OpenFOAM-1.6 install cookbook
Like Tree1Likes
Old   October 13, 2009, 16:51
Aurel is on a distinguished road
Hi Mads,
first of all I like to thank you for your "cookbook".
Brilliant!
I'm working on a 64-bit ubuntu 9.04 version.
After three attempts of installation it seems that I'm pretty close to a successful installation.
At the moment I've got still two critcal errors. As a newbie I'm a little helpless.
It would be very kind if you could give me an advise.
Attached find below a excerpt of the "Checking Installation Script".
Checking installation - you should see NO criticals...
Executing /home/aurel/OpenFOAM/OpenFOAM-1.6.x/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: aurel-desktop
OS: Linux version 2.6.28-15-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/aurel/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/aurel/OpenFOAM/aurel-1.6.x yes no
$WM_THIRD_PARTY_DIR /home/aurel/OpenFOAM/ThirdParty-1.6.x yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/aurel/OpenFOAM/OpenFOAM-1.6.x yes yes yes
$FOAM_APPBIN ...6.x/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN ...nFOAM/site/1.6.x/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...6.x/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR .../aurel/OpenFOAM/OpenFOAM-1.6.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.6.x/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...nFOAM/site/1.6.x/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...FOAM/aurel-1.6.x/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...nmpi-1.3.3/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.3
User version :
Minimum required: 4.3.1
gcc
WARNING: Conflicting installations:
OpenFOAM settings : /home/aurel/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam
OpenFOAM settings : /home/aurel/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
Regards
Aurel
Aurel is offline   Reply With Quote
Old   October 13, 2009, 23:49
Default Linux version and OF must be consistency
  #42
M. Li
cnlimin is on a distinguished road
Originally Posted by Aurel View Post
Hi Mads,
Brilliant!
Shell: bash
Host: aurel-desktop
User version :
gcc
CRITICAL ERROR
tar 1.20 /bin/tar
icoFoam
current path :
CRITICAL ERROR
Summary
done.
Regards
Aurel
Hi, Aurel,
I also met the same problem above when I install OF. the problem is resulted probably by the version disagreement between OF and Linux.
Suggest you carefully check the downloaded OF version (32 or 64 bit) and your installed Linux version (32 or 64 bit).
Good luck!!
Michael, Min LI
cnlimin is offline   Reply With Quote
Old   October 14, 2009, 03:20
Originally Posted by cnlimin View Post
Hi, Aurel,
Good luck!!
Michael, Min LI
Good morning Michael,
I'm working with Ubuntu 9.04 64-bit version and I used the 64-bit installation script of Mads. What did I wrong?
Regards
Aurel
Old   October 14, 2009, 03:36
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
I am glad you liked the script, although you are still facing some trouble. Let's get you pass that bump in the road.
I remember such error, and first thing that comes to my mind is that you may not have sourced the file
. ~/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc
Secondly, is the following link created:
ln -s ~/OpenFOAM/ThirdParty-1.6 ~/OpenFOAM/ThirdParty-1.6.x
Third (I could go on here :-)), are you positive, that Allwmake is successful? Try to run it again, and it will update whatever file is not compiled.
Let me know how it works out while I try to remember what this error is caused by. Maybe someone else remembers?
/Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   October 14, 2009, 05:04
Hi Mads,
the above listed bash commands are exactly the same like in your installation script. I see no difference at all. (only that: in the installation script behind the "ln -s" command are two blanks! could this be responsible for the error?)
I'm pretty sure that the "Allwmake" worked successfully. Compiling time took at least 3 hours. But this is probably no indication for a complete installation.
Anyway, in the evening I will try your suggestions.
Best regards
Aurel
/Mads[/QUOTE]
Old   October 14, 2009, 05:16
MadsR's Avatar
Mads Reck
They are the exact same commands but I have experienced that some times, when running the script by manually copying each line and inserting them into the command window, one tends to loose a line or a command is not recognised. It was just to make sure that didn't happen in your case.
The Allwmake can easily take more than 3 hours, depending on your hardware.
/Mads
Old   October 14, 2009, 13:39
luka is on a distinguished road
Hi MadsR,
Couple of questions regarding your cookbook. The thing is, I'm total Linux newb (downloaded Ubuntu 9.04 couple of hours ago) and it looks like I'm doing something wrong. I started your scipt in terminal (did c/p since didn't know better) and it started to "do its thing". The procedure didn't last as long as you said (all in all 20-30 mins. max), didn't get any errors (think). The problem is, I don't know where to start openFoam, so I suspected the script wasn't finished (but then again, I didn't get the message I would kill the process). Obviously I'm doing something wrong. If you have time, could you please give me step-by-step procedure for complete linux newb.
Thanks.
luka is offline   Reply With Quote
Old   October 15, 2009, 03:47
/Mads
Good morning Mads,
I did what you told me and it seems to work. There are still some "no's" in the checking installation script.
Is it neccessary that there are only "yes"?
Below find the checking installation print. What is your opinion? Does it look ok? Are there still some installation work neccessary?
Best regards
Aurel
Shell: bash
Host: aurel-desktop
gcc 4.3.3 ...M/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/bin/gcc
tar 1.20 /bin/tar
icoFoam 1.6.x ...penFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
Summary
Critical systems ok.
done.
: command not foundine 48:
aurel@aurel-desktop:~$
Old   October 15, 2009, 03:57
MadsR's Avatar
Mads Reck
Aurel: I have never seen ": command not foundine 48: " before. Apart from that, you should be fine. Does it work? :-)
Luka: what does c/p mean? :-) if it only took 30 minutes you either have a very fast computer or the script died somewhere. Try copying each line with the mouse and paste them into the command window, and see what happens at each command. This should work. Remember to be logged in as the user who are going to run OpenFOAM (that is not as root or anything else).
/Mads
Old   October 15, 2009, 05:27
/Mads
Hi Mads,
are there any test cases available for running the program to see previously if the system is working?
Do have a guidance about that?
I know that on the OF homepage are informations given.
Before I'm able to start my own case I have to learn to work with OF.
Best regards
Aurel
Old   October 15, 2009, 05:34
Jan
JanJ is on a distinguished road
Hi Mads
Thanks for the excelent script. Saved my butt in a tight spot... Worked perfectly!
The FORCE is still with you
/Jan
JanJ is offline   Reply With Quote
Old   October 15, 2009, 06:44
MadsR's Avatar
Mads Reck
Aurel: sure. The first thing you could try is just to type icoFoam. You will see either 1) command not found or 2) some output from OpenFOAM which states that it can't see any case to run. Secondly you should make a directory in your home folder and copy a simple cavity-test-case to it:
cd ~
mkdir myOpenFoamCases
cd myOpenFoamCases
cp -r ~/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/icoFoam/cavity .
cd cavity
blockMesh (generates a predefined mesh)
icoFoam (runs icofoam)
then use paraFoam to view the results.
Jan: Hi Jan! Happy to help you. Please keep me posted on your advances with OpenFOAM :-)
/Mads
Old   October 15, 2009, 16:13
Hi MadsR,
I followed your tips and it seems that every thing went fine (Base configuration ok.
Critical systems ok.). Thanks for the script. Rep point for you.
Old   October 15, 2009, 16:20
cd ~
cd myOpenFoamCases
cd cavity
/Mads
Hi Mads,
again thank you for your assistance.
1) icoFoam gave me an output.
2) I copied "cavity" in the directory /myOpenFoamCases
3) blockMesh gave following output
aurel@aurel-desktop:~/myOpenFoamCases/cavity$ blockMesh
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-99d4b831e6f2
Exec : blockMesh
Date : Oct 15 2009
Time : 21:10:24
Host : aurel-desktop
PID : 7486
Case : /home/aurel/myOpenFoamCases/cavity
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Creating block mesh from
"/home/aurel/myOpenFoamCases/cavity/constant/polyMesh/blockMeshDict"
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
Check block mesh topology
Basic statistics
Number of internal faces : 0
Number of boundary faces : 6
Number of defined boundary faces : 6
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating points with scale 0.1
Creating cells
Creating patches
Creating mesh from block mesh
Writing polyMesh
4) icoFoam gave following output for a lot time steps (the first time steps are listed below):
time step continuity errors : sum local = 9.45906e-09, global = -3.01342e-19, cumulative = 3.75172e-18
ExecutionTime = 0.13 s ClockTime = 0 s
Time = 0.275
Courant Number mean: 0.116922 max: 0.852131
DILUPBiCG: Solving for Ux, Initial residual = 2.29666e-06, Final residual = 2.29666e-06, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 4.82143e-06, Final residual = 4.82143e-06, No Iterations 0
DICPCG: Solving for p, Initial residual = 1.17435e-06, Final residual = 7.37825e-07, No Iterations 1
time step continuity errors : sum local = 8.44922e-09, global = 6.18731e-19, cumulative = 4.37045e-18
DICPCG: Solving for p, Initial residual = 1.03418e-06, Final residual = 6.73945e-07, No Iterations 1
time step continuity errors : sum local = 7.93654e-09, global = -1.09883e-18, cumulative = 3.27162e-18
Time = 0.28
DILUPBiCG: Solving for Ux, Initial residual = 2.15919e-06, Final residual = 2.15919e-06, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 4.5588e-06, Final residual = 4.5588e-06, No Iterations 0
DICPCG: Solving for p, Initial residual = 8.87539e-07, Final residual = 8.87539e-07, No Iterations 0
time step continuity errors : sum local = 9.6874e-09, global = 3.59741e-19, cumulative = 3.63136e-18
DICPCG: Solving for p, Initial residual = 1.11354e-06, Final residual = 7.94958e-07, No Iterations 1
time step continuity errors : sum local = 8.94508e-09, global = -8.45544e-19, cumulative = 2.78582e-18
.... and so on.5. paraFoam works, but I see no results!
Do you have an idea what did I wrong.
Best regards
Aurel
Old   October 15, 2009, 17:05
Default New to Openfoam
  #55
m.maneshi's Avatar
Mehdi
m.maneshi is on a distinguished road
any tips??
gzip: stdin: invalid compressed data--format violated
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
thx alot.
m.maneshi is offline   Reply With Quote
Old   October 16, 2009, 03:42
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
Hi, Mads.
I am installing on OF 1.6 on Ubuntu 9.04 64 bit using your 64 bit script. But I got some errors. Follow are some of them.
/lib/../lib64/libz.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libscotch.so] Error 1
/usr/bin/ld: cannot find -lscotch
make: *** [/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libdecompositionMethods.so] Error 1
/usr/bin/ld: cannot find -ldecompositionMethods
make: *** [/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libmeshTools.so] Error 1
/usr/bin/ld: cannot find -lmeshTools
make: *** [/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libfiniteVolume.so] Error 1
I think dado had similar problems. But he got them solved with the 64-bit script. Could you give me some advices?
Thanks.
Jin
JinBiao is offline   Reply With Quote
Old   October 16, 2009, 23:46
akidess's Avatar
Anton Kidess
Jin, looks like a problem with zlib. Manually execute sudo apt-get install zlib1g-dev and if that works try executing the script again. If not, post the error.
Old   October 17, 2009, 02:54
Jinbiao Xiong
Hi Akidess, thanks for the reply. I tried to execute your script to update the zlib. But it shows my zlib is the newest version.
And I am wondering whether the error is related to the hardware configuration of my computer. This computer has 16 CPU cores. The type is Intel Xeon CPU W5590. The operation system is Ubuntu 9.04.
Here I attach the details of the first error about zlib. It may provide some information about error.
SOURCE=library_error_exit.c ; gcc -m64 -Dlinux64 -DWM_DP -Wall -O3 -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DCOMMON_TIMING_OLD -DSCOTCH_RENAME -I../../include -DSCOTCH_VERSION=\""5.1"\" -IlnInclude -I. -I/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/library_error_exit.o
/usr/bin/ld: /lib/../lib64/libz.a(gzio.o): relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC
Thanks.
Jin
Old   October 17, 2009, 15:43
akidess's Avatar
Anton Kidess
Jin, this is definitely a software problem. Do you have the file OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libz.so? If so, try
export LD_LIBRARY_PATH=$HOME/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/:${LD_LIBRARY_PATH}
and then recompile with ./Allwmake.
This seems to be a problem with how the system zlib library was compiled. The installation script might have to be changed to accommodate for this...
Old   October 19, 2009, 00:31
Jinbiao Xiong
Akidess, I can not find the libz.so under the directory $HOME/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/. But there is a file libz.so.1.2.3.3 in /lib/. So I made a link $HOME/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libz.so directing to /lib/libz.so.1.2.3.3. It does work. I successfully compiled the libscotch.so.
But now I still have one error. It is caused by cmake. The error I got is as follows.
make[3]: Leaving directory `/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/postProcessing/graphics/PV3FoamReader/vtkPV3Foam'
+ cd PV3FoamReader
+ mkdir -p Make/linux64GccDPOpt
+ cd Make/linux64GccDPOpt
+ cmake ../..
./Allwmake: 1: cmake: not found
+ make
make[3]: Entering directory `/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/postProcessing/graphics/PV3FoamReader/PV3FoamReader/Make/linux64GccDPOpt'
make[3]: *** No targets specified and no makefile found. Stop.
make[3]: Leaving directory `/home/openfoam/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/postProcessing/graphics/PV3FoamReader/PV3FoamReader/Make/linux64GccDPOpt'
make[2]: *** [PV3FoamReader] Error 2
This lead to a failure to compile the applications.
However, when I test the installation with foamInstallationTest
I got:
done.
What should I do then?
Thanks.
Jin
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 01:48
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 05:06
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 10:04
