[OpenFOAM.org] OpenFOAM 1.6.x Installer for Ubuntu |
May 21, 2010, 05:24 |
Reinstall
#61 |
Rep Power: 17 |
Hi!
And thanks for the reply! I've tried to follow the steps but when I try to reinstall, the entire computer crashes (somewhere in the process, I don't know exactly where in the process since I'm away from the computer during the installation) . I think I will start over by erasing everything and then running the script again. This time marking the other alternatives of making paraView. It will take some time but I will report how it worked out when I'm finished. Lin, my graphic card is: ATI Mobility Radeon HD3650...i think that's the answer to your question. Oh, right. I'm using Ubuntu 10.04. Regards, Marco |
May 21, 2010, 11:40 |
#62 |
Rep Power: 17 |
Hi, Bruno.
That's me again Today I made a fresh installation of OpenFOAM 1.6.x on another pc (32-bit, Ubuntu 10.04 LTS), with the last stable version of your script (v. 0.9). I had a (just) Paraview building error, like in post #37. Just now I read about the very last version of the script: how can I fix the problem, without launching again the whole installation process? I attach my log files. Cheers, Maurizio PS I can't attach OF installation log file, it's too big. |
May 21, 2010, 12:00 |
#63 |
Anton Kidess
Rep Power: 30 |
For Maurizios problem, it looks like we are missing freeglut3-dev..
May 21, 2010, 12:07 |
#64 |
Rep Power: 17 |
What is freeglut3-dev? I have no idea about it
Can you help me, please? I'd like to fix the problem before office closing... |
May 21, 2010, 12:08 |
#65 | |
Anton Kidess
Rep Power: 30 |
Hehe. Personally I'd prefer not to patch the existing paraFoam but have two scripts. Otherwise we need a runtime option to select system or of-parafoam without reinstalling. But I guess that's just a matter of taste. I like the other ideas and will try to include them in the script when I find the time, but that's probably going to be in two weeks...
May 21, 2010, 12:09 |
#66 |
Anton Kidess
Rep Power: 30 |
Maurizio, freeglut is a part of the OpenGL library. Try "apt-get install freeglut3-dev", then rerunning the build script.
May 21, 2010, 12:17 |
#67 |
Rep Power: 17 |
Should I run the whole compiling process (OF, QT, etc.) - it takes hours - or maybe is it possible to run again only Paraview building with OF install script?
May 22, 2010, 17:23 |
#68 | |||
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all,
I know it would be possible to make paraFoam to use only one of them by default (if OpenFOAM ParaView version doesn't exist, and system's version exists, use foamToVTK+system ParaView), but that would limit the user to only one ParaView version. Quote:
The current experimental version (as of this writing) has the following capabilities, that the current stable script doesn't have: an additional option for custom building, which gives you access to building Qt, ParaView, Gcc, change the way the OpenFOAM environment is started (always or with startFoam), build ccm26ToFoam and code documentation... all of these, without (re)building OpenFOAM itself. This is to be used ONLY after at least one "fresh install" run has been fully completed, whether with or without success. In case you do need to rebuild OpenFOAM, you should run with the "update install" option (in the "Install mode" dialog). If the update option doesn't do the trick, it's because there is some object junk in the way, so run the following commands: Code:
cd $WM_PROJECT_DIR wcleanAll The experimental script still doesn't have the option for using Ubuntu's ParaView with foamToVTK. These changes haven't been pushed to the stable version, because... I haven't tested it completely and there are still some more tweaks needed to ensure a comfortable user experience Which will only be done when time is available to do so Has for ParaView locking up the machines, I'm going to try to investigate if the Mesa libraries can fully replace GPU-OpenGL, thus relying in CPU-OpenGL (independent of graphic cards), but it could be a long shot Edit: after an hour of research, I've figured out how to build ParaView with Mesa, but it require more time to implement than I have right now. It will be possible to directly link to Ubuntu's Mesa libraries, thus not requiring to do a custom build of the Mesa libraries. Best regards, Bruno
Last edited by wyldckat; May 22, 2010 at 18:29. Reason: Mesa issue: research complete... |
May 22, 2010, 22:34 |
#69 |
Rep Power: 17 |
Well, on monday I'll be your cavy
Since I think OpenFOAM, Gcc, Qt, etc. building was ok in my case and the problem was only in ParaView, I'm going to test the experimental script in order to build only Paraview. A newbie suggestion. This incredible and growing script is fantastic (above all) for not-so-linux-experts. For this reason, if you are going to include all these customing options, it should be better to have a little readme in order to explain the options, in simple words. Otherwise one could be puzzled (too many choices!). Thank you for your help, cheers. Maurizio |
May 23, 2010, 16:44 |
OpenFOAM 1.6 and Ubuntu V10.4 with gcc 4.4.3
#70 |
Rep Power: 16 |
Dear All,
Does anyone have any experience with running the script to install OpenFOAM 1.6 on Ubuntu 10.4 with gcc 4.4.3. I am doing a test run right now and in doing a tail -F on the install.log file, I only see references to gcc 4.3.3. I expect the worse followed by lots of fiddling about. i hope I am wrong. If anyone has any insight into this, I would appreciate your input. Impressive work with the script by the way. Regards, SDA |
May 24, 2010, 04:40 |
#71 |
Rep Power: 17 |
I ran installOF_exp script but something went wrong. Maybe I didn't set the right installation options:
- custom install mode - build ParaView with(out) Qt - build Paraview with GUI Then I tested the OpenFOAM installation by the cavity tutorial. When I run paraFoam I obtain: Code:
paraFoam: line 131: paraview: command not found |
May 24, 2010, 07:57 |
#72 |
Bruno Santos
Rep Power: 128 |
Greetings to all,
Maurizio, on the dialog that has "- build Paraview with GUI", you should have read more carefully the text It says right above it "Do custom build of ParaView ?". I know, it seems misleading, but you know how quoting only some specific sentences can be misleading without knowing the whole text, right? We haven't had time yet to write the FAQ in English, nor to write a tutorial on how to use the script and explaining each option. We've been more focused on getting the script "running to the max" and aiming to reach version 1.0. When we reach that stage, we will allocate more time to the docs SDA, it has crossed my mind a few times to add to the script the option to also build OpenFOAM 1.6, but since 1.6.x is the state-of-the-art version of OpenFOAM, we've focused our efforts on primarily making the script fully functional, and then start adding extras. And since OpenFOAM 1.7 is just two months away, it seems to me to be a "waste of precious time" to invest in old technology Best regards, Bruno
May 24, 2010, 08:19 |
#73 | |
Rep Power: 17 |
Hi, Bruno.
My english and linux understanding is not so good, so I don't think I can understand Quote:
About th FAQ, it was a suggestion for the (far) future. Your work is great and free, I know that Thanks for your help, cheers. Maurizio UPDATE It's all ok, now. It was probably enough the rebuilding of ParaView with the appropriate settings in the install script, but I got it and that matters to me. Thanks for your help again Last edited by vaina74; May 24, 2010 at 09:48. |
May 24, 2010, 11:00 |
#74 |
Bruno Santos
Rep Power: 128 |
I'm glad it's finally working! And you're welcome
May 24, 2010, 14:04 |
64 bit Ubuntu 10.04
#75 |
Rep Power: 17 |
Hi!
Now I've "upgraded" to 64 bit Ubuntu and ran the script but paraview doesn't want to work this time. Everything worked fine with the 32 bit installation but not in 64 bit. ------------------------------------------------------ Build ParaView: Build process didn't finished with success. Please check the log file for more information: /home/marco/OpenFOAM/ThirdParty-1.6.x/build_ParaView.log You can post it at this forum thread: http://www.cfd-online.com/Forums/ope...er-ubuntu.html You can also verify that thread for other people who might have had the same problems. ------------------------------------------------------ ------------------------------------------------------ ParaView isn't available where it is expected: /home/marco/OpenFOAM/ThirdParty-1.6.x/paraview-3.6.1/platforms/linux64Gcc/bin/paraview Therefore it isn't possible to proceed with building the plugin PV3FoamReader. ------------------------------------------------------ I attached the log file for this. By the way, it didn't work out the freezing problems for me before (in 32 bit Ubuntu 10.04). I suspect it is, as many already said, the graphics card (hardware problem/incompatibility). Regards Marco |
May 24, 2010, 14:22 |
#76 |
Bruno Santos
Rep Power: 128 |
Greetings Marco,
Can you test the experimental script (see post #68) to build again ParaView? Use the new "custom" option instead of the "fresh" install option, and try to build ParaView again, but this time without the "OSMesa" build option. OSMesa is useful only for off-screen rendering. Instructions here: Setting up a ParaView Server This option hasn't been fully tested yet, so as far as I know, it should work, but it might not work Best regards, Bruno
May 24, 2010, 17:22 |
#77 |
Rep Power: 17 |
Thanks alot Bruno!
Everything (!) is working fine for the moment. Even the freezing problem is gone! I don't know if it have anything to do about switching to 64 bit. Now, something strange happened, when I did NOT (not yet) update the drivers for my graphic card. Paraview worked fine. THEN, when I updated it I got segmentation error when trying to open paraview . After that I thought: "What the heck!" and "un-updated" my drivers and then tried to run paraview. Guess what happened, it worked! . I thinks that's very peculiar to say the least. Maybe a pure coincidence I don't know... Regards Marco |
May 25, 2010, 07:23 |
#78 |
Bruno Santos
Rep Power: 128 |
Hi Marco,
That's good news As for the drivers, I'm almost betting that if you'd had gone to the previous version of the drivers in the 32bit version, the same would have happened. The thing is, as far as I know, proprietary drivers like NVidia and ATI's, have one serious problem with their source code: they aren't even privately open (i.e., any changes by others would be automatically theirs), they are fully closed to the general public and when they release a new update, it's just as prone to error as GPL software, but has a tendency of taking far longer to be fixed. My assumption is that the team that works on the Windows version of the drivers is far larger than the team that works on the Linux version. Best regards, Bruno
May 25, 2010, 09:13 |
#79 | |
Anton Kidess
Rep Power: 30 |
I googled "OPENGL_INCLUDE_DIR (ADVANCED)" and the most likely answer was the missing freeglut package. No black magic here
I have the feeling using Mesa will be really slow so it might not even be that helpful. But it's worth trying if you find the time... - Anton Quote:
May 25, 2010, 10:06 |
#80 |
Fábio César Canesin
Rep Power: 16 |
Mesa is f***ing slow against OpenGL in rendering.. when you are dealing with small meshes and fields maps you don't notice it a lot but when you need an cluster almost the size of the compute-cluster just to post-process you start to understand why is a good design choice to include one rendering node in your farm... Has some LLVM work with translation GL whith a JIT for CPU rendering, using Gallium3D ... has some benchmark here : http://www.phoronix.com/scan.php?pag...llvmpipe&num=1
But, GPU will always be better for the job. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 05:57 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Error compiling OpenFoam 1.6.x with intel compiler icc | mak_04 | OpenFOAM Installation | 5 | October 28, 2011 08:06 |
