#61 | |||||
Anon
Rep Power: 16 ![]() |
/home/vex/OpenFOAM/ThirdParty-1.6/qt-x11-opensource-src-4.3.5/bin/rcc Quote:
[ 8%] Generating qrc_PV3FoamReader.cxx make[2]: QT_RCC_EXECUTABLE-NOTFOUND: Command not found make[2]: *** [qrc_PV3FoamReader.cxx] Error 127 make[1]: *** [CMakeFiles/PV3FoamReader.dir/all] Error 2 make: *** [all] Error 2 Quote:
CMake Error: The following variable are used in this project, but they are set to NOTFOUND. Please set them or make sure they are set and tested correctly in the CMake files: QT_QTDESIGNER_INCLUDE_DIR (ADVANCED) Used as include directory in directory /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/GUISupport/Qt Used as include directory in directory /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Qt/Chart Used as include directory in directory /home/vex/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/GUISupport/Qt/Testing/Cxx Code:
Qt QTGUI library not found. Qt QTCORE library not found. Code:
Warning: QT_QMAKE_EXECUTABLE reported QT_INSTALL_LIBS as /usr/local/Trolltech/Qt-4.3.5/lib Warning: /usr/local/Trolltech/Qt-4.3.5/lib does NOT exist, Qt must NOT be installed correctly. Quote:
#62 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
So... why are you using the custom version? I mean custom, because it isn't the system default version ![]() OK, then let's take one step back. How did you build the custom Qt library? Did you execute the makeQt script that comes with the ThirdParty General package? If not, you should have ![]() By the way, have you tried Mads OpenFOAM 1.6.x install cookbook for Ubuntu, available here (see Mads signature for the link)? There a variant of the same script, by Canesin here, which is a bit more generic for Ubuntu various versions. They aren't perfect, but seems to do the trick for many new users! Either way, knowing what installation steps have you taken so far will make it simpler to help you making OpenFOAM work ![]() Best regards, Bruno |
#63 | |
Anon
Currently running the script as I type. |
9.04, installing openfoam, ubuntu 9.04 |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 7 | July 30, 2009 03:14 |
qt4.3.4 with ubuntu 9.04 "jaunty jackalope"? | sven | OpenFOAM | 4 | May 30, 2009 18:22 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
