June 4, 2009, 10:20 |
OpenFOAM 1.5.x package - CentOS 5.3 x86_64
Niels Nielsen
Rep Power: 27 |
Hello all you Foamer's
I've decided to release at full package of a precompiled version of OpenFOAM 1.5.x for your delight. The package is split up into several sub packages, so if you have a working OpenFOAM installation and only want engrid you can unpack engrid and its dependencies and everything should work. ---------------- Included ---------------- - Cmake 2.6.4 - OpenFOAM 1.5.x (git 01-06-09) (flex, mpfr and gmp built from source) - note paraFoam command will not work since I've altered the Paraview install, just create an empty "case.foam" in you case root folder, and paraview can open your case eg. $ touch cavity.foam - Paraview 3.7 (cvs 01-06-09) and its dependencies. - Built with qt-4.3.5, OpenFOAM version of openmpi, ffmpeg support (export to avi), and parallezied support for decomposed cases. - Engrid 1.0.1 for creating meshes in a gui environment and its dependencies built with qt-4.5.1, VTK-5.4 and latest netgen SVN. - Meshlab 1.2.1 with glew, lib3ds and muParser built with qt-4.5.1 - Gmsh 2.3.1 - Compiled version of GCC-4.3.3 ---------------- Install Instructions for the whole package ---------------- 0. First you need to install the gcc and c++ compiler which is shipped with CentOS 5.3 - yum install gcc gcc-c++ (needed to compile not already precompiled OpenFOAM solvers, like MRFsimpleFoam) 1. Place the content of libraries.tar.gz into /usr/local and accept overwriting existing folders. The package contains the compiled libraries/executable of gmp. mpfr, flex and ffmpeg. if this step is skipped you wont be able to compile the OF extra solvers. 2. Unpack the content of OpenFOAM.tar.gz to /usr/local, this package contains the compiled libraries/executable which the Allmake command produces. The package also contains the thirdparty applications needed by OpenFOAM. 3. Unpack the content of vtk-5.4 to /usr/local (needed by engrid) 4. Unpack the content of Qt-4.5.1 to /usr/local (needed by engrid/Meshlab) 5. Unpack gmsh-2.3.1 to /usr/local 6. Unpack engrid-1.0.1.tar.gz to /usr/local 7. Unpack meshlab-1.2.1.tar.gz to /usr/local 8. Unpack paraview-3.7.tar.gz to /usr/local 9. Setup/copy the relevant content of the bashrc file to your own .bashrc file. This is also attached as bashrc.txt If you want to use ParaView without the OpenFOAM install you need to unpack the openmpi.tar.gz to /usr/local since ParaView is built with MPI support. There are extra packages in the package which is only needed if you consider compiling you own version of the included packages. cmake-2.6.4.tar.gz - for VTK and ParaView Qt-4.3.5.tar.gz - for ParaView openmpi-1.2.6.tar.gz - MPI support for ParaView without an OpenFOAM installation fltk-1.1.9.tar.gz - for gmsh It is possible to install to another location other than /usr/local, all you have to do is to modify you own .bashrc file, the bashrc in OpenFOAM (/usr/local/OpenFOAM/OpenFOAM-1.5.x/etc/bashrc) and possibly also the setup.sh file to point to the right directories. ---------------- Disclaimer ---------------- The package has been verified on a fresh minimal gnome install of CentOS 5.3 64bit The package is "as is" and can only be guaranteed to work with a 64bit version of CentOS/RedHat/Scientific 5.3 (yum update could brake stuff, but i doubt it will). Or if in a cluster environment Rocks 5.2 beta (based on CentOS 5.3). No RPM's will be availble since it is a combersome task to get this to work. I don't have time to create an installer for this, so don't ask for it :-) If other distributions are used, I can't help you. ---------------- Download ---------------- NOTE: The package is available through torrent. I have found a way to host the file online and it should be possible to get it from here Note this is the full package 1Gb Last edited by linnemann; June 10, 2009 at 07:47. Reason: Updated to include install instructions |
June 9, 2009, 12:19 |
Niels Nielsen
Rep Power: 27 |
June 10, 2009, 07:48 |
Niels Nielsen
Rep Power: 27 |
June 19, 2009, 10:17 |
Niels Nielsen
Rep Power: 27 |
Hi
It would be nice if there are any people using this package , to give some feedback, if things are working/not working. Or if you have a request for something extra that aren't included. Regards Linnemann |
July 29, 2009, 05:07 |
Mihails Ščepanskis
Rep Power: 17 |
Linnemann,
I've unpacked your file, but it doesn't work. bashrc file have such code: #User specific aliases and functions . /usr/local/OpenFOAM/OpenFOAM-1.5.x/etc/bashrc But there are no etc directory in unpacked files! How can I solve this problem? Thank you, Mihails |
July 29, 2009, 11:18 |
Niels Nielsen
Rep Power: 27 |
Hi
If you got it from depositfiles you have to unpack first the big file and then the smaller ones. I dont know what could be the problem since the /etc folder exists inside the OpenFOAM.tar.gz when I download and unpack it. Regards |
July 30, 2009, 03:42 |
Mihails Ščepanskis
Rep Power: 17 |
Linnemann,
thank you for answer. I downloaded files from torrents. Ok, I'll try to get them from depositfiles. |
July 30, 2009, 04:14 |
Niels Nielsen
Rep Power: 27 |
Hi
The torrent files are guaranteed to work, I've used them several times. Have you done a data integrity check on the torrent files you downloaded? Using Ktorrent you have this possibility, I have encountered, before, that not all packages were downloaded. Regards |
OpenFoam 1.5.x installation | gareth__it_power | OpenFOAM Installation | 5 | April 1, 2009 04:27 |
OpenFOAM 15 and CentOS 52 installation issues | remrich | OpenFOAM Bugs | 9 | March 20, 2009 02:48 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
