OpenFOAM 1.6 package - CentOS 5.3 x86_64
Old   July 30, 2009, 08:58
Default OpenFOAM 1.6 package - CentOS 5.3 x86_64
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hello Foamers
Here is a prepackaged/precompiled version of OpenFOAM-1.6 and Paraview-3.6.1. Some extra mesh related programs have been put in the Thirdparty package.
All built from source, no prepackaged binaries, so optimal speed for CentOS.
The Thirdparty folder have been striped for any source-code and only the binary/lib files are remaining.
---------------- Included ----------------
- OpenFOAM 1.6 (flex, mpfr and gmp built from source)
- Paraview 3.6.1, Mpi support, ffmpeg support (export to avi), and parallezied support for decomposed cases.
- gmsh-2.3.1
- engrid-1.0.1
- meshlab-1.2.1
---------------- Install Instructions for the whole package ----------------
0. First you need to install gcc, c++, bison and ncurses-devel, which is shipped with CentOS 5.3 - (needed to compile/recompile OpenFOAM solvers, or your own solvers)
yum install gcc gcc-c++ bison ncurses-devel
1. Next steps are all done as root
2. Create a folder for OpenFOAM, the default in the bashrc is /usr/loal/OpenFOAM
mkdir /usr/local/OpenFOAM
3. unpack the content of OpenFOAM-1.6_CentOS-5.3_x86-64.tar.gz and ThirdParty-1.6_CentOS-5.3_x86-64.tar.gz to the folder
cd /usr/loal/OpenFOAM
tar -xvf /pathtothedownload/OpenFOAM-1.6_CentOS-5.3_x86-64.tar.gz
tar -xvf /pathtothedownload/ThirdParty-1.6_CentOS-5.3_x86-64.tar.gz
4. Fix any possibly wrong permissions
chmod -R 755 /usr/local/OpenFOAM
5. Next part is done as non-root (user)
6. Put this line in your .bashrc file.
. /usr/local/OpenFOAM/OpenFOAM-1.6/etc/bashrc
restart console or source the bashrc $ . ~/.bashrc
to check if it works try
$ which gcc
this should output the following
$ /usr/local/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/gcc
The Qt-4.5.2.tar.gz and vtk-5.4.2.tar.gz, in the non-essential folder at sourceforge, are extras, which is only needed if you consider recompiling paraview, or some other app which depends on Qt/vtk.
It is possible to install to another location other than /usr/local, all you have to do is to modify you own .bashrc file, the bashrc in OpenFOAM (/usr/local/OpenFOAM/OpenFOAM-1.6/etc/bashrc) to point to the new location of the install like in the regular OpenFOAM README.
---------------- Disclaimer ----------------
The package has been verified on a fresh minimal gnome install of CentOS 5.3 64bit
The package is "as is" and can only be guaranteed to work with a 64bit version of CentOS/RedHat/Scientific 5.3 (yum update is fine). Or if in a cluster environment Rocks 5.2 (based on CentOS 5.3).
If other distributions are used, I can't help you.
---------------- Download ----------------
I have made a sourceforge project for this which can be found at
https://sourceforge.net/projects/centfoam/
---------------- BUGS ----------------
User wesoe reported an issue where the geometry is not shown, Takuya proposed putting the following into your .bashrc or run the command before paraFoam is run.
export LC_ALL=C
This is apparently a locale issue
An error related to paraview, if its not installed in /usr/local/OpenFOAM do this as root.
mkdir /pathtoopenfoam/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/lib
ln -s /pathtoopenfoam/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/bin /pathtoopenfoam/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/lib/paraview-3.6
Last edited by linnemann; August 25, 2009 at 12:29. Reason: New file structure and packaging
linnemann is offline   Reply With Quote
Old   August 3, 2009, 06:51
Angus Lock
lockan is on a distinguished road
Does this include a parallel version of ParaView?
Thanks for your help.
Angus
lockan is offline   Reply With Quote
Old   August 3, 2009, 07:38
linnemann's Avatar
Niels Nielsen
Hi
Yes, forgot to mention, it is built with the OpenFOAM shipped version of openmpi.
The only extra I put in is the possibility to read decomposed cases.
you can still use the paraFoam command, but this will only work on reconstructed cases as far as I know.
Regards
Old   August 3, 2009, 19:20
Default Packages
Dr. Eric Warren
downforce is on a distinguished road
Can you provide access to the packages other than through depositfiles where you have to pay to download them (unless you want to wait 2 hours between downloads)?
downforce is offline   Reply With Quote
Old   August 4, 2009, 02:40
linnemann's Avatar
Niels Nielsen
Hey,
I have tried many places, but I haven't found a decent place for it yet.
I will try to see if i can create a sourceforge project for it, but I cant promise anything.
If you don't want to wait 2 hours try the torrent.
Regards
Old   August 4, 2009, 11:12
Dr. Eric Warren
With regards to the Qt package, do you unpack it as well in the /usr/local directory? i assume then that if so that /usr/local/Qt-4.5.2 would need to be added to your path...
Old   August 4, 2009, 11:23
Dr. Eric Warren
Got everything downloaded from the torrent and installed and works great thank you. Saved me a lot of time...
Old   August 4, 2009, 12:29
linnemann's Avatar
Niels Nielsen
Hi
Yes you would need to add Qt to your PATH, but it is not needed to run the binary pack.
It is only provided to those who would want a precompiled Qt-4.5.2 for their CentOS install.
Regards
Old   August 6, 2009, 02:46
linnemann's Avatar
Niels Nielsen
I have made a sourceforge project for this and future packages at
Regards
Old   August 7, 2009, 12:28
Soeren Werner
wersoe is on a distinguished road
Great work linnemann...
If you need any help in the future, I am not actually an expert in compiling stuff, anyway, I d like to support the project...
Regards, Sören
wersoe is offline   Reply With Quote
Old   August 7, 2009, 13:11
Soeren Werner
...well, just downloaded, unpacked OpenFOAM.tar.gz to /opt/OpenFOAM and run the icoFoam/cavity.
So, blockMesh and icoFoam run without error, paraFoam opens Paraview, however, I cant see the cavity file. The statistics options gives the correct cell number, but the display remains grey...
Has anybody something similar and could give me a hint?
Would appreciate very much, thanks
Sören
Old   August 8, 2009, 07:16
linnemann's Avatar
Niels Nielsen
You need to choose some scalar which you want to show in the top.
First you need to use the arrows on top to get to the last time-step/iteration.
Then under display you can choose which scalar/property you want to show and you properly also have to rescale it using one of the first icons on the second row of the toolbar
Old   August 8, 2009, 07:18
linnemann's Avatar
Niels Nielsen
I have restructured the files and added some extra mesh packages in the Thirdparty folder so from now on It will only be possible to download from the sourceforge project page
Old   August 8, 2009, 08:02
Soeren Werner
Hello linnemann,
thanks for your reply.
However, I have set all rite, so I think, couldnt see anything anyway.
The color scale is visible, but the geometry isnt...
One other thing, the time scale is not correct, since cavity is calculated up to 0.5s with step size of 0.01.
Something is really wrong, and I couldnt see it.
I will try at another system now, I get back with results...
Anyway, help is much appreciated.
Thanks, Sören
File Type: jpg Bildschirmfoto-Kitware ParaView 3.6.1 .jpg (43.2 KB, 9 views)
Old   August 8, 2009, 09:01
Takuya OSHIMA
7islands is on a distinguished road
Hi Sören,
I guess your ParaView (PV3FoamReader) is affected by a problem which is reportedly occurs only when ParaView built with Qt 4.5.x is run under certain locales [1]. Try running paraFoam after running "export LC_ALL=C". If it works, write the "export LC_ALL=C" line into somewhere in the paraFoam script for later convenience.
[1] See comments #55-#72 in a Gentoo tracker thread. The thread discusses the parallel reader under Gentoo but I know that the same thing applies to PV3FoamReader and other distros as well.
p.s. @linnemann: thanks about including the parallel reader!
Takuya
7islands is offline   Reply With Quote
Old   August 8, 2009, 09:23
Soeren Werner
Hi Takuya,
thanks for help. After exporting the variable, paraFoam works...
@linnemann, maybe you can bring the workaround to your installation instructions, since there are probably some German users out there...
Regards, Sören
Old   August 8, 2009, 09:31
linnemann's Avatar
Niels Nielsen
Fix have been included in the installation instructions.
Regards
Old   August 8, 2009, 11:59
Soeren Werner
edited by wersoe
Old   August 8, 2009, 15:42
linnemann's Avatar
Niels Nielsen
well I found an error related to paraview, apparently there needs to be a symlink to a folder, if its not installed in /usr/local/OpenFOAM do this as root.
Old   August 16, 2009, 18:46
Jean-Peer Lorenz
jploz is on a distinguished road
@7islands: Do you know whether this 'export LC_ALL=C' bug is reported somewhere, so it can be fixed in the sources?
Regards.
jploz is offline   Reply With Quote
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 04:14
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 18:55
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
