#41 | |
Hy Yu
Rep Power: 17 ![]() |
yes, if i use "foamToVTK" and i can see the results using "paraview". I cannot understand why paraFoam does not work. Hongyi |
#42 |
Mandar
Hello Jaswinder, thanks a lot for pointing to the right installation files. I have been able to install the dev version and its working fine now. thanks. I will get back to my ggi mixer problem now.
Niel, Thanks to you too for your suggestion. Reg, Mandar |
#43 |
tino boelke
Dear Hongyi,
i have unfortunately the same problem, after compiling
Runnung: Ubuntu 9.04 Nvidia drivers 180 and 173 tried (both the same) Qt-4.3.5 ParaView-3.4.0 On Ubuntu 8.10, the same configurations worked really fine... so where can be the problem? Regards Tino |
#44 |
Henrik Rusche
Rep Power: 18 ![]() |
Dear All,
there is not much I can do to help other than posting my setup. System -------------- lenovo W500 laptop with Suse 11.1 and latest patches. galerius*178-> uname -a Linux galerius 2.6.27.21-0.1-default #1 SMP 2009-03-31 14:50:44 +0200 i686 i686 i386 GNU/Linux compiler -------------- I am used the system compiler to compile OF. Qt-libraries -------------- galerius*177-> rpm -qa | egrep libqt4 libqt4-sql-mysql-4.4.3-11.8.1 libqt4-x11-4.4.3-4.8.2 libqt4-sql-4.4.3-4.8.2 libqt4-sql-unixODBC-4.4.3-11.8.1 libqt4-sql-sqlite-4.4.3-4.8.2 libqt4-devel-doc-data-4.4.3-4.8.1 libqt4-qt3support-4.4.3-4.8.2 libqt4-devel-4.4.3-4.8.2 libqt4-devel-doc-4.4.3-4.8.1 libqt4-4.4.3-4.8.2 libqt4-sql-postgresql-4.4.3-11.8.1 Paraview -------------- I unpacked Paraview 3.4.0 into the ThirdParty directory and used the scripts I posted to compile it. galerius*163-> foamInstallationTest Executing /home/foam/OpenFOAM/OpenFOAM-1.5-dev/bin/foamInstallationTest: foamInstallationTest -------------- Checking basic setup... ------------------------------------------------------------------------------- Shell: tcsh Host: galerius OS: Linux version 2.6.27.21-0.1-default ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/foam/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/foam/OpenFOAM/foam-1.5-dev yes no $WM_THIRD_PARTY_DIR /home/foam/OpenFOAM/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/foam/OpenFOAM/OpenFOAM-1.5-dev yes yes yes $FOAM_APPBIN ...5-dev/applications/bin/linuxGccDPOpt yes yes yes $FOAM_USER_APPBIN ...5-dev/applications/bin/linuxGccDPOpt yes yes no $WM_DIR ...foam/OpenFOAM/OpenFOAM-1.5-dev/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...M/OpenFOAM-1.5-dev/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN ...nFOAM/foam-1.5-dev/lib/linuxGccDPOpt yes yes no $MPI_ARCH_PATH .../openmpi-1.3/platforms/linuxGccDPOpt yes yes yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : ../configure 4.3.2 Minimum required: 4.2.0 gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /bin/gzip tar 1.20 /bin/tar icoFoam 1.5-dev ...penFOAM-1.5-dev/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_galerius Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. done. |
#45 |
Hello all,
I have installed and compiled OF-1.5-dev without an error. Now I wanted to check the icoFoam case but in my Terminal this message is shown: /home/michel/OpenFOAM/OpenFOAM-1.5-dev/bin/paraFoam: 103: paraview: not found. But this is really strange because I compiled paraview, too. Has anybody an idea? Best Regards Michél |
#46 |
tino boelke
@ Holzmichel,
check your $OpenFOAM-DIR/etc/apps/paraview3/bash for these entries: Code:
export ParaView_VERSION="3.5-dev" export ParaView_INST_DIR=$WM_THIRD_PARTY_DIR/ParaView-$ParaView_VERSION Last edited by tino_boelke; May 5, 2009 at 04:34. |
#47 |
export ParaView_INST_DIR=$WM_THIRD_PARTY_DIR/ParaView$ParaView_VERSION
Thank you. between ParaView$ParaView was an - |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Installation problems | indy | OpenFOAM Installation | 7 | April 3, 2009 09:40 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Installation problems | shellbell1999 | OpenFOAM Installation | 9 | April 6, 2006 13:29 |
1 fetal error in OpenFOAM12 installation | andycong | OpenFOAM Installation | 3 | February 26, 2006 03:09 |
