Please help: Installing OpenFOAM-1.5-dev on Ubuntu 9.04
Old   June 6, 2011, 11:50
Elvis
elvis will become famous soon enough
Hi Zeljko,
everything you want to do with 1.5-dev you should be able to do with 1.6-extend!
As 1.6-extend is the successor of 1.5-dev.
You can have more than one OF-installation on your computer.
Just make your .bashrc "multi-OF-installation-proof"
Your .bashrc should look like
alias startOF16ext='source ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc'
alias startOF171='source "what in the old 171 path was writen" '
by writing in your command-line
startOF16ext
or
startOF171
you can switch to the OF-installation you want to use. So you have capabilaties like GGI with 1.6-extend and the vanilla OF-1.7.1 as well.
elvis is offline   Reply With Quote
Old   July 16, 2011, 23:47
Santiago
gascortado is on a distinguished road
Hi. I have similar problems trying to install OF1.6-ext. After step #3, I get the following error at the tail of the log:
MGridGenGAMGAgglomerate.C:164: error: ‘MGridGen’ was not declared in this scope
make: *** [Make/linuxGccDPOpt/MGridGenGAMGAgglomerate.o] Error 1
+ wmake libso engine
/usr/bin/ld: cannot find -lfiniteVolume
collect2: ld returned 1 exit status
make: *** [/home/santiago/OpenFOAM/OpenFOAM-1.6-ext/lib/linuxGccDPOpt/libengine.so] Error 1
Any idea of what I need to do? I would appreciate any help. Thanks
gascortado is offline   Reply With Quote
Old   July 18, 2013, 02:45
Default install OF15dev
  #23
Arash Mahboubidoust
arashfluid is on a distinguished road
Send a message via Yahoo to arashfluid
Hi
I tried to install the openfoam-1.5-dev on ubuntu 10.04 and got the following: file:///C:/Users/Arash/Desktop/OpenFOAM%20on%20Your%20Own%20Laptop.htm
I get the following error after OF15dev:
bash: /home/arash/OpenFOAM/OpenFOAM-1.5-dev/etc/bashrc: line 188: syntax error near unexpected token '<<<'
'<<<<<<< .mine'
bashrc is attached.
arashfluid is offline   Reply With Quote
Old   July 21, 2013, 07:31
Retired Super Moderator
Bruno Santos
Greetings Arash,
Find this block of code in the attached file:
<<<<<<< .mine
    MACOSX_DEPLOYMENT_TARGET="10.4"
>>>>>>> .r1000
And replace it with:
This is very strange... which exact instructions are you following? Because the link you gave is pointing into your local copy of the instructions.
Best regards,
Bruno
installation, openfoam 1.5-dev
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
OpenFoam 1.6 Permissions in Ubuntu 9.04 AlanR OpenFOAM Installation 14 December 28, 2009 20:45
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 03:44
Problem installing OpenFOAM 1.5 installation on RHEL 4. vwsj84 OpenFOAM Installation 4 April 23, 2009 05:48
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
