OpenFOAM-1.6 install cookbook
Like Tree1Likes
Old   September 23, 2009, 17:38
akidess's Avatar
Anton Kidess
What is the output of "echo $FOAM_APPBIN" and "which blockMesh"? If one of both doesn't give you a path, rerun foamInstallationTest and post the output.
Old   September 23, 2009, 17:54
gfilip is on a distinguished road
"which blockMesh" does not give an output. Here is the output of foamInstallationTest
Executing /home/greg/OpenFOAM/OpenFOAM-1.6.x/bin/foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               greg-laptop
OS:                 Linux version 2.6.24-24-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/greg/OpenFOAM                      yes       yes
$WM_PROJECT_USER_DIR /home/greg/OpenFOAM/greg-1.6.x           yes       no
$WM_THIRD_PARTY_DIR  /home/greg/OpenFOAM/ThirdParty-1.6.x     yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/greg/OpenFOAM/OpenFOAM-1.6.x       yes  yes  yes
$FOAM_APPBIN         ...1.6.x/applications/bin/linuxGccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    ...penFOAM/site/1.6.x/bin/linuxGccDPOpt  no        no
$FOAM_USER_APPBIN    ...1.6.x/applications/bin/linuxGccDPOpt  no        no
$WM_DIR              /home/greg/OpenFOAM/OpenFOAM-1.6.x/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...OAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    ...penFOAM/site/1.6.x/lib/linuxGccDPOpt  no        no
$FOAM_USER_LIBBIN    ...penFOAM/greg-1.6.x/lib/linuxGccDPOpt  no        no
$MPI_ARCH_PATH       ...penmpi-1.3.3/platforms/linuxGccDPOpt  yes  yes  yes
Third party software
Software Version   Location
gcc      4.3.3     ...OAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux/bin/gcc
gzip     1.3.12    /bin/gzip
tar      1.19      /bin/tar
icoFoam  1.6.x     .../OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/icoFoam
Summary
Base configuration ok.
Critical systems ok.
done.
And the output of the echo:
greg@greg-laptop:~$ echo $FOAM_APPBIN
/home/greg/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt
gfilip is offline   Reply With Quote
Old   September 23, 2009, 18:10
akidess's Avatar
Anton Kidess
Ok, so the paths and environment variables seem ok, but the binary is missing. I think something must have gone wrong during compiling. Go to /home/greg/OpenFOAM/OpenFOAM-1.6.x/applications/ and execute ./Allwmake. If that doesn't give any errors the binary should be there afterwards.
I'm using OF-1.5 but this should be the same for 1.6.x.
Old   September 23, 2009, 18:46
That managed to fix it. Thank you very much.
-Greg
Old   September 24, 2009, 02:55
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Great it worked out :-)
I guess I'll put such hints into the header of the script.
/Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   September 24, 2009, 14:28
akidess's Avatar
Anton Kidess
Oh by the way Mads, I just noticed you should make the script exit if an error occurs at any point; e.g. compiling doesn't make sense if the script bails at the git checkout for some reason.
Old   September 30, 2009, 06:14
MadsR's Avatar
Mads Reck
That's a great idea. Any hints as to how to do that :-)
/Mads
Old   September 30, 2009, 14:49
akidess's Avatar
Anton Kidess
set -e is probably the most straightforward way to make bash exit on errors. Just include that somewhere at the top of the script.
Old   October 1, 2009, 01:38
Phoevos
fivos is on a distinguished road
I have tried your script for the OpenFoam v1.6.x installation. In the end when the foamInstallationTest runs I get the following results:
Executing /home/fivos/OpenFOAM/OpenFOAM-1.6.x/bin/foamInstallationTest:
Shell:              bash
Host:               fivos-desktop
OS:                 Linux version 2.6.27-14-generic
$WM_PROJECT_INST_DIR /home/fivos/OpenFOAM                     yes       yes
$WM_PROJECT_USER_DIR /home/fivos/OpenFOAM/fivos-1.6.x         no        no
$WM_THIRD_PARTY_DIR  /home/fivos/OpenFOAM/ThirdParty-1.6.x    yes       yes
$WM_PROJECT_DIR      /home/fivos/OpenFOAM/OpenFOAM-1.6.x      yes  yes  yes
$FOAM_APPBIN         ...6.x/applications/bin/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    ...nFOAM/site/1.6.x/bin/linux64GccDPOpt  no        no
$FOAM_USER_APPBIN    ...6.x/applications/bin/linux64GccDPOpt  no        no
$WM_DIR              .../fivos/OpenFOAM/OpenFOAM-1.6.x/wmake  yes  yes  yes
$FOAM_LIBBIN         ...M/OpenFOAM-1.6.x/lib/linux64GccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    ...nFOAM/site/1.6.x/lib/linux64GccDPOpt  no        no
$FOAM_USER_LIBBIN    ...FOAM/fivos-1.6.x/lib/linux64GccDPOpt  no        no
$MPI_ARCH_PATH       ...nmpi-1.3.3/platforms/linux64GccDPOpt  yes  yes  yes
gcc      4.3.3     ...M/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/bin/gcc
tar      1.20      /bin/tar
icoFoam  1.6.x     ...penFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
Summary
done.
The result of $FOAM_APPBIN is :
fivos@fivos-desktop:~/OpenFOAM/OpenFOAM-1.6.x$ echo $FOAM_APPBIN
/home/fivos/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt
When I rerun the ./Allwmake, as akidess said, I get many
make[1]: Leaving directory `/home/fivos/OpenFOAM/OpenFOAM-1.6.x/applications/........'
And in the end :
make: Target `application' not remade because of errors.
(Also in the make.log there is the same thing)
However when I give the blockMesh, or checkMesh, icoFoam commands for example they are recognised.
So the questions are :
- Why do I get these 'no' at the foamInstallationTest, are these normal?
- Why there are errors during make in the applications folder?
Any help is appreciated.
PS : I forgot to mention I am using the 64 - bit script since I am using Ubuntu 8.10 64 bit.
fivos is offline   Reply With Quote
Old   October 1, 2009, 19:46
akidess's Avatar
Anton Kidess
Phoevos, my reply with ./Allwmake was very specific to gfilip's problem. Are you having the same problem? Why are you trying to recompile the applications directory? Nobody will be able to tell you why you are getting errors making the applications directory without knowing the errors (to my knowledge there are no psychics on the forum :P).
What makes you think your OpenFOAM installation isn't functional?
Old   October 2, 2009, 02:47
Phoevos
As far as I have tested OpenFOAM seems to work.
But why are these no's from the foamInstallationTest, is this normal?
As regards for the error during (re)build, I dont know why it was caused and I dont have any clue of what exactly is happening - I get this line (make: Target `application' not remade because of errors) at the end of the make.log after building all files, without any information about what these errors might be, or any more clues.
I have not been able to test OpenFOAM extensively, to make sure if it works or not. All commands, that I have tested till now work, so maybe there isnt any problem in the installation at all and these errors might be trivial for OpenFOAM's operation.
I apologise if my first message was vague, I believe that now I have made clear what bothers me.
Old   October 3, 2009, 07:06
Phoevos
After using OpenFOAM a bit, I believe that it is working normally. So ignore my previous messages.
Anyway thank you Madsr for your nice script!
Old   October 6, 2009, 21:17
Default hi
  #33
sarangarajan
sarajags_89 is on a distinguished road
~/OpenFOAM/OpenFOAM-1.6.x$ ./Allwmake >make.log 2>&1 I am getting stuck at this point.. does it take a long time for this step to complete?..thanks in advance.it is in the same step for more than 20 mins. is it normal? or shall I close it
sarajags_89 is offline   Reply With Quote
Old   October 7, 2009, 02:14
Dalibor
dado is on a distinguished road
It took more than 3 h on my computer to compile everything
dado is offline   Reply With Quote
Old   October 7, 2009, 15:23
MadsR's Avatar
Mads Reck
yeah, it can take 5-8 hours on a slow computer...
Old   October 7, 2009, 18:49
sarangarajan
hi it took 3hrs .. When I start paraview from the cavity case file I get the following msg " A reader for cavity.Openfoam could not be found" please select one of the following.
1.protein data bank files
plot 3d files
digital elevation map files
stereo lithography
gaussian cube files
raw(binary files)
pop ocean files
AVS UCD binary /ASCII files
SESAME
comma -separated grid files
MFIX unstructured grid files
fluent case files
openfoam files
cosmology files
Which one do i select
thanks in adv
cheers
sarang
Old   October 8, 2009, 03:58
bigred's Avatar
Matthew Philpott
bigred is on a distinguished road
plot 3d files
stereo lithography
gaussian cube files
raw(binary files)
pop ocean files
SESAME
fluent case files
openfoam files
cosmology files
thanks in adv
cheers
sarang
That would be my guess (the one in bold)
CAELinux 2009 + OF1.5
Ubuntu 9.04 x64 (jaunty jackalope) + OF1.6
bigred is offline   Reply With Quote
Old   October 8, 2009, 05:06
jugghead is on a distinguished road
Thanks for the script!
jugghead is offline   Reply With Quote
Old   October 8, 2009, 09:10
plot 3d files
stereo lithography
gaussian cube files
raw(binary files)
pop ocean files
SESAME
fluent case files
openfoam files
cosmology files
thanks in adv
cheers
sarang
Hi Sarang,
I had the same issue. All you have to do is compile the PV3 OF file reader (even though it is showing up on the list) through:
cd $FOAM_UTILITIES/postProcessing/graphics/PV3FoamReader
    ./Allwclean
    ./Allwmake
Hope it helps.
-Greg
Old   October 8, 2009, 09:17
M. Li
cnlimin is on a distinguished road
Originally Posted by MadsR View Post
Hi there.
I am not sure if this helps anyone, but for what it's worth, I thought I'd share how I install OpenFOAM on a fresh Ubuntu 9.04 system in a somewhat fool-proof way...By installing I mean real install with compiling, not "only" downloading of binaries.
I have previously spent quite some time, installing OpenFOAM, so I was trying to simplify and organise the process. I like to bake cakes, so I'll put it in a cookbook way if that's okay with you.
1. you need to have a Ubuntu 9.04 system running (or a similar apt-get enabled distro)
2. you need to be logged in as the user you want to be using OF as (not just using su)
3. you need to be allowed to run the sudo command
4. download my install-script found here
5. read through the script and see if you find anything upsetting (please notify me if you do)
6. either - for the not so faint-hearted - run the script "automatically" by typing . ./installOF OR manually copy-paste each line from the script to your command-line and execute, a bit safer, the installation process step-wise
7. you could bake a cake now, as step 6 probably will take a really long time
8. enjoy OpenFOAM, a cup of coffee and your cake
9. if everything above worked out, you can actually maintain your OpenFOAM install by typing git pull in the OpenFOAM-1.6.x-directory followed by ./Allwmake
The script is "verision 1.0" - please use this at your own risk and don't hold anything against me if your summer-vacation pictures are deleted (actually if this happens I really wonder how my script could have caused that )
Let me know if this is useless, or if it helps you out.
Cheers,
Mads
First, thank you very much for providing this script and I'm executed it on ubuntu 9.04 (32bit).
The installation of OpenFOAM1.6 is successful.
Thank you again!
cnlimin is offline   Reply With Quote
install OpenFoam 1.6 by building source: how? niudie OpenFOAM Installation 13 April 26, 2011 01:48
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
install openfoam 1.6 on opensuse 11.0 andresbh OpenFOAM Installation 8 September 30, 2009 01:48
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found fossy OpenFOAM Installation 1 August 28, 2009 05:06
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial potac OpenFOAM Installation 3 August 27, 2009 10:04
