Problems installin OpenFoam-1.5-dev in Ubuntu 8 |
September 18, 2009, 15:16 |
Teresa Margarida Mata
Rep Power: 17 |
Hi Foamers,
I am trying to install OpenFoam-1.5-dev in Ubuntu 8. I have downloaded the developer version from the svn repository, using the comand svn checkout <path of the version>. After that I downloaded the Third Party version from the OpenCFD website. I have decompressed both packages with no problems. I also made the changes in the .bashrc file settings.ch file, after some errors were reported by the foamInstalationCheck utility. Then, I tried to compile with no sucess. After analysing the errors, I identified some problems that terminate the compilation. 1- It looks like that flex is needed in order to perform the compilation. Am I right? I remenber when I compiled version 1.5 I did not need it, but, of course, versions are different. The error message that I got that made me think that is the following SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; flex --c++ -f $SOURCE ; mv lex.yy.cc Make/linuxGccDPOpt/readSTLASCII.C ; g++ -m32 -Dlinux -DDP -DFOAM_DEV_REVISION_NUMBER=1433 -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/titio/OpenFOAM/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/titio/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude -I/home/titio/OpenFOAM/OpenFOAM-1.5-dev/src/OSspecific/Unix/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/readSTLASCII.C -o Make/linuxGccDPOpt/readSTLASCII.o /bin/sh: flex: not found. Besides flew, what other software I need that is not included in the Third Party Software? 2 - I noticed that many of compilation commands failed because libraries, like for example libfiniteVolume.so, could not be found. I think this problem is due to the flex problem. A typical error of this kind is + wmake libso meshTools /usr/bin/ld: cannot find -ltriSurface collect2: ld returned 1 exit status make: *** [/home/titio/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libmeshTools.so] Error 1 Can anyone help me out here. I am reading other posts concerning but I can not figure out what is going on. Good weekend to all and thanks in advance, Teresa Mata |
September 19, 2009, 03:49 |
Gijsbert Wierink
Rep Power: 18 |
Hi Teresa,
1. The actual compilation of OpenFOAM needs some extra packages. Just look for and install the packages with "sudo apt-get" or Synaptic packege manager:
Hope this is of any help. Just post following errors (if you get any ). Regards, Gijs |
September 23, 2009, 10:50 |
Everything o.k
Everything compiled O.K, after four hours in my PC. Thanks, Teresa Mata |
[Commercial meshers] Boundary condition problems (OpenFOAM) | Milos | OpenFOAM Meshing & Mesh Conversion | 13 | October 13, 2016 19:58 |
OpenFOAM 1.5 installation on OpenSUSE 11.0 | bigphil | OpenFOAM Installation | 16 | April 29, 2009 06:28 |
Problems in representing convected derivatives in OpenFoam | titio | OpenFOAM Running, Solving & CFD | 1 | February 16, 2009 15:01 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
[General] OpenFoam - problems | MateuszZb | ParaView | 8 | July 21, 2008 16:16 |
