i am new i can't resolve the problem alone.
when the installation finishes i got Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: baki-desktop OS: Linux version 2.6.31-22-generic ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/baki/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/baki/OpenFOAM/baki-1.6.x no no $WM_THIRD_PARTY_DIR /home/baki/OpenFOAM/ThirdParty-1.6.x yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/baki/OpenFOAM/OpenFOAM-1.6.x yes yes yes $FOAM_APPBIN ...1.6.x/applications/bin/linuxGccDPOpt yes yes yes $FOAM_SITE_APPBIN ...penFOAM/site/1.6.x/bin/linuxGccDPOpt no no $FOAM_USER_APPBIN ...1.6.x/applications/bin/linuxGccDPOpt no no $WM_DIR /home/baki/OpenFOAM/OpenFOAM-1.6.x/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt yes yes yes $FOAM_SITE_LIBBIN ...penFOAM/site/1.6.x/lib/linuxGccDPOpt no no $FOAM_USER_LIBBIN ...penFOAM/baki-1.6.x/lib/linuxGccDPOpt no no $MPI_ARCH_PATH ...penmpi-1.3.3/platforms/linuxGccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.3.3 ...OAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux/bin/gcc gzip 1.3.12 /bin/gzip tar 1.22 /bin/tar icoFoam 1.6.x .../OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. Please i need your help Thank you |
June 25, 2010, 07:51 |
#125 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Dear Xiaoguang,
tar -cjf make_log.tar.bz2 make.log As for MAMERI, welcome to the forum! And, uhm... your installation seems to have gone pretty well! Quote:
Best regards, Bruno
June 25, 2010, 14:34 |
no thing hapens
#126 |
MAMERI Abdelbaki
Rep Power: 16 |
Thank you for your reply,
when i try to startfoam i only have : baki@baki-desktop:~$ startFoam Building on 4 cores baki@baki-desktop:~$ and that's all, i expect the launch of OpenFoam?? Thank you |
June 25, 2010, 14:45 |
#127 | ||
Bruno Santos
Rep Power: 128 |
Greetings MAMERI,
Here is another information source, the Unofficial OpenFOAM Wiki: http://openfoamwiki.net There is a project under development named Discretizer that gives the GUI capability to interact with OpenFOAM: http://www.discretizer.org/ edit: By the way: Quote:
Best regards, Bruno
Last edited by wyldckat; June 25, 2010 at 14:48. Reason: Remembered about Jesper.. |
June 25, 2010, 17:23 |
#129 |
MAMERI Abdelbaki
Rep Power: 16 |
Hello all
I tried to execute my first case and that what i have : ERROR: In /home/baki/OpenFOAM/ThirdParty-1.6.x/paraview-3.6.1/VTK/Filtering/vtkExecutive.cxx, line 757 vtkCompositeDataPipeline (0x8dca8f8): Algorithm vtkPV3FoamReader(0x8d55d90) returned failure for request: vtkInformation (0x8dc6b28) Debug: Off Modified Time: 83308 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 Best regards |
June 25, 2010, 19:10 |
i resolved the problem
#130 |
MAMERI Abdelbaki
Rep Power: 16 |
Thanks to all
i resolved the problem |
June 28, 2010, 08:52 |
#131 | |
Xiaoguang Yang
Rep Power: 16 |
I solved the problem by installing binutils-2.19.1 in $HOME/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux. I was experiencing compatibility problems between gcc 4.3.3 and my system's default linker "/usr/bin/ld". Thank you anyway. I wish OpenFOAM-1.7 were installed easily. Best regards, Xiaoguang Yang |
June 28, 2010, 19:42 |
#132 | |
Bruno Santos
Rep Power: 128 |
Dear Xiaoguang Yang,
And as for OpenFOAM 1.7.x, we'll try to be up and running with it as soon as we can. Best regards, Bruno
July 3, 2010, 09:15 |
#133 |
Alistair Field
Rep Power: 16 |
Dear Bruno,
many thanks for the detailed replies you have always given. I ma new to OPENFoam and am tryign to install on UB 10.04...I have followed the instructions but have a critical error here: Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.3 User version : 4.4.3 Minimum required: 4.3.1 gcc 4.4.3 WARNING: Conflicting installations: OpenFOAM settings : /home/alistair/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.22 /bin/tar icoFoam 1.6.x .../OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. Having read through i see some similar comments, but I have no clue how to resolve the issue, or where to even start... Many thanks in advance Alistair |
July 3, 2010, 10:19 |
#134 | |
Bruno Santos
Rep Power: 128 |
Hi Alistair and welcome to the forum!
Honestly, that critical error can be considered a dud! In other words, even if the expected gcc version isn't the same as the one that was picked, apparently OpenFOAM was still built properly! Quote:
Now, the question is if you told the script to continue even if a critical error was found!? Because if you told it to continue, then you should have a fully working OpenFOAM and ParaView installation!! By the way, what options did you choose? Because it's a bit odd that OpenFOAM's gcc wasn't available to use... Best regards, Bruno
July 4, 2010, 14:33 |
#135 |
Alistair Field
Rep Power: 16 |
I followed the instructions on the following link...
http://www.cfd-online.com/Forums/ope...tml#post260591 but i did have one problem in that the return key was constantly being pressed (activated) during the install. So in the end im not sure what got accepted, changed on the way. Is there a file showing options chosen? thanks again.. |
July 4, 2010, 15:10 |
#136 |
Alistair Field
Rep Power: 16 |
i think i've got it.
I tried the startFoam command and got the following output. Warning in /home/alistair/OpenFOAM/OpenFOAM-1.6.x/etc/settings.sh: Cannot find /home/alistair/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux installation. Please install this compiler version or if you wish to use the system compiler, change the 'compilerInstall' setting to 'System' in this file so made the change and it just comes back with Building on 2 cores Thats seems fine... will now try some tutorials. Hopefully thats it. Cheers Alistair |
July 5, 2010, 18:48 |
#137 |
Bruno Santos
Rep Power: 128 |
Hi Alistair,
I'm glad you got the handle on OpenFOAM Now, hopefully your installation is fully working. The only reason that I can figure out right now for the problem you had, is that the patch responsible for "fixing" settings.sh no longer works with the latest version of OpenFOAM 1.6.x... probably due to an influence by the launch of 1.7.0. I'll try ASAP to run the install script again and figure out if there are any major changes that reflect my deduction! Otherwise, it might have been due to the strange lock of the Return key that you had. As for the file that shows the choices made... sadly there isn't one at the moment, but it's on the task list for a while now... Best regards, Bruno
August 28, 2010, 08:50 |
#138 |
Ben K
Rep Power: 19 |
Hi, I'm trying to install 1.6.x on a freshly installed Ubuntu 10.04 machine using the script. I keep getting an error saying that the MD5 checksum didn't work out for ThirdParty-1.6.General.gtgz. Is there a workaround for this?
--2010-08-28 07:41:07-- http://iweb.dl.sourceforge.net/project/foam/foam/1.6/ThirdParty-1.6.General.gtgz Resolving iweb.dl.sourceforge.net... 70.38.0.134 Connecting to iweb.dl.sourceforge.net|70.38.0.134|:80... connected. HTTP request sent, awaiting response... 416 Requested Range Not Satisfiable The file is already fully retrieved; nothing to do. Checking md5 checksum of file ThirdParty-1.6.General.gtgz ... grep: OFpackages.md5: No such file or directory md5sum: standard input: no properly formatted MD5 checksum lines found File is NOT OK. Getting the file 'ThirdParty-1.6.General.gtgz'seems to have failed for some reason. Do you want to try to download again? (yes or no): |
August 28, 2010, 12:26 |
#139 |
Bruno Santos
Rep Power: 128 |
Greetings Ben,
I'm so sorry, but since 1.7.0 was released, we no longer had any feedback for the script and I didn't check it in a clean installation I've just pushed a fix. You can download the script again and it won't need to download again those files you already downloaded! EDIT: I didn't check nor tested the push I made I've been taking care of a serious makeover for the script and I've been making changes on the 'stable' script without proper checks ASAP in the next few hours (8h50 UTC right now) I will push a fixed and tested version of the stable script! Once again, I'm very sorry for the inconvenience! Best regards, Bruno
August 28, 2010, 20:55 |
#140 |
Bruno Santos
Rep Power: 128 |
Greetings to All!
Ben: I've just finished testing the current version (at about 23h50 UTC) and it worked in Ubuntu 9.10 x86_64, including building Qt 4.3.5 and ParaView 3.6.1, just like it would in Ubuntu 10.04. I haven't tested Anton Kidess's new feature: the paraFoamSys script, which allows running the Ubuntu's ParaView or the official build 3.8.0 from www.paraview.org, depending on the options during installation. If someone can test the new features, please report back if it works or not! In the mean time, I'll try to check if it's working properly or not. Best regards, Bruno
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 05:57 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Error compiling OpenFoam 1.6.x with intel compiler icc | mak_04 | OpenFOAM Installation | 5 | October 28, 2011 08:06 |
