OpenSuSE 11.2 installation
Old   January 5, 2010, 09:35
stephane sanchi
openfoam_user is on a distinguished road
Hi Alberto,
I run again foamInstallationTest and get :
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.3
User version : 4.4.1
Minimum required: 4.3.1
gcc 4.4.1
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/X11/gcc
CRITICAL ERROR
gzip 1.3.12 /usr/bin/X11/gzip
tar 1.21 /bin/tar
icoFoam 1.6.x ...penFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
So the installation seems OK.
But I can't run MRFSimpleFoam
Create time
Create mesh for time = 0
Reading field p
#0 Foam::error:rintStack(Foam::Ostream&) in "/shared/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
Segmentation fault
Regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   January 5, 2010, 12:18
Alberto Passalacqua
OK.
Did you rebuild everything with the system compiler? I have just run the MRFSimpleFoam tutorial successfully, and it seems we have the same system.
Best,
Alberto
Alberto Passalacqua
Old   January 5, 2010, 19:13
baernibaer
baernibaer is on a distinguished road
Hello @all,
same problem (Suse11.2&2.6.31.5-0.1-default&Kde4.3.1-32bit on 64bit system, git clone git://repo.or.cz/OpenFOAM-1.6.x.git) -> 1 critical gcc error ($WM_COMPILER_DIR))
(recompiled paraView and openmpi (yast2: software installed?) first)
until now this worked (...OpenFOAM-1.6/etc/settings.sh):
compilerBin=$WM_COMPILER_DIR/bin
compilerLib=$WM_COMPILER_DIR/lib$WM_COMPILER_LIB_ARCH:$WM_COMPILER_DIR/lib
System)
export WM_COMPILER_DIR="/usr"
esac
if [ -d "$compilerBin" ]
then
_foamAddPath $compilerBin
_foamAddLib $compilerLib
fi
just compiled ~/OpenFOAM/OpenFOAM-1.6/tutorials/incompressible/icoFoam/cavity
(could look at it with:
console:~/OpenFOAM/FOAM_RUN/tutorials/incompressible/icoFoam # icoFoam -case cavity
console:~/OpenFOAM/FOAM_RUN/tutorials/incompressible/icoFoam # paraview)
Thanks to Alberto and all supporters.
hopefully helpful,
Regards
bernhard
p.s. there is no "ThirdParty/cmake" folder anymore???
baernibaer is offline   Reply With Quote
Old   January 6, 2010, 03:17
stephane sanchi
I have run the tutorial mixerVessel2D without success.
Hereafter is the log.MRFSimpleFoam.
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-f3456b234025
Exec : MRFSimpleFoam
Date : Jan 06 2010
Time : 08:10:19
Host : cfs10
PID : 7929
Case : /shared/sanchi/mixerVessel2D
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Reading field p
I have always the same error message with the use of MRFSimpleFoam !!!
Regards,
Stephane.
Old   January 6, 2010, 12:03
stephane sanchi
to all people that have installed OpenFOAM-1.6.x with Linux 11.2
I am not able to run the MRFSimpleFoam solver.
I have the following error message when running the mixer 2D tutorial :
Date : Jan 06 2010
Time : 16:42:36
Host : cfs10
PID : 16108
nProcs : 1
Create time
Reading field p
Advices are welcome.
I need help to solve this problem.
Best regards,
Stephane
Old   January 8, 2010, 08:18
stephane sanchi
I discover the problem.
For OpenFOAM-1.6.x and OpenSUSE 11.2 I have to use the system compiler.
So I just have forgotten to recompile MRFSimpleFoam too.
cd ~/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/MRFSimpleFoam
wmake
and now MRFSimpleFoam works again.
Regards,
Stephane.
Old   January 8, 2010, 08:31
stephane sanchi
Following the steps of Alberto works fine for me (OpenFOAM-1.6.x and pvFoam).
http://albertopassalacqua.com/?p=532
Stephane
Installation problem in OpenSuse 11.1 oort OpenFOAM Installation 4 June 30, 2009 16:56
Critical errors during OpenFoam installation in OpenSuse 11.0 amscosta OpenFOAM 5 May 1, 2009 15:06
OpenFOAM 1.5 installation on OpenSUSE 11.0 bigphil OpenFOAM Installation 16 April 29, 2009 07:28
OpenFOAM 1.5-dev installation in OpenSuSe 10.3 darenyang OpenFOAM Installation 0 April 28, 2009 05:30
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
