Will OpenFoam work on Xeon
Old   May 2, 2005, 09:09
Default Hi, We are planning to upgrad
David Segersson
segersson is on a distinguished road
We are planning to upgrade our CFD-hardware, and I just wanted to make sure that it will be possible to run OpenFOAM on the new hardware.
Can the binaries provided for Linux/Pentium be expected to work on a machine with two Intel Xeon processors running Red Hat Enterprise Linux ES 3?
Regards
David
segersson is offline   Reply With Quote
Old   May 2, 2005, 09:31
Default Probably yes. We're not runnin
Mattijs Janssens
mattijs is on a distinguished road
Probably yes. We're not running Redhat over here so cannot test.
But you can always recompile from sources. As long as you make sure the gcc compiler you are using is the correct one (3.4.3 for OpenFoam1.1)
mattijs is offline   Reply With Quote
Old   May 2, 2005, 09:45
Default I'm running (according to dmes
Gavin Tabor
grtabor is on a distinguished road
I'm running (according to dmesg) on twin Intel Xeon 3.06GHz processors under RH8. No problems AFAIK.
Gavin
grtabor is offline   Reply With Quote
Does anyone work with curl in OpenFoam evgenii OpenFOAM Running, Solving & CFD 10 January 23, 2020 05:14
Work anybody with OpenFOAM in Berlin Germany ingolf OpenFOAM Running, Solving & CFD 0 September 21, 2005 09:27
cluster Xeon Ivan CFX 8 December 7, 2004 17:10
PIV Xeon vs. Athlon MP Clovis R. Maliska Jr. Main CFD Forum 1 March 6, 2002 15:49
P3 or P3 Xeon Scott W FLUENT 8 April 14, 2001 07:08
