#21 |
Petri Sulasalmi
Rep Power: 17 ![]() |
Well it failed again. It started promising but when compiling Thermophysical utility it gave errors.
#22 |
P.A.
Hello linnemann,
does your CentOS-Package support Infiniband use? Where would I set this in case I need to compile it in? Thanks a lot! blaise |
#23 |
Niels Nielsen
Rep Power: 27 ![]() |
Hi
my package is the same as the standard OpenFOAM release the only difference is that I've included some extra stuff with regards to mesh generation and post processing. So you should be able to add infiniband as regular procedure. I've never done this as I'm not using infiniband, but I'm sure other people can help you here. Best regards Linnemann |
#24 |
Niels Nielsen
Well I found a stupid error in my way of sourcing the extra stuff.
instead of this export PATH=$PATH:$WM_THIRD_PARTY_DIR/gmsh-2.3.1/binIt should be written like this in the OpenFOAM bashrc file export PATH=$WM_THIRD_PARTY_DIR/gmsh-2.3.1/bin:$PATH |
#25 |
Petri Sulasalmi
more problems with OF. I'm trying to install OF under my own user name. I had it installed in /usr/local/OpenFOAM. I removed all of it with rm -rf /usr/local/OpenFOAM Then I installed OF under my user name. For some reason it doesn't update the environment variables and all of OF related variables still point to old directories. Any idea what is this about? Is there any way to remove everything that is related to the old installation? Regards, Petri |
#26 |
Petri Sulasalmi
I got it working. Restartin the computer did the trick for the environment variables
#27 |
Niels Nielsen
Hi
I have had similar problems and a reboot/logout seemed to solve the problem. Have no idea why the environment variables aren't updates Regards |
#28 |
Petri Sulasalmi
Well. Now it's working otherwise but paraFoam refuses to run. Gave the following error when I tried to post-process the Cavity tutorial:
/home/petri/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin/paraview-real: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory |
#29 |
Niels Nielsen
Hi
libssl should be a part of your CentOS installation so it seems weird it cant locate the library. do you have openssl installed? yum install openssl openssl-devel regards |
#30 |
Petri Sulasalmi
#31 |
Niels Nielsen
Hi
Then I have no idea why paraview complains. |
#32 |
Petri Sulasalmi
I got it working. I started from the beginning once again and now everything seems to be just fine.
#33 |
Niels Nielsen
UPDATE
the ThirdParty package now features gmsh 2.4.2 and Engrid svn-version Netgen has been added to the SF page as an extra stand-alone package. Install details is in the Netgen package. Regards
Linnemann PS. I do not do personal support, so please post in the forums. |
#34 |
Niels Nielsen
Hi everyone
I have started a wiki page for CentFOAM and created an install script which makes installation of the hosted files very easy. Go see for yourself and please try the install script and report your findings.
#35 | |
Joaquín J. Correa
Rep Power: 16 ![]() |
http://www.cfd-online.com/Forums/ope...entos-4-x.html Regards. |
#36 |
Robert Castilla
Hi, I have to install the last version of OpenFOAM in a Red Hat 32 bits. I have had a lot of problems with compilation and I wonder if there is an easy way to do that with binaries.
Thanks |
#37 |
Vishal Jambhekar
Will it be the same procedure for OpenFOAM-1.7.1. Coz when i have downloded i could not find and of the additional tools like gmesh, engrid, meshlab in thirdparty folder.
I gueess we need to put unzipped folder in Third party directory. Though it sounds little silly question need to get it cleared for further process.....
Cheers, Vishal Jambhekar... ![]() "Simulate the way ahead......!!!" |
#38 | |
Manoj L Das
Rep Power: 15 ![]() |
Hi Niels Nielsen,In the above method, the links"OpenFOAM-1.6.x_CentOS-5.3_x86-64.tar.gz and ThirdParty-1.6.x_CentOS-5.3_x86-64.tar.gz",in step 3 doesn't contain any file named "OpenFOAM-1.6.x_CentOS-5.3_x86-64.tar.gz" and"ThirdParty-1.6.x_CentOS-5.3_x86-64.tar.gz". Also both the above links directs to the same location where three different folder are there (Non-Essential, 6.x and OpenFOAM). Could you plese guide me which one to download or where I can get the files named "OpenFOAM-1.6.x_CentOS-5.3_x86-64.tar.gz" and"ThirdParty-1.6.x_CentOS-5.3_x86-64.tar.gz". Also the mechine where I have to compile the CentFOAM is not connected to the internet. And it has RHEL 5.3 with gcc 4.1.x version, and It is not registerd with the RHN. so, yum installer is also not working. In such circumstance could you please suggest any alternative for setting the required environment for CentFOAM install. On one of the Linux forum, I had seen a procedure to convert RHEL5.x in to CentOS, which does't require RHN registration to use yum installer, but I am not sure, by doing that will serve my purpose, And don't know whether by converting RHEL to CentOS will not affect the other other installations? Please help me out. With Best Regards, MLD |
#39 |
Manoj L Das
Hi Niels Nielsen,
#40 |
Niels Nielsen
Hi Manoj
Go here instead. I have changed the install process since that description. https://sourceforge.net/apps/mediawi...itle=Main_Page If you need the packages for RHEL you can mix and match from CentOS and SL, they are all built using the same source packages. So to install manually go here f.ex. http://ftp.hosteurope.de/mirror/cent...x86_64/CentOS/ Search for the packages you need, download it and install with rpm -Uvh nameOfPackage.rpm It might complain that it needs some dependency package to install so search for those as well and install them before the other. You can also convert to CentOS but for the small number of packages you need for centFOAM I would just download them manually. Best Niels
1.6.x, centos, openfoam |
OpenFOAM 1.6 package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 36 | September 2, 2009 12:46 |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 03:14 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
OpenFOAM 15 and CentOS 52 installation issues | remrich | OpenFOAM Bugs | 9 | March 20, 2009 01:48 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
