April 1, 2009, 10:25 |
OpenFOAM on SiCortex
FoamHeads,
Does anyone have experience running OpenFOAM on a SiCortex machines (http://sicortex.com/) that they would be willing to share? I'm particularly looking for: 1. performance metrics 2. installation & optimization I've noticed that 1.5-dev has an entry in the wmake directory, $WM_PROJECT_DIR/wmake/rules/SiCortex64Gcc. Therefore, someone is using a SiCortex machine in the OpenFOAM world. Thanks, Eric |
April 6, 2009, 15:24 |
Mattijs Janssens
Rep Power: 26 |
2. We did the port a little while ago. Since it is based on Linux it was quite easy - the only major change we had to make was in enforcing 4 byte alignment for mpi transfers. It should just compile/run out of the box. We just linked in their native mpi - didn't do any specific optimisation.
1. We only ran some tiny testcases to make sure it was running. I'd be interested in seeing some performance metrics as well - especially scaling on lots of processors. |
April 6, 2009, 16:09 |
Hi Mattijs,
Yeah, the wmake/rules looked pretty straight forward, so I expected it to compile without much problem. I have access to a SiCortex SC1458 which has 1458 cores (http://sicortex.com/products/entry_m..._system_sc1458). Once I have some scaling performance numbers, I'll post them. Eric |
April 7, 2009, 05:51 |
Mattijs Janssens
Rep Power: 26 |
We found a big benefit from turning off runTimeModifiable (checks all registered dictionaries for change every time step). The nfs performance is not spectacular.
July 15, 2009, 11:14 |
Kent Wardle
Rep Power: 21 |
I have access to a SiCortex with 5832 cores. I will try to compile and runs some tests on this one too.
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 10:33 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
