Can't run paraFoam with OpenFOAM 1.6
Old   October 28, 2009, 15:34
Default Can't run paraFoam with OpenFOAM 1.6
Nat
Fed11 is on a distinguished road
Hi Guys,
I installed OpenFoam 1.6 on Fedora 11_64. Everything went fine except when running paraFoam, where I have the following error: paraFoam
created temporary 'cavity.OpenFOAM'
/home/nat/OpenFOAM/OpenFOAM-1.6/bin/paraFoam: line 129: paraview: command not found
Anyone can help?
Thanks a lot
Nat
Fed11 is offline   Reply With Quote
Old   October 30, 2009, 20:54
Nat
Hi guys,
I finally got my previous problem resolved. In ThirdParty directory, the package cmake-2.6.4 was not there for me somehow
Now I have another problem with paraFoam: When I load ParaView 3.6.1 and play with it it seems fine until I hit some particular options and everything freezes, I can't access other windows and I can't even kill the process running (paraview-real) from other machines. The only option is to force the reboot!
Anyone experienced-resolved the problem?
Thanks
Nat
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 03:00
Setup OpenFOAM to run one two computers steps hsieh OpenFOAM Installation 12 February 12, 2011 05:44
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
problems with installing OpenFOAM 1.6 su_junwei OpenFOAM Installation 8 September 10, 2009 13:54
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 18:55
