OpenFOAM-1.6 install cookbook
Like Tree1Likes
Old   November 24, 2009, 09:12
Xye
Xye is on a distinguished road
Originally Posted by akidess View Post
It's ok, no errors.
Great.
Can't seem to get the tutorials to work though. Not sure if its anything to do with the $FOAM_RUN part of the command that it tells you to do Here
Xye is offline   Reply With Quote
Old   November 24, 2009, 13:36
akidess's Avatar
Anton Kidess
It would help if you told us what the problems are you are having.
Old   November 25, 2009, 17:22
Default icofoam
  #123
wenc2 is on a distinguished road
Thanks for the script it's a great help. It solved most of the error I had. Still got one so. It looks like it's with "icoFoam"
If some now how to solve it It would be wonderfull
Third party software
Software Version   Location
gcc      4.3.3     ...OAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux/bin/gcc
gzip     1.3.12    /bin/gzip
tar      1.20      /bin/tar
icoFoam
WARNING:  Conflicting installations:
          OpenFOAM settings        : /home/wenceslas/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/icoFoam
          current path             :
          CRITICAL ERROR
wenc2 is offline   Reply With Quote
Old   November 26, 2009, 16:05
Default error when compiling
  #124
Achim
af631717 is on a distinguished road
i often used the skript and it always worked well even with Debian 5. But on one computer the following error message comes:
gcc -m32 -Wall -O3 -fPIC dirToString.c -o /home/timo/OpenFOAM/OpenFOAM-1.6.x/wmake/bin/linuxGcc/dirToString
flex wmkdep.l
gcc -m32 -Wall -O3 -fPIC lex.yy.c -o /home/timo/OpenFOAM/OpenFOAM-1.6.x/wmake/bin/linuxGcc/wmkdep
lex.yy.c:1393: warning: ‘yyunput’ defined but not used
lex.yy.c:1436: warning: ‘input’ defined but not used
wmkdep.l: In function ‘yy_scan_bytes’:
wmkdep.l:463: internal compiler error: Ungültiger Maschinenbefehl
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
make: *** [/home/timo/OpenFOAM/OpenFOAM-1.6.x/wmake/bin/linuxGcc/wmkdep] Fehler 1
++ '[' -n '' ']'
++ '[' -n '' ']'
++ '[' -n '' ']'
++ '[' -n '' ']'
++ '[' -n '' ']'
++ cd malloc
++ ./Allwmake
+ wmake libso hoard
/bin/sh: /home/timo/OpenFOAM/OpenFOAM-1.6.x/wmake/bin/linuxGcc/wmkdep: Datei oder Verzeichnis nicht gefunden
Any hints?
A.
af631717 is offline   Reply With Quote
Old   November 27, 2009, 01:33
akidess's Avatar
Anton Kidess
Achim, from what google tells me you might have a problem with your RAM.
Old   November 27, 2009, 04:04
Default Ram
  #126
Achim
Anton; thanks - will change the RAM
Achim
Old   November 28, 2009, 11:32
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Hi.
From the suggestions of Bruno above (thanks, man), I have changed the scripts to support Ubuntu 9.10. Actually I have scripts now for 9.04 and 9.10 separately (link in my signature).
I have just installed a fresh Ubuntu 9.10 64-bit from scratch and used the new scripts and they worked. Please let me know about any issues you might have, and I will upgrade.
/Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   November 29, 2009, 18:17
83_Ale_83's Avatar
Alessandro
83_Ale_83 is on a distinguished road
Hello guys,
I am a newbee of OpenFOAM, i am trying to install it on Ubuntu 9.10 x64 with the script, but when I type in terminal
cd OpenFOAM-1.6.x/
. ~/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc
The terminal close itself, if I re-open the terminal I got this message:
bash: /home/ale/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc: Nessun file o directory
Which is the problem?
With rRegards
Alessandro
83_Ale_83 is offline   Reply With Quote
Old   November 30, 2009, 03:27
MadsR's Avatar
Mads Reck
Hi Alessandro.
We might a bit more info. Is it a fresh install of 9.10? Is it when the script executes bashrc or when you (why?) do it? It should be added automatically to your .bashrc file so there shouldn't be any need for you executing it yourself.
/Mads
Old   November 30, 2009, 03:54
83_Ale_83's Avatar
Alessandro
It's not proper a fresh installation of Ubuntu 9.10 (I have update it and install the driver of my quadro video card and uninstall some useless programs (the gimp in example).
It happen when I copy-paste the script from your file to my terminal.
Maybe I have to reinstall a fresh ubuntu installation and the try, If could be usefull I have a dual boot system xp/9.10 and for 9.10 3 partitions: /,/home and swap.
Thank you
Alessandro
Old   November 30, 2009, 04:45
MadsR's Avatar
Mads Reck
What if you write (just to check if the installation is where it should be, and the bashrc of OpenFOAM is present):
ls ~/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc
/Mads
Old   November 30, 2009, 04:52
Default old Script worked with Ubuntu 9.10?!
  #132
Achim
on my netbook i used the old script and it worked!
Is it necessary to use the other libs?
The skript worked for Debian 5. Only the paraFoam does not work!
When you use the precompiled version with Lenny (Debian 5) then everything ist fine, but when you compile the 1.6.x, paraFoam does not work anymore - when you compile paraFoam again, it also does not work - strange!
A.
Old   November 30, 2009, 05:28
MadsR's Avatar
Mads Reck
Hi Achim.
Interesting. A couple of questions:
1) so the old script worked with Ubuntu 9.10?
2) was it the 32-bit version?
3) you mention Debian 5, what script did you use and did you experience other problems than the one with paraFoam?
4) do you have any error output from paraFoam?
/Mads
Old   November 30, 2009, 05:41
83_Ale_83's Avatar
Alessandro
/Mads
This is what the terminal show:
walk 7df9c9e09d67e226d1a409ef2dd141203701924f
walk b21a55baed3309240f84f3fc0ea91e5e41cd7277
ale@alien:~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64$ cd OpenFOAM-1.6.x/
ale@alien:~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/OpenFOAM-1.6.x$ . ~/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc
ale@alien:~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64/OpenFOAM-1.6.x$ ls ~/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc
ls: impossibile accedere a /home/ale/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc: Nessun file o directory
Old   November 30, 2009, 05:48
MadsR's Avatar
Mads Reck
Alessandro,
Wierd. It seems that you don't have the bashrc of OpenFOAM available at all...?
Show us the output of the following commands:
1. ls ~/OpenFOAM
2. ls ~/OpenFOAM/OpenFOAM-1.6.x
3. ls ~/OpenFOAM/OpenFOAM-1.6.x/etc
/Mads
Old   November 30, 2009, 06:11
Default Ubuntu + Debian questions
  #136
Achim
Hi Mads
yes, Acer Aspire Netbook with Remix Ubuntu 9.10 (Remix is especially for the netbook - only adapted GUI for the small LCD and Wireless Lan etc. All other things should be the same. Works perfect. Also ParaFoam works with a proper performance.
Intel Atom
Only paraFoam Reader has problems, compiling the 1.6.x was correct and work proberly.
It looks like the old problem that no reader is found as it occurred with OF1.5 when you had the wrong Qt libraries
One Error is in the new 32 Skript. There is no lib64 in the 32 ThirdParty package.
/Achim
Old   November 30, 2009, 06:29
MadsR's Avatar
Mads Reck
OK. So it seem to work on Debian 5 too.
Good call. linux64 changed in the new 9.10 script.
/Mads
Old   November 30, 2009, 06:38
83_Ale_83's Avatar
Alessandro
Alessandro,
1. ls ~/OpenFOAM
/Mads
ale@alien:~$ ls ~/OpenFOAM
ThirdParty-1.6 ThirdParty-1.6.General.gtgz ThirdParty-1.6.linux64Gcc.gtgz ThirdParty-1.6.x
ale@alien:~$ ls ~/OpenFOAM/OpenFOAM-1.6.x
ls: impossibile accedere a /home/ale/OpenFOAM/OpenFOAM-1.6.x: Nessun file o directory
ale@alien:~$ ls ~/OpenFOAM/OpenFOAM-1.6.x/etc
ls: impossibile accedere a /home/ale/OpenFOAM/OpenFOAM-1.6.x/etc: Nessun file o directory
ale@alien:~$
ale@alien:~$ ls
Documenti examples.desktop Immagini Modelli Musica nuovo file~ nuovo file.txt OpenFOAM Pubblici Scaricati Scrivania Video
Thank you for help me
Old   November 30, 2009, 06:59
Default Debian 5
  #139
Achim
1) Yes it seems to work with Debian but in fact in does not.
2) cd ~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/lib64
does not exist in that package -> there is something wrong in the script.
A.
Old   November 30, 2009, 07:32
83_Ale_83's Avatar
Alessandro
Maybe, and I say maybe, I have resolved my issue,
I have changed the git command
git clone git://repo.or.cz/OpenFOAM-1.6.x.git
to
then I type
cd OpenFOAM-1.6.x/
And it seems to have no problems, now I have started to compile with
./Allwmake >make.log 2>&1
I have a question for you /Mads, in your script :
At line 51 your script create a folder OpenFOAM-1.6.x, this folder must be in OpenFOAM folder to run after
cd OpenFOAM-1.6.x/
right?
Thank you
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 01:48
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 05:06
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 10:04
