LibfoamUserso in multiuser configuration
Old   March 16, 2005, 08:35
Default We are trying to install OpenF
Daniele Panara
panara is on a distinguished road
We are trying to install OpenFOAM on our cluster in order to be used by all the users.
Everything works fine, the question now is what is the right way to handle the user libraries...
When a user creates is own boundary conditions ,for example, and recompile the foamUser library the file libfoamUser.so is modified.
A user should not have the right to access the lib directory..
Is there any other method to handle this except to give the writing file permission to all the users?
Daniele
panara is offline   Reply With Quote
Old   March 16, 2005, 08:46
Default Users libraries should be comp
henry is on a distinguished road
Users libraries should be compiled into their own library directory. There are a set of FOAM_USER_??? variables within the build system to handle this. So the user should create a copy of the foamUser directory and change the Make/files file in their to create the libfoamUser.so in their own directory:
LIB = $(FOAM_USER_LIBBIN)/libfoamUser
and put a list of all the files they want to build and link into their library into that file as well, e.g.
interpolations = interpolations
surfaceInterpolation = $(interpolations)/surfaceInterpolation
schemes = $(surfaceInterpolation)/schemes
$(schemes)/limiterTest/limiterTestMake.C
turbulenceModels/incompressible/v2f/v2f.C
libfoamUser.C
henry is offline   Reply With Quote
Old   March 16, 2005, 10:12
Default Thanks very much, now everithi
Daniele Panara
Thanks very much, now everithing is working fine!!
Just one extra little question, in order to make it work I had to add in my $PATH the $(FOAM_USER_LIBBIN) as well as $(FOAM_USER_APPBIN) path.
Was it the right thing to do? or I am making some other mistake
Daniele
Old   March 16, 2005, 10:16
Default That's a bit strange, as long
That's a bit strange, as long as you have $FOAM_USER_LIBBIN in your $LD_LIBRARY_PATH it should work fine. This should be done automatically by the OpenFOAM dot-files, could you check and let me know.
Old   March 16, 2005, 10:36
Default The reason was that after the
Daniele Panara
The reason was that after the creation of the $FOAM_USER_LIBBIN directory I didn't update the shell variables with the command
. /opt/OpenFOAM/OpenFOAM-1.0.2/.OpenFOAM-1.0.2/bashrc
Now everithing is clear, thanks very much!
Old   March 16, 2005, 10:55
Default The creation of those director
The creation of those directories, the setting of the corresponding environment variable and the update of $PATH and $LD_LIBRARY_PATH is fully automatic in OpenFOAM-1.1
Best cluster configuration ziad OpenFOAM Installation 15 September 21, 2007 13:36
Configuration of MPICH mer OpenFOAM Installation 31 June 6, 2007 19:08
Dual configuration ff FLUENT 0 January 27, 2004 07:14
PC configuration for CFD Fernando Sanz Main CFD Forum 17 December 19, 2001 08:29
airplane configuration Shereef Main CFD Forum 10 October 26, 2000 12:48
