Installation 1.5 as a user of server (New bird)
Old   April 12, 2009, 21:57
Default Installation 1.5 as a user of server (New bird)
J. Cai
chiven is on a distinguished road
I am only a user of a large computer server, and I execute the foamSystemCheck script in the bin/directory of the OpenFOAM installation.
Checking basic system...
Shell: /bin/tcsh
Host: jaerif
OS: Linux version 2.6.5-7.283-sn2
User: e090012
System check: PASS
Continue OpenFOAM installation.
Then I do Installation
EITHER
if running bash or ksh (if in doubt type echo $SHELL), source the etc/bashrc file by adding the following line to the end of your $HOME/.bashrc file:
. $HOME/OpenFOAM/OpenFOAM-<VERSION>/etc/bashrc
Then update the environment variables by sourcing the $HOME/.bashrc file by typing in the terminal:
. $HOME/.bashrc
OR
if running tcsh or csh, source the etc/cshrc file by adding the following line to the end of your $HOME/.cshrc file:
source $HOME/OpenFOAM/OpenFOAM-<VERSION>/etc/cshrc
Then update the environment variables by sourcing the $HOME/.cshrc file by typing in the terminal:
source $HOME/.cshrc
However, when I run the command $HOME/.bashrc or $HOME/.cshrc, it is not successful.
/home/g2/e090012/.cshrc: Permission denied.
is shown.
What shall I do in the next step? Any suggestions? Thank you very much.
chiven is offline   Reply With Quote
Old   April 13, 2009, 01:54
Default any help
J. Cai
I try again, and do the following:
change the file of .bashrc in /home/g2/e090012/.bashrc
adding the following line to the end:
.$HOME/OpenFOAM/OpenFOAM-1.5/etc/bashrc
then
update the environment variable by this command:
.$HOME/.bashrc
however, "./home/g2/eo90012/.bashrc: Command not found." is shown.
in fact, ".bashrc" does exist there.
So I change the property by:
chmod 755 .bashrc
Still be unsuccessful. How shall I do?
I run this command: $PATH, the result is as follows.
.:.:.:.:.:.:/usr/center/bin:/opt/vast/bin:/jaeri/app/toolworks/totalview/bin:/jaeri/lsf/6.2/linux2.6-glibc2.3-sn-ipf/etc:/jaeri/lsf/6.2/linux2.6-glibc2.3-sn-ipf/bin:/usr/kerberos/bin:/opt/intel/itac/7.1/bin:/opt/intel/ita/bin:/opt/intel/itc/bin:/opt/intel/vtune/bin:/opt/intel_fc/10.1.011/bin:/opt/intel_idb/10.1.011/bin:/opt/intel_cc/10.1.011/bin:/opt/histx_1.3b/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/X11R6/bin:/usr/games:/opt/gnome/bin:/opt/kde3/bin: Command not found.
welcome any comment.
Old   April 13, 2009, 03:04
Default any comments
J. Cai
I also try to run the command with a blank like,
. $HOME/.bashrc
but the result is
.: Permission denied.
What shall I do?
I run this command: ls -l /home/g2/e090012/.bashrc
the result is :
-rwxrwxr-x 1 e090012 g0913 1364 Apr 13 16:11 /home/g2/e090012/.bashrc
Any suggestions?
Time is limited, I am very urgent now, can anybody give me suggestions?
Old   April 13, 2009, 07:07
Default .: Permission denies
J. Cai
I have search many threads here, but all of the problems met by other friends are that some files or folders are Permission denied, so they can solve the problems easily, only by changing the characteristic of the files or folders.
However in my case, it is the "." which is " : Permission denies".
How to solve this problem?
Old   April 13, 2009, 07:57
Default try to compile $HOME/.cshrc
J. Cai
Then I try to change the $HOME/.cshrc, add the source $HOME/OpenFOAM/OpenFOAM-1.5/etc/cshrc at the last raw, like:
# This is the default standard .cshrc provided to csh users.
# They are expected to edit it to meet their own needs.
# The commands in this file are executed each time a new csh shell
# is started.
umask 022
set path=(. $path)
# list directories in columns
#alias ls 'ls -C'
alias cp 'cp -i'
alias mv 'mv -i'
alias rm 'rm -i'
# Remember last 100 commands
set history = 100
and run the command: source $HOME/.cshrc
however, the result is as follows.
jaerif g2/e090012> source $HOME/.cshrc
umask: Improper mask.
What shall I do?
Old   April 13, 2009, 09:59
lin
Hua Zen
lin is on a distinguished road
For this problem,I think you'd better to ask for the system administrator for help.It's not OF related.
lin is offline   Reply With Quote
Old   April 13, 2009, 10:08
Default Thanks
J. Cai
Thanks for lin's reply.
But the problem is very queer. And I think the system administrator doesn't understand the FOAM.
Now, I am trying to install FOAM in another server.
Any other comments?
Old   April 13, 2009, 10:54
Default The same problem
J. Cai
I try to install OpenFOAM in another server, the same problem is met. It is very intereting.
[e090012@jaeripca ~]$ source $HOME/.cshrc
I have to go back and have a supper. Good night everybody, and see you tomorrow.
Old   April 14, 2009, 08:39
Default Insteresting
J. Cai
I found an interesting thing.
I run the "foamInstallationTest" successfully in a server once, however, when I try to run it again, fail.
Another question,
Now I can run the source "$HOME/.cshrc" successfully, but after that, I run "foamInstallationTest", the results are
__________________________________________________ ______________
Checking basic setup...
FATAL ERROR: OpenFOAM environment not configured.
Please refer to the installation section of the README file:
<OpenFOAM installation dir>/OpenFOAM-1.5/README
to source the OpenFOAM environment.
And I check the file of ".cshrc", which is shown in follows.
# is started.
umask 022
set path=(. $path)
#alias ls 'ls -C'
alias cp 'cp -i'
alias mv 'mv -i'
alias rm 'rm -i'
set history = 100
__________________________________________________ ________________
I can not find any problem there.
Helps.
Old   April 14, 2009, 10:05
Default very interesting
J. Cai
I try again and again, I revised the file of .cshrc as follows.
__________________________________________________ __________________________________________________ _________
# is started.
umask 022
#set path=(. $path)
#alias ls 'ls -C'
alias cp 'cp -i'
alias mv 'mv -i'
alias rm 'rm -i'
set history = 100
#source $HOME/OpenFOAM/OpenFOAM-1.5/etc/cshrc
#source /home/g2/e090012/OpenFOAM/OpenFOAM-1.5/etc/cshrc
setenv PATH $PATH:OpenFOAM/OpenFOAM-1.5/etc/cshrc
__________________________________________________ __________________________________________________ __________
suddenly the command of "foamInstallationTest" can be run, and the results are shown in following.
jaerif OpenFOAM-1.5/bin> foamInstallationTestExecuting /home/g2/e090012/OpenFOAM/OpenFOAM-1.5/bin/foamInstallationTest:
Shell: tcsh
Host: jaerif
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/g2/e090012/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/g2/e090012/OpenFOAM/e090012-1.5 yes no
$WM_THIRD_PARTY_DIR /home/g2/e090012/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/g2/e090012/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...5/applications/bin/linuxIA64I64DPOpt yes yes yes
$FOAM_USER_APPBIN ...5/applications/bin/linuxIA64I64DPOpt yes yes no
$WM_DIR .../e090012/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.5/lib/linuxIA64I64DPOpt yes yes yes
$FOAM_USER_LIBBIN ...AM/e090012-1.5/lib/linuxIA64I64DPOpt yes yes no
$MPI_ARCH_PATH --------- env variable not set --------- yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : 3.3.3
Minimum required: 4.2.0
gcc 3.3.3
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.5 /usr/bin/gzip
tar 1.13.25 /bin/tar
icoFoam
OpenFOAM settings : /home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxIA64I64DPOpt/icoFoam
current path :
CRITICAL ERROR
Checking networking...
Action Result Crit
Pinging_jaerif Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
I really hope the experts can give some suggestions to me. Thanks in advance.
Have a sweet dream, everybody.
Old   April 14, 2009, 23:35
Default Sime results
  #11
J. Cai
Now I understand the errors before are resulted by my using ftp to edit the file. Now I am using the editor of vi, everything seems OK.
And I use this command to update the environment variables:
#setenv PATH /home/g2/e090012/OpenFOAM/OpenFOAM-1.5/ect/cshrc
Here are the results.
Shell: tcsh
Host: jaerif
gcc 3.3.3
CRITICAL ERROR
icoFoam
current path :
CRITICAL ERROR
Action Result Crit
done.
Old   April 15, 2009, 07:27
Default more better now
  #12
J. Cai
adding the following line to the end of your $HOME/.cshrc file is also OK now:
before there, i have to run the command to define WM_COMPILER_DIR:
setenv WM_COMPILER_DIR /home/g2/e090012/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/
Old   April 20, 2009, 00:51
Default Install in VMware
  #13
J. Cai
Executing /home/cai/OpenFOAM/OpenFOAM-1.5/bin/foamInstallationTest:
Shell: bash
Host: linux-jobm
OS: Linux version 2.6.22.19-0.2-default
$WM_PROJECT_INST_DIR /home/cai/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/cai/OpenFOAM/cai-1.5 yes no
$WM_THIRD_PARTY_DIR /home/cai/OpenFOAM/ThirdParty yes yes
$WM_PROJECT_DIR /home/cai/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...M-1.5/applications/bin/linuxGccDPOpt yes yes yes
$FOAM_USER_APPBIN ...i-1.5/applications/bin/linuxGccDPOpt yes yes no
$WM_DIR /home/cai/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
$FOAM_LIBBIN ...nFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...i/OpenFOAM/cai-1.5/lib/linuxGccDPOpt yes yes no
$MPI_ARCH_PATH ...penmpi-1.2.6/platforms/linuxGccDPOpt yes yes yes
gcc 4.3.1 .../OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.17 /bin/tar
icoFoam 1.5 ...AM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam
Action Result Crit
Pinging_linux-jobm Successful yes
Critical systems ok.
done.
cai@linux-jobm:~/OpenFOAM/cai-1.5/run/tutorials/icoFoam/cavity> blockMesh
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
Exec : blockMesh
Date : Apr 18 2009
Time : 04:01:28
Host : linux-jobm
PID : 11331
Case : /home/cai/OpenFOAM/cai-1.5/run/tutorials/icoFoam/cavity
nProcs : 1
Create time
Reading block mesh description dictionary
Creating block mesh
Creating blockCorners
Creating curved edges
Creating blocks
Creating patches
Creating block mesh topology
Default patch type set to empty
Check block mesh topology
Basic statistics
Number of internal faces : 0
Number of boundary faces : 6
Number of defined boundary faces : 6
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating points
Creating cells
Creating patches
Creating mesh from block mesh
Writing polyMesh
end
cai@linux-jobm:~/OpenFOAM/cai-1.5/run/tutorials/icoFoam/cavity> paraFoam
paraview: error while loading shared libraries: libQtAssistantClient.so.4: cannot open shared object file: No such file or directory
however, I can use paraview directly by changing it ti VTK form.
blockMesh
chechMesh
icofoam >& log &
cat log
foamToVTK
paraview
therefore, there maybe an conflict between the QT version and paraview 3.3.
anyway, it is basically successful, congratulations. good luck
Old   April 21, 2009, 09:16
Default new progress
  #14
J. Cai
Today, I revise the file of "~/OpenFOAM/OpenFOAM-1.5/etc/cshrc" as following part:
case ia64:
# setenv WM_ARCH linuxIA64
setenv WM_ARCH linux64
# setenv WM_COMPILER I64
breaksw
then run foamInstallationTest in the /etc/ directory successfully, the results are shown as follows.
Shell: tcsh
Host: jaerif
$FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...FOAM/e090012-1.5/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
User version :
gcc ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
icoFoam .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam
Action Result Crit
done.
however, when i try to run the case of cavity, i is not OK. the results like,
jaerif tutorials/icoFoam> cd cavity
jaerif icoFoam/cavity> blockMesh
/home/g2/e090012/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/blockMesh: Exec format error. Binary file not executable.
I check the gcc version, it also show binary file is not executable as follows.
jaerif OpenFOAM-1.5/bin> gcc version
/home/g2/e090012/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc: Exec format error. Binary file not executable.
I think for this ia64 linux platform, i have to rebuild the complete OpenFOAM from the source-pack by myself.
good luck.
Old   April 22, 2009, 08:29
Default buildParaView3.3-cvs problem
  #15
J. Cai
-- Build files have been written to: /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linuxGcc
Scanning dependencies of target vtksys
[ 0%] Building C object VTK/Utilities/kwsys/CMakeFiles/vtksys.dir/ProcessUNIX.o
In file included from /usr/include/signal.h:333,
from /usr/include/sys/wait.h:31,
from /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:56:
/usr/include/bits/sigcontext.h:28:29: error: asm/sigcontext.h: No such file or directory
In file included from /usr/include/errno.h:36,
from /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:60:
/usr/include/bits/errno.h:25:26: error: linux/errno.h: No such file or directory
In file included from /usr/include/bits/posix1_lim.h:153,
from /usr/include/dirent.h:232,
from /home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:63:
/usr/include/bits/local_lim.h:36:26: error: linux/limits.h: No such file or directory
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘vtksysProcess_Execute’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:730: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:730: error: (Each undeclared identifier is reported only once
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:730: error: for each function it appears in.)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessWaitForPipe’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1036: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘vtksysProcess_Kill’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1347: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessCleanup’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1465: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessCleanupDescriptor’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1512: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessClosePipes’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1540: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessCreate’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1733: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessDestroy’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:1779: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessFork’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:2278: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessesAdd’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:2555: error: ‘EINTR’ undeclared (first use in this function)
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c: In function ‘kwsysProcessesRemove’:
/home/cai/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Utilities/kwsys/ProcessUNIX.c:2592: error: ‘EINTR’ undeclared (first use in this function)
make[2]: *** [VTK/Utilities/kwsys/CMakeFiles/vtksys.dir/ProcessUNIX.o] Error 1
make[1]: *** [VTK/Utilities/kwsys/CMakeFiles/vtksys.dir/all] Error 2
make: *** [all] Error 2
done
Old   April 26, 2009, 23:33
Default done
  #16
J. Cai
for the SUSE 10.3 platform, it only need to compile the paraview 3.3, it is OK.
and for the IA64 platform, it need to rebuild the OpenFOAM from the source codes.
Special thanks to Dr Wei in Tongji University, China.
Good luck everybody.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Installation of CCM+ on HPC server 2008 Peter Schiøler Siemens 0 January 29, 2009 06:49
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
External Flow Computations - Lift and Drag Ramanath KS Main CFD Forum 9 December 28, 2000 18:38
