Installing OpenFOAM 1.5 on OpenSUSE 11.1
Old   April 25, 2009, 22:21
Alberto Passalacqua
All due to the lack of libPstream.so, which is provided in the ThirdParty binary package, as I said before :-)
Btw, are you on openSUSE 32 or 64 bit?
Best,
Alberto Passalacqua
Old   April 25, 2009, 22:40
Samuele
StructureITA is on a distinguished road
Originally Posted by alberto View Post
The reader builds. You reported warnings, if I did not miss something.
Could you give more details about the errors you read when you compile OpenFOAM?
Are you using a 64 bit distribution? Have you _all_ (binary and source) the third party packages installed? libPstream should be in
/home/Sam/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/openmpi-1.2.6/libPstream.so
if you have a 64 bit system, and something like that for a 32 bit version (linux instead than linux64 in the path).
Best,
I am running a 32 bit distribution.
What do you mean with "installed"? I simply took the files and I put them into the ThirdParty folder. Have I to do something else?
However, yes, libPstream.so is in /home/Sam/OpenFOAM/OpenFOAM-1.5.x/lib/linuxGccDPOpt/openmpi-1.2.6. It exists, it is in there. How it is possible that libOpenFOAM dows not see it?
StructureITA is offline   Reply With Quote
Old   April 25, 2009, 23:06
Alberto Passalacqua
OK. I have just recompiled 1.5.x on my system after an update and it works OK.
With installed I meant "put the ThirdParty directory into the ~/OpenFOAM directory.
This
linux-gate.so.1 => (0xffffe000)
libPstream.so => not found
libz.so => /usr/lib/libz.so (0xb7c5d000)
libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xb7b69000)
libm.so.6 => /lib/libm.so.6 (0xb7b40000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xb7b30000)
libpthread.so.0 => /lib/libpthread.so.0 (0xb7b16000)
libc.so.6 => /lib/libc.so.6 (0xb79ba000)
/lib/ld-linux.so.2 (0xb8041000)
looks weird. I checked what
ldd $FOAM_LIBBIN/libOpenFOAM.so
gives to me, and the answer was (I'm using the system compiler):
linux-vdso.so.1 => (0x00007fff341fc000)
libPstream.so => /home/alberto/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/openmpi-1.2.6/libPstream.so (0x00007ff72b83a000)
libz.so => /home/alberto/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libz.so (0x00007ff72b622000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00007ff72b2ed000)
libm.so.6 => /lib64/libm.so.6 (0x00007ff72b096000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007ff72ae7e000)
libc.so.6 => /lib64/libc.so.6 (0x00007ff72ab25000)
libmpi.so.0 => /home/alberto/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linux64GccDPOpt/lib/libmpi.so.0 (0x00007ff72a898000)
/lib64/ld-linux-x86-64.so.2 (0x00007ff72c03b000)
libopen-rte.so.0 => /home/alberto/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linux64GccDPOpt/lib/libopen-rte.so.0 (0x00007ff72a63e000)
libopen-pal.so.0 => /home/alberto/OpenFOAM/ThirdParty/openmpi-1.2.6/platforms/linux64GccDPOpt/lib/libopen-pal.so.0 (0x00007ff72a3dc000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007ff72a1d8000)
libnsl.so.1 => /lib64/libnsl.so.1 (0x00007ff729fc0000)
libutil.so.1 => /lib64/libutil.so.1 (0x00007ff729dbc000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007ff729ba0000)
Notice that also other libs are taken from the OpenFOAM/ThirdParty sub-directories.
Did you change the configuration file of OpenFOAM sourced in your /home/Sam/.bashrc ?
Best,
Alberto Passalacqua
Old   April 25, 2009, 23:11
Samuele
Do you mean if I added the line ". $HOME/OpenFOAM/OpenFOAM-1.5.x/etc/bashrc"? I did this through the nano command (as gac said, being not superuser):
nano ~./bashrc
Old   April 25, 2009, 23:24
Alberto Passalacqua
If you did type it this way
nano ~./bashrc
it is wrong. The correct syntax is nano ~/.bashrc, being .bashrc a hidden file.
Just to be sure, you have to do everything I said as your user (Sam), and not as root, as correctly pointed out by gac.
I meant if you edited $HOME/OpenFOAM/OpenFOAM-1.5.x/etc/bashrc or /home/Sam/OpenFOAM/OpenFOAM-1.5.x/etc/settings.sh in some way.
P.S. If you have time, we can talk directly on #openfoam-irc on irc.freenode.net servers, or you can add me to your MSN or Skype.
Best,
Alberto Passalacqua
Old   April 25, 2009, 23:43
Samuele
I added you to MSN.
Old   April 25, 2009, 23:58
Alberto Passalacqua
I'm connected (alberto_passalacqua@hotmail.it) but I don't see you.
Edit: Sorry, there was a typo in the address in the profile. Not it is fixed.
Best,
Alberto Passalacqua
Old   April 28, 2009, 04:34
Samuele
I did it!
Alberto helped me very much and I have to thank him a lot. Thanks to him I understood that I was performing several mistakes:
- installation and bash modifications has to be done not as root;
- download of the git repository has to be done in order to have to latest version;
- unzip of the two thirdparty packages has to performed in the same folder, in order to let them to make a single result in a single folder.
Moreover, beyond these instructions he gave me, I discovered that some files from the binary pack (OpenFOAM 1.5) have to be taken and inserted within the 1.5.x version. I refer to:
- several applications/bin/linuxGccDPOpt files;
- several lib/linuxGccDPOpt files;
- the file wmkdep inserted in the folder wmake/rules/linuxGcc.
When I didn't inserted them yet, I was not able to run the tutorial and foamInstallationTest told me that a CRITICAL ERROR in icoFoam installation was present. Now (after this modification and the compilation of ParaView and OpenFOAM), foamInstallationTest is perfect and I am finally able to perform the tutorial about cavity.
foamInstallationTest log:
Executing ./foamInstallationTest:
Checking basic setup...
Shell: bash
Host: linux-jw4g
OS: Linux version 2.6.27.21-0.1-pae
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/Sam/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/Sam/OpenFOAM/Sam-1.5.x yes no
$WM_THIRD_PARTY_DIR /home/Sam/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/Sam/OpenFOAM/OpenFOAM-1.5.x yes yes yes
$FOAM_APPBIN ...1.5.x/applications/bin/linuxGccDPOpt yes yes yes
$FOAM_USER_APPBIN ...1.5.x/applications/bin/linuxGccDPOpt yes yes no
$WM_DIR /home/Sam/OpenFOAM/OpenFOAM-1.5.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...OAM/OpenFOAM-1.5.x/lib/linuxGccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OpenFOAM/Sam-1.5.x/lib/linuxGccDPOpt yes yes no
$MPI_ARCH_PATH ...penmpi-1.2.6/platforms/linuxGccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.1 .../OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
gzip 1.3.12 /usr/bin/gzip
tar 1.20 /bin/tar
icoFoam 1.5.x .../OpenFOAM-1.5.x/applications/bin/linuxGccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_linux-jw4g Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the OpenFOAM enviroment.
Base configuration ok.
Critical systems ok.
done.
What I see after typing the three tutorial command lines:
Old   April 28, 2009, 12:12
Alberto Passalacqua
Click Apply ;-)
The case is not visible, as shown by the "eye" next to the name "cavity.OpenFOAM".
Alberto Passalacqua
Old   April 29, 2009, 04:30
Hy Yu
ttdtud is on a distinguished road
Click Apply ;-)
Hi Alberto,
actually i have the same problem as above. The case is not visible. Especially in my case i have no chance to click "Apply" which is always grey.
How can i correct it?
Best Regards
Hongyi
ttdtud is offline   Reply With Quote
Old   April 30, 2009, 20:37
Default Results can't be seen in ParaFoam
  #31
Hy Yu
Hi Alberto,
as you said, the case is not visible. Using FoamToVTK and starting paraview, everything can be seen.
The results of run "foamInstallationTest" are:
Shell: bash
Host: ttdws92
OS: Linux version 2.6.25.20-0.1-default
$WM_PROJECT_INST_DIR /home/hongyi/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/hongyi/OpenFOAM/hongyi-1.5.x yes no
$WM_THIRD_PARTY_DIR /home/hongyi/OpenFOAM/ThirdParty yes yes
$WM_PROJECT_DIR /home/hongyi/OpenFOAM/OpenFOAM-1.5.x yes yes yes
$FOAM_APPBIN ...5.x/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_USER_APPBIN ...5.x/applications/bin/linux64GccDPOpt yes yes no
$WM_DIR ...hongyi/OpenFOAM/OpenFOAM-1.5.x/wmake yes yes yes
$FOAM_LIBBIN ...M/OpenFOAM-1.5.x/lib/linux64GccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OAM/hongyi-1.5.x/lib/linux64GccDPOpt yes yes no
$MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes yes yes
gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
tar 1.19 /bin/tar
icoFoam 1.5.x ...penFOAM-1.5.x/applications/bin/linux64GccDPOpt/icoFoam
Action Result Crit
Pinging_ttdws92 Successful yes
done.
My setup is:
uname -a
Linux ttdws92 2.6.25.20-0.1-default #1 SMP 2008-12-12 20:30:38 +0100 x86_64 x86_64 x86_64 GNU/Linux
What is false?
Please help me! Since last week i have concentrated myself on compiling OF-1.5.x. Till now the paraFoam does not work rightly.
Best Regards
Hongyi
Old   April 30, 2009, 20:45
Alberto Passalacqua
Did you recompile ParaView and the reader using your system Qt library?
If so, I don't know why it doesn't work. It is working smoothly here on openSUSE 11.1 64 bit.
Best,
Alberto Passalacqua
My experiences about Installing OpenFOAM on OPENSUSE103 32bit coompressor OpenFOAM Installation 9 February 19, 2010 00:00
OpenFOAM 15 with ParaView 340 on OpenSuSE 110 zairja OpenFOAM Installation 7 February 10, 2009 09:31
Fonts not displaying properly under openSuse 11.1 F.P. FLUENT 0 January 8, 2009 09:44
OpenFOAM Version 1.5 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 July 14, 2008 19:22
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
