Problem Installing OF 1.6 Ubuntu 9.10 (64 bit) - How to use GCC 4.4.1 |
October 1, 2011, 13:43 |
#41 |
Santiago
Rep Power: 16 |
Thanks a lot Bruno. You are the man.
I installed binutils-dev and I'm able to compile my own solver using wmake all. However, the groovyBC still giving me the same problem I just downloaded groovyBC from the wiki using: svn checkout https://openfoam-extend.svn.sourcefo...aries/groovyBC end then just hit wmake all or wmake libso and I get the same error each time. Any idea?? I'm almost there!... Thanks a lot Santiago |
October 1, 2011, 16:31 |
#42 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Santiago,
Mmm, this is odd. I've now tested on a virtual machine with Ubuntu 11.04 and both OpenFOAM 1.6.x and CAE-Team's OpenFOAM 1.6-ext. For 1.6-ext, I had to edit the general rules file: Code:
gksu gedit /usr/lib/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc/general Code:
CPP = cpp -traditional-cpp $(GFLAGS) Code:
wclean libso wmake libso Try the clean up and make once again like I've done. If you still have problems, run: Code:
wmake libso > gbcmake.log 2>&1 tar -czf gbcmake.log.tar.gz gbcmake.log Best regards, Bruno
October 3, 2011, 08:09 |
#43 |
Santiago
Rep Power: 16 |
Hi Bruno,
Thanks again. I re-downloaded the groovyBC files and when I hit wmake libso, everything is fine. Thanks very much for all of your help. Santiago |
November 10, 2011, 08:17 |
Installing Openfoam in ubuntu
#44 |
please help me out in installing openfoam in ubuntu. |
Problem installing OF 1.5 on Ubuntu 9.05 | smart | OpenFOAM Installation | 18 | August 10, 2009 20:12 |
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) | Mir5 | FLUENT | 3 | April 29, 2009 11:32 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 05:48 |
OF Installation Problem - Gcc Error | Daniel Pilatti | OpenFOAM Installation | 11 | April 19, 2009 23:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
