June 16, 2009, 09:33 |
#21 | |
Matteo Carpentieri
Rep Power: 17 |
Does anyone have any other suggestion? |
June 16, 2009, 11:00 |
#22 | |
Mark Olesen
Rep Power: 40 |
June 27, 2009, 17:01 |
#23 |
Steve Hansel
Rep Power: 17 |
I've found that some of the executables in the ThirdParty binary openfoam distribution are for some reason incompatible with Ubuntu 9.04. Cmake is one of them. You can be in the direction with cmake, type ./cmake and it will claim that it's not found. All the protections look reasonable. I think there is something about the file ubuntu doesn't like.
One of the Paraview 3.3-cvs libraries is the same way. It has an undefined label. If I rebuild Paraview, supposedly using the same libraries they did, the problem just goes away. I'm going to try a few more things then I'm reverting to the previous Ubuntu. |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
64bit machine for CFX | Ahlo | CFX | 1 | February 7, 2008 17:30 |
Library problem on a 64bit machine wrong ELF class ELFCLASS32 | jango | OpenFOAM Installation | 0 | June 11, 2007 08:29 |
Problems installing OpenFoam on a 64bit machine | jango | OpenFOAM Installation | 1 | June 4, 2007 15:53 |
runing Fluent with a 64bit machine | Rucy | FLUENT | 1 | November 17, 2005 09:51 |
