[OpenFOAM.com] OpenFOAM-1.6.x on 64 bit machine
Old   February 9, 2010, 16:42
Default OpenFOAM-1.6.x on 64 bit machine
Kyungrock Kim
Kr_kim is on a distinguished road
Dear Formers
git version for OpenFOAM-1.6.x is compiled successfully in 32 bit version
However, It's not compiled on 64 bit machine. I just followed the procedure below
http://openfoamwiki.net/index.php/Howto_install_OpenFOAM-1.6.x_(git_repository_version)
But I got a error below at the last step, ./Allwmake in OpenFOAM-1.6.x
./Allwmake
Error: Current directory in not $WM_PROJECT_DIR
The environment variable are not consistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
Do you have any idea for this problem?
Thanks in advance
Kyungrock
Kr_kim is offline   Reply With Quote
Old   February 11, 2010, 07:28
Retired Super Moderator
Bruno Santos
Greetings Kyungrock,
Please run the following command:
echo $WM_PROJECT_DIR
It will either output nothing or it will output a path that is different than the one your running ./Allwmake from. Usually $WM_PROJECT_DIR is $HOME/OpenFOAM/OpenFOAM-1.6.x for OpenFOAM-1.6.x ...
So, in can it does output something and is different from your installed path, then you can either edit the OpenFOAM-1.6.x/etc/bashrc script and adapt to your installation settings, or vice-versa, i.e., move or symbolically link your current set-up to the folder hierarchy defined in the bashrc script.
If the echo outputs nothing, than something is very wrong... because if you managed to build properly the ThirdParty tools, then how is it not allowing the building of OpenFOAM?
Best regards,
Bruno Santos
Old   February 12, 2010, 12:04
suitup is on a distinguished road
or just try the script from Mads, can be found here http://www.cfd-online.com/Forums/ope...-cookbook.html
should be the easiest way
good luck
suitup is offline   Reply With Quote
Old   February 12, 2010, 14:55
Kyungrock Kim
Thanks for the reply.
my output is /storage/kkim/OpenFOAM/OpenFOAM-1.6.x
It looks strange.
Best wishes
Kyungrock
Old   February 12, 2010, 14:56
Kyungrock Kim
Hi
In redhat linux case, will that way be availabe?
Thanks
Kyungrock
Old   August 22, 2016, 09:14
Default similar problem
Jenna Vergeynst
jenna is on a distinguished road
Best regards,
Bruno Santos
I've got the same error message with OpenFOAM-2.2.2 on Mac Ox X El Capitan, when sourcing the bashrc file. I think I built the ThirdParty tools, but echo outputs nothing in my case...
Any idea?
Thanks,
Jenna
jenna is offline   Reply With Quote
Old   August 24, 2016, 21:52
Bruno Santos
Quick questions:
  1. Which installation instructions are you following?
  2. What is the full path to where you have OpenFOAM's source code?
  3. What commands are you using for sourcing OpenFOAM's "etc/bashrc" file?
Old   August 25, 2016, 03:40
Jenna Vergeynst
1. Installation instructions: https://openfoamwiki.net/index.php/I...OpenFOAM_2.2.2
2. I had to create a sparse-image which is in my homefolder, and then created a symlink to this sparse-image, where I put the dowloaded source code.
3. Sourcing the bash/file was given to be following command:
. etc/bashrc
[OpenFOAM] view OpenFOAM result in ParaView on another machine base0 ParaView 0 November 12, 2015 20:29
OpenFOAM on a 32 bit machine samiam1000 OpenFOAM Installation 5 December 8, 2013 17:41
anyway to install 32 bit fortran on 64 bit machine HaKu Main CFD Forum 4 July 22, 2011 08:30
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 12:57
Random machine freezes when running several OpenFoam jobs simultaneously 2bias OpenFOAM Installation 5 July 2, 2010 08:40
