install openfoam in fedora
Like Tree1Likes
Old   March 1, 2010, 10:44
Gijsbert Wierink
gwierink is on a distinguished road
Fantastic Maysam! Well done!
Regards, Gijs
gwierink is offline   Reply With Quote
Old   March 2, 2010, 11:19
Default how to install the gcc-4.3.3 in the right place
  #22
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
please how to write the gcc-4.3.3 to the right place ?
and how to install it. when i do this command
$ export ~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/compile=~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/gcc-4.3.3
this appairs
bash: export: `~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/compile=~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/gcc-4.3.3': not a valid identifier
Ahmed Khattab is offline   Reply With Quote
Old   March 8, 2010, 20:12
Alex
bruxellois is on a distinguished road
Hi gwierink
I see that you are a professional in Linux and openfoam, please help me to install openfoam in fedora 11, i didn't understand anything i don't exaggerate if i say that my future depends help me plzzz. I downloaded all the files and i created the openfoam directory but I’m stopped there, how to install it and how to install the gcc I’m not good in Linux can you please write to me the codes step by step pleasssssse. I'm under fedora 64bit
Thanks a lot.
bruxellois is offline   Reply With Quote
Old   March 10, 2010, 04:06
Gijsbert Wierink
Hi guys,
@Ahmed:
Please read the post, it is explained above.
You don't need this. Are you trying to set the right environment variables? This is explained in this thread.
@Abdelhafidh:
Well, thank you, but I'm just a PhD student playing around with it a bit .
Have you followed the method higher up in this thread? That should do the trick.
Regards, Gijs
Old   April 19, 2010, 12:55
ahmed
Originally Posted by maysmech View Post
i find directories to paraview directory but not more because not same as your format!
/home/maysmech/OpenFOAM/ThirdParty-1.6/ParaView3.6.1
no it because you have removed it
rm -rf /$home/OpenFOAM/ThirdPArty-1.6/paraview-3.6.1/pltforms
Old   April 19, 2010, 14:30
ahmed
please can you explain the steps you done after downloading qt
Old   April 19, 2010, 14:33
ahmed
my problem was solved.
i update my Qt version by typing this command on terminal.
su -c 'yum update qt'
Now paraView works.
thank you dear Gijsbert.
Old   April 20, 2010, 07:16
Gijsbert Wierink
First, go to a convenient directory. In my case I make a directory containing all kinds of loose things, called "tmp" in my home dir). So, open up a terminal and
mkdir tmp && cd tmp
Now you're in your newly made tmp directory, get Qt-4.3.5
wget http://ftp3.ie.freebsd.org/pub/trolltech/pub/qt/source/qt-x11-opensource-src-4.3.5.tar.gz
Then, extract it
tar xzf qt-x11-opensource-src-4.3.5.tar.gz
Go into the inflated qt directory
cd qt-x11-opensource-src-4.3.5.tar.gz
and configure Qt for building by
./configure
Then, make Qt by
make
or
gmake
Finally, become root and actually install Qt
su
make install
or
gmake install
(you need to be root (su=superuser) to have write permission in /usr/, which is what you need when installing).
To get your system and OF find Qt, add its path to $HOME/.bashrc by
gedit $HOME/.bashrc
and add the lines
PATH=/home/gijsbert/tmp/qt-x11-opensource-src-4.3.5/bin:$PATH
export PATH
Save $HOME/.bashrc and source it by
. $HOME/.bashrc
(don't forget the dot (".") at the beginning).
Hope this helps you on your way .
Regards, Gijs
Old   April 20, 2010, 12:13
Unhappy paraview
  #29
ahmed
thanks for you
after i did that i tried to install paraview
cd /home/ahmed/OpenFOAM/ThirdParty-1.6
./makeParaView
Error: cannot find qmake either at $QMAKE_PATH or in current $PATH
what can i do
Old   April 20, 2010, 12:29
Gijsbert Wierink
Hmm, ok, what do
which qmake
and
qmake --version
say?
PS Just to be sure, you did add the Qt path (as above in this thread), source command for OpenFOAM to $HOME/.bashrc and source the latter, right?
Regards, Gijs
Old   April 21, 2010, 03:45
Lightbulb
  #31
maysmech's Avatar
maysmech is on a distinguished road
1111111111
maysmech is offline   Reply With Quote
Old   September 23, 2011, 11:35
M.Sanchez
MSAN is on a distinguished road
Hello
I am attempting to run OF on fedora 15 32 bits. I have built the sources as explained in the tutorial:
http://www.openfoam.com/download/source.php
but now, I have the same probleme as Rebel Ahmed, i.e:
when executing:
./makeParaView
the reply is:
Qt4 is already installed and up to date ...
my bash do not reconize the "qmake" command but there is a "qmake-qt4" command
I saw in the "makeParaView" file that I could change the qmake path but I am unable to locate it ...
If someone would help me ...
THX
M.
MSAN is offline   Reply With Quote
Old   September 23, 2011, 12:11
M.Sanchez
I found the answer by my own:
in a terminal:
whereis qmake-qt4
answer:
/usr/bin/qmake-qt4
then I edited the makeParaView file and replaced
QMAKE_PATH=""
by
QMAKE_PATH="/usr/bin/qmake-qt4"
ran
./makeParaView
and that was ok ...
/!\ On Fedora it is VERY IMPORTANT to run this before building ParaView!!!
sed -i -e 's=ptrdiff_t=std::ptrdiff_t='  ParaView-3.10.1/VTK/Utilities/vtkmetaio/metaUtils.cxx
maysmech likes this.
fedora, install, openfoam
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
Installation of OpenFOAM on Fedora 11 jits_aps90 OpenFOAM Installation 0 August 20, 2009 03:23
OpenFOAM Install problem masb OpenFOAM 3 May 25, 2009 12:32
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
