June 3, 2010, 08:35 |
#361 |
Gareth
Rep Power: 16 |
http://code.google.com/p/openfoam-ubuntu
and then follwoed the instructions directly: $ wget http://openfoam-ubuntu.googlecode.com/hg/installOF.sh $ chmod +x installOF.sh $ ./installOF.sh Once the program to install started runnning i let it do its work After it was doen i read through the log file it seemed to have worked... |
June 3, 2010, 16:00 |
#362 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi bullmut,
That particular script has it's own thread for reports: http://www.cfd-online.com/Forums/ope...-ubuntu-5.html So please, if after the solution bellow, the installation is still not working, please post on that thread! Now, for the error you got: did you start a new terminal and run startFoam before running foamInstallationTest? If not, that's the problem! Best regards, Bruno
June 6, 2010, 11:24 |
error message while installing OF on an external hard drive with Ubuntu 9.10
#363 |
Suresh kumar Kannan
Rep Power: 17 |
Hello guys,
I am trying to install OF on a external hard drive on which i installed Ubuntu 9.10. I used the script from the install cookbook. I used the same script a few weeks before and it worked fine on another computer. But now I think there is a problem wiith the git. I recieved this message while running the script 2010-06-06 16:07:38 (7.52 MB/s) - `ThirdParty-1.6.linuxGcc.gtgz' saved [138472985/138472985] ------------------------------------------------------ Untarring - this takes a while... ------------------------------------------------------ FIX up for Ubuntu 9.10 Fix up done ------------------------------------------------------ Retrieveing OpenFOAM... ------------------------------------------------------ Initialized empty Git repository in /home/bernhard/OpenFOAM/OpenFOAM-1.6.x/.git/ fatal: http://repo.or.cz/r/OpenFOAM-1.6.x.git/info/refs download error - It says it is a download error. Is it a problem with the site or , with the script. Please clarify regards K.Suresh kumar |
June 7, 2010, 10:04 |
#364 | |
Bruno Santos
Rep Power: 128 |
Greetings Kumar,
Best regards, Bruno
June 7, 2010, 10:23 |
#365 |
Alessandro
Rep Power: 17 |
Now it works without problem, I have just update with git pull
June 7, 2010, 10:35 |
#366 |
Suresh kumar Kannan
Rep Power: 17 |
Thanks guys,
I just tried the script again and now the git has no problem. I guess it was a problem with the server. Now OpenFoam is compiling. I hope it compiles with no problem. Just one question do you think since I am compiling on an external hard drive, I will have some problems in using paraFoam. thanks again bye regards K.Suresh kumar |
June 13, 2010, 20:48 |
paraFoam, Segmentation Fault
#367 |
Subramanyam Natarajan
Rep Power: 16 |
I installed OF-1.6 on my Ubuntu 10.04. (Compaq Presario, Intel Centrino 1.6GHz, 1.2GB DDR, old, but works). I used this link : http://www.cfd-online.com/Forums/ope...okbook-19.html Took about 7 hours in total!! I tried to follow this tutorial, as I plan to learn OF from scratch : http://www.openfoam.com/docs/user/cavity.php When I issue the command, $ paraFoam or $ paraFoam -case $FOAM_RUN/tutorials/incompressible/icoFoam/cavity I get this error : created temporary 'cavity.OpenFOAM' QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No such file or directory QFileSystemWatcher: failed to add paths: /home/sn/.config/ibus/bus Bus:pen: Can not get ibus-daemon's address. IBusInputContext::createInputContext: no connection to ibus-daemon Segmentation fault I am a Linux newbie and looking forward for some help with this! Thanks! Subramanyam |
June 15, 2010, 04:44 |
Error with paraFoam
#368 |
Rickard Hidefjäll
Rep Power: 17 |
Hi !
I've used the http://openfoam-ubuntu.googlecode.com/hg/installOF.sh script several times with different parameters, and I also still get the same results as above: rickard@SkunkWorks:/Data/FlygFiler/Projekt20100612$ startFoam Building on 4 cores rickard@SkunkWorks:/Data/FlygFiler/Projekt20100612$ paraFoam created temporary 'Projekt20100612.OpenFOAM' QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No such file or directory QFileSystemWatcher: failed to add paths: /home/rickard/.config/ibus/bus Bus:pen: Can not get ibus-daemon's address. IBusInputContext::createInputContext: no connection to ibus-daemon Segmentation fault rickard@SkunkWorks:/Data/FlygFiler/Projekt20100612$ A new fresh Linux install has taken place twice with no differens in results. I think some thing has change sins 22/5 when the script was last updated. Or has anyone any hints about how to fix the problem? Regards Rickard |
June 15, 2010, 04:52 |
#369 | ||
Anton Kidess
Rep Power: 30 |
June 15, 2010, 04:54 |
#370 |
Rickard Hidefjäll
Rep Power: 17 |
Sorry! and thanks!
Regards Rickard |
June 20, 2010, 05:37 |
#371 |
Ovidiu Michiu
Rep Power: 16 |
hello there,
thk Mads for the cookbook. the installation went very well, but i have a small problem, or my be is a bug. after the installation, i run a tutorial and when i start the paraFoam to see the mesh, my paraview give me a white screen. when i start to move the mouse in the window where you can see the model, i was seeing the model but with frames; when i was stop moving the screen became white again. i modify the script from $OpenFOAM-1.6.x./bin/paraFoam by adding at the top,under the comment lines: export LC_ALL=C i start again the paraview and it has the same white screen, but after a few second close and give me this error: inginer@inginer-laptop:~/OpenFOAM/FOAM_RUN/tutorials/incompressible/icoFoam/cavity$ paraFoam created temporary 'cavity.OpenFOAM' X Error: GLXBadContextTag 172 Extension: 154 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x50006c3 X Error: GLXBadContextTag 172 Extension: 154 (Uknown extension) Minor opcode: 5 (Unknown request) Resource id: 0x500001c X Error: GLXBadContextTag 172 Extension: 154 (Uknown extension) Minor opcode: 1 (Unknown request) Resource id: 0x1 X Error: GLXBadContextTag 172 Extension: 154 (Uknown extension) Minor opcode: 117 (Unknown request) Resource id: 0x1 Segmentation fault inginer@inginer-laptop:~/OpenFOAM/FOAM_RUN/tutorials/incompressible/icoFoam/cavity$ PS: i have ubuntu 9.10, on 32 bits, (fresh install); also im new in linux and openFoam thk |
June 21, 2010, 19:14 |
#372 | |
Bruno Santos
Rep Power: 128 |
Hello again Ovidiu,
Wow, you may be new to Linux, but you've been trying different distributions for a while now OK, the issue you are getting is related to the graphics card drivers. If you trail back this thread, you should pick up on similar errors that others have had in the past and how they fixed it. The solution that I usually go for is to rebuild ParaView. For that, there are a few guides you could follow:
Best regards, Bruno
November 20, 2010, 12:57 |
Compiling OpenFOAM 1.6 on SGI machine
#373 |
n/a
Rep Power: 17 |
Wow, this was a pretty long thread. Since this thread pertains to cookbook for installing OpenFOAM 1.6, I am attempting to do so on an HPC machine, 64 bit and tcsh shell. Is there an install script that someone has developed that I can utilize? Thanks.
Deji |
install OpenFoam 1.6 by building source: how? | niudie | OpenFOAM Installation | 13 | April 26, 2011 01:48 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
install openfoam 1.6 on opensuse 11.0 | andresbh | OpenFOAM Installation | 8 | September 30, 2009 01:48 |
Install openFOAM 1.6 on debian 32bit - blockMesh: command not found | fossy | OpenFOAM Installation | 1 | August 28, 2009 05:06 |
Install of OpenFOAM 1.6 Error 1 Error 2 & run tutorial | potac | OpenFOAM Installation | 3 | August 27, 2009 10:04 |
