OpenFOAM141dev installation error (bashrc file)
Old   March 18, 2009, 05:39
Default OpenFOAM141dev installation error (bashrc file)
Virginie Ehrlacher
virginie_e is on a distinguished road
Hello foamers,
I just downloaded the svn package for OpenFOAM-1.4.1-dev yesterday and tried to compile it. (I am using a linux x86_64) However, when I typed the following command:
. ~/OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/bashrc
I got the following error:
ksh: /users/V1117324/OpenFOAM/OpenFOAM-1.4.1-dev/.bashrc[107]: too many files open in shell
Executing: /users/V1117324/OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/apps/ensightFoam/bashrc
Executing: /users/V1117324/OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/apps/paraview/bashrc
Executing: /users/V1117324/OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/apps/dxFoam/bashrc
ksh: /users/V1117324/OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/bashrc[275]: can't create pipe - try again
That is very strange because I managed to compile OpenFOAM-1.5-dev without problem. Does anyone know why I have too many files open in shell? Does somenone know what I should do to make it run? Thank you very much!
Virginie
virginie_e is offline   Reply With Quote
Old   March 18, 2009, 05:48
Virginie Ehrlacher
Hello foamers,
just a quick precision to say that I commented out the lines
#SOURCE $WM_PROJECT_DIR/$FOAM_DOT_DIR/apps/ensightFoam/bashrc
#SOURCE $WM_PROJECT_DIR/$FOAM_DOT_DIR/apps/paraview/bashrc
#SOURCE $WM_PROJECT_DIR/$FOAM_DOT_DIR/apps/dxFoam/bashrc
#SOURCE $WM_PROJECT_DIR/$FOAM_DOT_DIR/apps/ParaView3/bashrc
in the OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/bashrc file,
but I still get the following error:
Thank you for your help
Virginie
Old   March 18, 2009, 06:27
Virginie Ehrlacher
Hello again,
sorry for having spammed your mail box, but I have found what the problem was. In fact, my OpenFOAM/OpenFOAM-1.4.1-dev/.bashrc and OpenFOAM/OpenFOAM-1.4.1-dev/.OpenFOAM-1.4.1-dev/bashrc files were sourcing one another indefinitely.
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
Error compiling OpenFOAM141dev on Ubuntu 710 andersking OpenFOAM Bugs 1 January 16, 2008 06:43
Bashrc for PS3 Fedora 6 and IBM sdk 21 mgarcia OpenFOAM Installation 0 November 2, 2007 14:24
Error after installation.. Nari Siemens 5 June 28, 2007 15:02
Who have 3.24 linux help file about installation? Kevin Siemens 1 July 8, 2005 09:42
