March 22, 2010, 04:44 |
#121 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Can't comment on the rest, as I don't use that patch Bernhard |
March 23, 2010, 09:10 |
Paraview Help..! /2/
#122 |
Daniele Trimarchi
Rep Power: 16 |
Hi Bernard, thank you for your reply. Unfortunately it does not seems to be working. So I might ask you, reading your answer, how did you manage to have paraview working? I'll be happy to follow any other procedure, if it solves the problem!
I also have the precompiled version of Paraview, which works, but crashes when reading OpenFOAM files. Thank you, Daniele |
March 23, 2010, 11:26 |
#123 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard makeParaViewMacBG.gz |
March 31, 2010, 08:55 |
#124 |
Wouldn't it be nice if someone of you uploaded the compiled version of OpenFoam? I could give you some space on my virtual hd…
June 18, 2010, 06:50 |
#125 | |
José Rodrigues
Rep Power: 16 |
I'm getting the same error as Elvis (as quoted) and I can't get around it. I started the endeavor of build OF and paraview this week and so my knowledge on this building and compiling is still a bit fuzzy. So, I have a couple of questions for you guys: 1) - Isn't it possible to use one of the builds of paraview already supplied by Kitware on this site http://www.paraview.org/paraview/res.../software.html and some how link it to the OpenFOAM reader? They work nicely on mac OS 10.6 but I can't get it linked to the OF reader. Any thoughts in this? 2) - I tried to run the ./makeParaView to compile a different version of ParaView (3.8.0 instead of 3.6.1) simply by changing the version variable on the /WM_PROJECT_DIR/etc/apps/paraview3/bashrc but with no success. It kept sending this error: -QMAKESPEC has not been set, so configuration cannot be deduced. and then CMake Error in Applications/ParaView/CMakeLists.txt: Cannot find source file "classes.nib". Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp .hxx .in .txx -- Build files have been written to: /Volumes/OpenFOAM/ThirdParty-1.6/paraview-3.8.0/platforms/darwinIntel64 Starting make make: *** No targets specified and no makefile found. Stop. What should be here the problem? Any ideas? Does anybody succeed in compiling paraview on mac with no further problems when loading a OF casefile? I am using the same compiler as I used to build OF 1.6: gcc43 from macports The system i m using is: -mac OX X 10.6.3 64 bits -OF 1.6 compiled with gcc43 from macports -qt4-mac also from macports -cmake 2.8.1 That is all THX Jose |
June 18, 2010, 08:47 |
#126 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- set the CMAKE setting that produces verbose Makefiles. That way when you get an error you also have the compiler call that triggered it and can retry it by hand - there is a handful of ObjectiveC-files in Paraview (the Cocoa-interface). In my experience these can only be compiled with an Apple-compiler (that means: compilation fails. You retry the last printed compiler call but replace gcc-mp-4.3 with /usr/bin/gcc-4.2. After that succeeds restart make) Bernhard |
June 18, 2010, 10:21 |
#127 |
José Rodrigues
Rep Power: 16 |
June 18, 2010, 12:21 |
#128 |
José Rodrigues
Rep Power: 16 |
Hi, Bernard
I managed to set CMAKE the way you suggested and I also eliminated the prob with QMAKESPEC. Now, I get this error message: CMake Error in Applications/ParaView/CMakeLists.txt: Cannot find source file "classes.nib". Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp .hxx .in .txx -- Build files have been written to: /Volumes/OpenFOAM/ThirdParty-1.6/paraview-3.8.0/platforms/darwinIntel64 Starting make make: *** No targets specified and no makefile found. Stop. ---------- $ cmake -DCMAKE_VERBOSE_MAKEFILE=on CMake Error: The source directory "/Volumes/OpenFOAM/ThirdParty-1.6" does not appear to contain CMakeLists.txt. Specify --help for usage, or press the help button on the CMake GUI. Any idea what could this be? I actually find a lot of files named "CMakeLists.txt". However I cant find any "classes.nib" in my whole disc. Is this because of the gcc43 compiler? I cant even find a compiler call before it stops! cheers Jose |
June 19, 2010, 09:23 |
#130 |
José Rodrigues
Rep Power: 16 |
Yeah!! it works perfect!! THX OSHIMA
I wasn't aware of this function!! |
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 05:06 |
problems with installing OpenFOAM 1.6 | su_junwei | OpenFOAM Installation | 8 | September 10, 2009 12:54 |
Problems Installing OF 1.6 32 bit | bucksfan | OpenFOAM Installation | 19 | August 4, 2009 01:36 |
Mac Simple Install Request or Processing Assistance Help | sjohnson | OpenFOAM Installation | 4 | December 12, 2008 07:46 |
MAC + SOLA for free surface | T | Main CFD Forum | 1 | April 11, 2001 13:43 |
