April 16, 2009, 11:50 |
Environment Variable
Danilo
Rep Power: 17 |
I'm trying to install OpenFOAM on my PC, even if it's already installed on the uni's network. My problem is that all the environment variables are set for the network installation, and i have to change them. I have a look into this bashrc file and change everything there, but it's not enough, because when i try to modify some solvers ore to execute some tests, i receive always the same error because all the environment variables point "to the server". Where i can find/modify these variables. Thanks a lot Danilo |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Install Openfoam in Suse 100 setup environment | h34gk1 | OpenFOAM Installation | 1 | September 26, 2006 21:08 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 05:27 |
How to set environment variables | kanishka | OpenFOAM Installation | 1 | September 4, 2005 11:15 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
