Critical Error wxecuting foamInstallationTest |
April 22, 2009, 06:03 |
Danilo
Rep Power: 17 |
I try to install openFOAM 1.5-dev. If i execute icoFoam, it works properly, but when i try to make the installation test i receive this error: WARNING: gcc version does not match gcc supplied with this release of OpenFOAM Supplied version: 4.3.1 User version : ../configure 4.3.1 Minimum required: 4.2.0 gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /nfs/home/bruno/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR gzip 1.3.12 /usr/bin/gzip tar 1.19 /bin/tar icoFoam 1.5-dev ...nFOAM-1.5-dev/applications/bin/linux64GccDPOpt/icoFoam Actually there's already an installed version (1.5) on the server and i guess that this could be the "Conflicting installations"..... but how can i fix the critical error? Thanks in advance |
April 25, 2009, 14:32 |
Samuele
Rep Power: 17 |
I have almost the same error. Does someone have the solution, please? I'm searching in the whole forum, but I am not able to find an answer.
April 25, 2009, 15:06 |
Samuele
Rep Power: 17 |
I tried this way: I opened setting.sh (conteined within OpenFOAM/OpenFOAM-1.5.x/etc) and I changed the line "compilerInstall" from OpenFOAM to System. In this way my "critical error" disappeared.
May 2, 2009, 18:24 |
inconsistent path definition
Robert
Rep Power: 17 |
I have modified the settings.sh to System to compile the code with Gcc version 4.3.3 in Ubuntu 9.0.4 distribution, and the baseline installation was deemed to be ok by foamInstallationTest. However, when checking for the icoFoam executable path, there was one inconsistent path definition with FOAM_APPBIN and FOAM_USER_APPBIN. I have not figured out how to fix the problem yet.
icoFoam WARNING: Conflicting installations: OpenFOAM settings : /home/rlee/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccSPOpt/icoFoam current path : /home/rlee/OpenFOAM/rlee-1.5/applications/bin/linuxGccSPOpt/icoFoam CRITICAL ERROR Does anyone know how to fix this ? |
CRITICAL ERROR on installation OpenFOAM 141 | nuovodna | OpenFOAM Installation | 19 | March 22, 2010 23:36 |
Critical temperaturepressure of liquids for dieselFoam solver | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | December 30, 2008 16:57 |
Critical errors gcc and icoFoam during installation of 15 | quartzian | OpenFOAM Installation | 3 | December 12, 2008 13:42 |
Critical errors on gcc and icofoam | giuliano | OpenFOAM Installation | 4 | June 25, 2008 14:31 |
Which is the fatal error when foamInstallationTest | eddy | OpenFOAM Installation | 2 | March 30, 2008 22:13 |
