Installing OF 1.6 on Mac OS X
Old   September 24, 2009, 23:35
Pierre-Olivier Dallaire
podallaire is on a distinguished road
Cool ! I tried it and worked / did not run anything yet but will do soon.
Best regards,
PO
podallaire is offline   Reply With Quote
Old   October 8, 2009, 02:17
nikita tryaskin
eternityboy is on a distinguished road
hi, i've got that thing after trying to patch third party
macbook-pro-15:ThirdParty-1.6 resolc$ patch -p1 <ThirdParty-1.6.-Mac.patch.v1
The next patch would create the file .gitignore,
which already exists! Assume -R? [n]
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored -- saving rejects to file .gitignore.rej
can't find file to patch at input line 18
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/ParMGridGen-1.0/MGridGen/IMlib/IMlib.h b/ParMGridGen-1.0/MGridGen/IMlib/IMlib.h
|index 9d0c85c..0cce518 100644
|--- a/ParMGridGen-1.0/MGridGen/IMlib/IMlib.h
|+++ b/ParMGridGen-1.0/MGridGen/IMlib/IMlib.h
File to patch:
so, whats wrong or what to patch?
eternityboy is offline   Reply With Quote
Old   October 9, 2009, 13:38
Assistant Moderator
Bernhard Gschaider
Apply anyway? [n]
Skipping patch.
File to patch:
Ignore that message. You don't need .gitignore. So if this was the only message then the patch worked alright
Bernhard
Old   October 9, 2009, 13:56
nikita tryaskin
nahhh.. it should show patching process when patching.. and this is the first and only message..
Old   October 12, 2009, 13:03
Assistant Moderator
Bernhard Gschaider
Have a look into the patch file. Which other files should be patched and whether it looks like the patches were applied
Bernhard
Old   October 20, 2009, 16:08
Elvis Dowson
elvisjohndowson is on a distinguished road
Is there a fix for libhoard not compiling on Mac OS X 10.6.1 64-bit ?
Elvis Dowson
elvisjohndowson is offline   Reply With Quote
Old   October 20, 2009, 18:48
I don't think so / you don't need this library to run OpenFOAM, should
not be a problem
PO
Old   October 21, 2009, 16:24
Elvis Dowson
I'm getting the following compilation errors, with OpenFoam-1.6, Mac OS X 10.6.1, with MacPorts gcc-mp-4.3, and Bernhard's from his repository.
Seems to me like some basic c++ include files not working. Any suggestions on what I can do to get it to compile?
Making dependency list for source file library_error_exit.c
SOURCE=arch.c ; gcc-mp-4.3 -m64 -DdarwinIntel64 -DWM_DP -Wall -O3 -Drestrict=__restrict -DCOMMON_FILE_COMPRESS_GZ -DCOMMON_RANDOM_FIXED_SEED -DCOMMON_TIMING_OLD -DSCOTCH_RENAME -I../../include -DSCOTCH_VERSION=\""5.1"\" -IlnInclude -I. -I/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -Ddarwin -c $SOURCE -o Make/darwinIntel64DPOpt/arch.o
In file included from /Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:49,
from /usr/include/memory.h:36,
from common.h:65,
from arch.c:75:
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/char.H:41: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Foam'
In file included from /Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:50,
from common.h:65,
from arch.c:75:
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Hasher.H:48:19: error: cstddef: No such file or directory
from common.h:65,
from arch.c:75:
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/Hasher.H:52: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Foam'
In file included from /usr/include/memory.h:36,
from common.h:65,
from arch.c:75:
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:52:18: error: string: No such file or directory
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:53:19: error: cstring: No such file or directory
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:54:19: error: cstdlib: No such file or directory
from common.h:65,
from arch.c:75:
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:58: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Foam'
In file included from /Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/string.h:225,
from common.h:65,
from arch.c:75:
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:27:20: error: iostream: No such file or directory
from common.h:65,
from arch.c:75:
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:31: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:35: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:42: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:49: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:56: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:64: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:78: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:112: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:135: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:172: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:183: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:193: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
/Users/elvis/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/stringI.H:199: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
Old   October 21, 2009, 16:52
Assistant Moderator
Bernhard Gschaider
from common.h:65,
from arch.c:75:
Never seen that one before. Two questions:
- a simple "Hello world" compiles with that compiler?
- your OF-installation is on a case-sensitve volume (because in my opinion the string.h should read string.H - it is my suspicion that because of the case-insensitvity the string.H of OF shadows the /usr/include/string.h)
Bernhard
Old   October 21, 2009, 18:11
Elvis Dowson
Oh, I wasn't aware of the fact that I had to do all the compilation on a case-insensitive volume. I am using my OS X 10.6.1 home directory, which is case-sensitive.
Could you give me some quick commands on how to create a case-insensitive volume, and to do the compilation from within that volume?
Best regards,
Elvis
Old   October 21, 2009, 18:37
Assistant Moderator
Bernhard Gschaider
Last time I checked a OS X system-disc had to be case-insensitve (but maybe Apple fixed that with 10.6 and they thought that this is too geeky to advertize). It only looked case sensitive to the user.
Test in the terminal
touch foo
touch Foo
ls
If ls shows you BOTH files the volume is Case-Sensitive, otherwise it is Case-Insensitive.
You need a case-sensitve volume for OF. Either a separate partition (that's better) or a disk-image.
Under no circumstances try to convert your system-disc to case-sensitive (unless you want to completely reinstall your machine)
Bernhard
Old   October 22, 2009, 01:50
Elvis Dowson
Bernhard
Thanks Bernhard, the Mac OS X 10.6 volume is indeed case-insensitive. I only got foo, when I typed ls.
Could you please give me an example on how to create a disk-image and mount it so that I can do all the compilation in it.
Best regards,
Elvis
Old   October 22, 2009, 06:47
Assistant Moderator
Bernhard Gschaider
Best regards,
Elvis
According to http://openfoamwiki.net/index.php/Ho...e_OpenFOAM_Mac you can do it with the Disc-Utility. The Image will mount itself into /Volumes. You'll have to set a symbolic link to that and you're set
For performance reasons I'd recommend a real partition. I think repartitioning the System-Disc with the Disc-Utility can be done, but you're on your own here ....
Old   October 23, 2009, 03:57
Aurelia Vallier
AureliaV is on a distinguished road
Hi Elvis
This is a part of the message I wrote a few weeks ago:
#1# create a case sensitive disc image called /Volumes/myvoldiskimage
hdiutil create -size 1t -type SPARSE -fs HFSX -volname myvoldiskimage mydiskimage
hdiutil compact mydiskimage.sparseimage
hdiutil attach mydiskimage.sparseimage
#2# create OpenFOAM directory
ln -s /Volumes/myvoldiskimage OpenFOAM
#3# download OF1.6 and Thirdparty1.6 generall and do tar in OpenFOAM directory (which is case sensitive)
cd OpenFOAM
tar xzf ~/Downloads/OpenFOAM-1.6.General.gtgz
tar xvzf ~/Downloads/ThirdParty-1.6.General.gtgz
hope it helps
Aurelia
AureliaV is offline   Reply With Quote
Old   October 23, 2009, 09:54
Elvis Dowson
Thanks for the replies, Aurelia and Bernhard! :-)
I opted for a physical disk partition, for performance reasons.
Now, if I were to work with the OpenFOAM-1.6.x git repository, should I patch the sources manually. If so, do I use Bernhard's patches as a starting point? I tried patching the git repository once before using Bernhard's patches and it failed.
I also notice that in wiki for OpenFOAM-1.4 http://openfoamwiki.net/index.php/Ho...e_OpenFOAM_Mac
there is a mention to a set of Darwin rules : Untar MediaarwinWmakeRules.1.4.v1.tgz to get compilation rules for darwin
Is that necessary?
Best regards,
Elvis
Old   October 23, 2009, 13:24
Elvis Dowson
Is there a git repository for ThirdParty-1.6, just like OpenFOAM-1.6.x ?
How about creating a new branch called macosx-10.6.1 to do the development for Mac OS X 10.6.1 support?
Best regards,
Elvis
Old   October 23, 2009, 14:40
Elvis Dowson
Right now, I've managed to apply Bernhard's Mac OS X patches, to a cloned local branch of the OpenFOAM-1.6.x repository, and called that branch macosx-10.6.1. So, in case this compilation works, I can push the changes to the master repository, so that development can take place for adding Mac OS X support for OpenFOAM.
Best regards,
Elvis
Old   October 23, 2009, 14:53
Elvis Dowson
When attempting to compile OpenFOAM-1.6.x with the patches applied, I get the following errors:
config.status: executing libtool commands
++ make
cd . && /bin/sh /Users/elvis/Tool/OpenFOAM/ThirdParty-1.6.x-patches/openmpi-1.3.3/config/missing --run aclocal-1.10 -I config
sh: config/ompi_get_version.sh: No such file or directory
Is this significant?
Old   October 23, 2009, 15:50
Elvis Dowson
Compilation is proceeding, but I get a couple of errors like the ones below:
could not open file fvm.H for source file laplaceFilter/laplaceFilter.C
could not open file fvc.H for source file laplaceFilter/laplaceFilter.C
I haven't compiled anything in the ThirdParty-1.6.x-patches folder (I'm using OpenFOAM-1.6.x-patches as the starting point, since I'm working on a local git repository, to generate some patches, if the need arises).
So, should I compile ThirdParty-1.6.x-patches, and then launch ./Allwmake from the OpenFOAM-1.6.x-patches folder?
Best regards,
Elvis
Old   October 23, 2009, 17:46
Elvis Dowson
I think it compiled fine now. I just ran the test tutorial and didn't get any errors.
Best regards,
Elvis
Technote OpenFOAM-1.6-001: How to install OpenFOAM-1.6 on Mac OS X 10.6.1
Overview
This document describes how to install OpenFOAM-1.6 on Mac OS X 10.6.1 (Snow Leopard).
Procedure
Step 01.00: Download MacPorts-1.8.0
Download MacPorts from the MacPorts download directory: http://distfiles.macports.org/MacPorts/
Run the package installer, to install the MacPorts infrastructure software to /opt/local/bin
Update the MacPorts installation by running the following command
$ sudo port selfupdate
Step 01.01: Install MacPorts gcc43
$ sudo port install gcc43
Step 02.00: Clone the official qt git source code repository
git clone git://gitorious.org/qt/qt.git
Step 02.01: Checkout the qt-4.5 branch
cd qt
git checkout 4.5
Step 02.02: Clone the git branch
git clone . ../qt-4.5
Step 02.03: Configure qt-4.5
./configure -platform macx-g++ -cocoa -arch x86_64 -nomake examples -nomake demos -framework -sdk /Developer/SDKs/MacOSX10.6.sdk/ -prefix /Developer/Applications/Qt-4.5
Step 02.04: Build qt-4.5
make -j 4
Qt is now configured for building. Just run 'make'.
Once everything is built, you must run 'make install'.
Qt will be installed into /Developer/Applications/Qt-4.5
To reconfigure, run 'make confclean' and 'configure'.
Step 02.05: Build qt-4.5 documentation
make docs
Step 02.06: Install qt-4.5
sudo make install
Step 02.07: Update the PATH environment variable to the qt installation’s binary folder
vi ~/.profile
# Qt-4.5
export PATH=/Developer/Applications/Qt-4.5/bin:$PATH
Step 03.00: Install CMake from the cvs repository
cvs -d server:anonymous@www.cmake.org:/cvsroot/CMake login
(respond with password cmake)
Follow this command by checking out the source code:
cvs -d server:anonymous@www.cmake.org:/cvsroot/CMake co CMake
Bootstrap, build and install CMake
$ ./bootstrap
$ make
$ sudo make install
Step 04.00: Install Paraview from the cvs repository.
mkdir $HOME/Tool/ParaView
cd $HOME/Tool/ParaView
cvs -d server:anoncvs@www.paraview.org:/cvsroot/ParaView3 login
(respond with empty password)
cvs -d server:anoncvs@www.paraview.org:/cvsroot/ParaView3 co ParaView3
For checking out the data, use the following:
cvs -d server:anoncvs@www.paraview.org:/cvsroot/ParaView3 co ParaViewData
Configure ParaView using CMake
mkdir $HOME/Tool/ParaView/ParaView3-bin
cd $HOME/Tool/ParaView/ParaView3-bin
ccmake $HOME/Tool/ParaView/ParaView3
Press c to configure and select the following options
BUILD_SHARED_LIBS = ON
PARAVIEW_USE_MPI = ON
PARAVIEW_ENABLE_PYTHON = ON
Build ParaView
make -j 4
Step 05.00: Install OpenFOAM from tar sources
tar xzf OpenFOAM-1.6.General.gtgz
tar xzf ThirdParty-1.6.General.gtgz
cd OpenFOAM-1.6
patch -p1 < ../OpenFOAM-1.6-Mac.patch
cd ..
cd ThirdParty-1.6
patch -p1 < ../ThirdParty-1.6.-Mac.patch
cd ..
. /Users/elvis/OpenFOAM/OpenFOAM-1.6/etc/bashrc
cd $WM_PROJECT_DIR
./Allwmake
OR
Step 05.01: Install OpenFOAM from the git repository.
cd ~/OpenFOAM
git clone git://repo.or.cz/OpenFOAM-1.6.x.git
tar -zxf ThirdParty-1.6.General.gtgz
ln -s ThirdParty-1.6 ThirdParty-1.6.x
cd ThirdParty-1.6.x
Step 06.00: Test the OpenFOAM installation.
To test whether your installation is ready, run one of the several tutorial-cases, i.e. the "lid driven cavity" case as follows (see also "Getting Started" of the README included in the OpenFOAM distribution):
mkdir -p /Users/elvis/Tool/OpenFOAM/run
cp -r $WM_PROJECT_DIR/tutorials run
cd run/tutorials/incompressible/icoFoam/
blockMesh -case cavity
icoFoam -case cavity
If these commands fail, you either put the files in the wrong place or didn't source the rc-file. Re-check that everything is where it should be and that you sourced the rc-file as documented in the installation instructions.
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 06:06
problems with installing OpenFOAM 1.6 su_junwei OpenFOAM Installation 8 September 10, 2009 13:54
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
Mac Simple Install Request or Processing Assistance Help sjohnson OpenFOAM Installation 4 December 12, 2008 08:46
MAC + SOLA for free surface T Main CFD Forum 1 April 11, 2001 14:43
