GCC Critical Error.
Old   June 19, 2009, 14:23
akidess's Avatar
Anton Kidess
Yeah, this in not a QT problem, but a problem with the Foam reader plugin. If step 7 in the readme does not work, a remedy is to convert the results with foamToVTK and use paraview instead.
Old   June 22, 2009, 11:32
Default problem with parafoam (detailled below)
  #22
riderman is on a distinguished road
Hello Akidess,
I did what is written in the step 7 but in doesn't work :
alexandre@alexandre-laptop:~/OpenFOAM/alexandre-1.5/run/tutorials/icoFoam/cavity$ paraFoam
/home/alexandre/OpenFOAM/OpenFOAM-1.5/bin/paraFoam: 103: paraview: not found
So, I decided to look at this file and here is the "bin/paraFoam". I added numbers of lines otherwise I would be a little be difficult for you to have marks. Can you compare it to yours and tell me whether the error comes from this file?
Moreover, could you indicate me how to convert the results with foamToVTK?
Kind regards
Riderman
33/Script=${0##*/}
35/usage() {
while [ "$#" -ge 1 ]; do echo "$1"; shift; done
cat<<USAGE
usage: $Script [-case dir]
40/
* start paraview $ParaView_VERSION with the OpenFOAM libraries
USAGE
exit 1
45/}
# parse options
if [ "$#" -gt 0 ]; then
case "$1" in
50/ -h | -help)
usage
-case)
shift
55/ caseDir=$1
[ "$#" -ge 1 ] || usage "'-case' option requires an argument"
cd "$caseDir" 2>/dev/null || usage "directory does not exist: '$caseDir'"
60/ usage "unknown option/argument: '$*'"
esac
fi
65/# get a sensible caseName
caseName=${PWD##*/}
# parent directory for normal or parallel results
case "$caseName" in
70/ processor*) parentDir=".." ;;
*) parentDir="." ;;
esac
# check existence of essential files
75/for check in system/controlDict system/fvSchemes system/fvSolution
do
[ -s "$parentDir/$check" ] || usage "file does not exist: '$parentDir/$check'"
done
80/#caseFile="$caseName.foam"
caseFile="$caseName.OpenFOAM"
case "$ParaView_VERSION" in
2*)
85/ # Clean up on termination and on Ctrl-C
trap "rm -f paraFoam.pvs $caseFile 2>/dev/null; exit 0" EXIT TERM INT
touch $caseFile
# since we are now in the cwd, %CASE% is '$PWD/$caseFile'
90/ sed -e s@%CASE%@$PWD/$caseFile@g \
$WM_PROJECT_DIR/bin/paraFoam.pvs > paraFoam.pvs
paraview paraFoam.pvs
95/
trap "rm -f $caseFile 2>/dev/null; exit 0" EXIT TERM INT
touch $caseFile
100/ paraview --data=$caseFile
103/esac
riderman is offline   Reply With Quote
Old   June 22, 2009, 14:17
akidess's Avatar
Anton Kidess
My paraFoam file is not altered, it is the standard script that comes with OpenFOAM. I use ubuntu 8.10 and paraFoam worked out of the box, so I did not have to recompile and cannot give you further advice. Did paraview compile without any errors? Looks like you are missing the binary file.
To view your files in VTK format, run a simulation, then execute the script foamToVTK in your case directory. This will create a new subdirectory "VTK". Now you can run paraview (not paraFoam) and open the VTK files.
-Anton
Last edited by akidess; June 22, 2009 at 14:19. Reason: adding hint to possible compilation error
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
