Installation on a cluster running a queueing system PBS
Old   June 9, 2005, 19:51
Default When I log on the system, the
diablo80@web.de
sampaio is on a distinguished road
When I log on the system, the environment variables are all correct.
When I issue a which blockMesh, for instance, it returns the correct directory.
But when I submit through the queueing system, I got "command not found" msgs, and when I include "which blockMesh" in the script to be submitted, it returns nothing (no command).
As I am not experienced in clusters (this one is a beowulf) with queues, I am wondering if this is some common and easy problem and if anyone can help me...
Note: I am not allowed to log onto the nodes and run an application from there...
Thanks a lot,
luiz
sampaio is offline   Reply With Quote
Old   June 10, 2005, 04:07
Default why not source your .cshrc the
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
why not source your .cshrc the first thing you do inthe script
niklas is offline   Reply With Quote
Old   June 10, 2005, 15:50
Default I did it. Now, the variables
diablo80@web.de
I did it.
Now, the variables are correctly set, but the output still contains errors.
Here is my script:
echo Running on host `hostname`
echo Time is `date`
echo Directory is `pwd`
echo This job runs on the following processors:
source /home/server/luizebs/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/cshrc
echo `which blockMesh`
echo `which mpiexec`
blockMesh . GL3 > logblock &
The logblock file is completely empty...
in my script.eXXXXX log file I got:
[luizebs@redhot oodles]$ cat script.e45957
$: Command not found.
while in the script.oXXXXX log I got (should I worry about this warning message?):
[luizebs@redhot oodles]$ cat script.o45959
Warning: no access to tty (Bad file descriptor).
Thus no job control in this shell.
Running on host n46
Time is Fri Jun 10 10:39:17 PDT 2005
Directory is /home/server/luizebs
/home/server/luizebs/OpenFOAM/OpenFOAM-1.1/applications/bin/linuxOpt/blockMesh
/home/server/luizebs/OpenFOAM/OpenFOAM-1.1/src/lam-7.1.1/platforms/linuxOpt/bin/ mpiexec
[1] 25710
Running PBS epilogue script
Killing processes of user luizebs on the batch nodes
Doing node n46
Done.
Old   June 11, 2005, 12:11
Default ok, so you are standing in $HO
niklas's Avatar
Niklas Nordin
ok, so you are standing in $HOME according to pwd.
is your GL3 directory located in $HOME?
also i would add #!/bin/tcsh (or csh or bash...)
on the first line of the script (might help)
N
Old   June 13, 2005, 22:32
Default Sorry that was an old log. Eve
diablo80@web.de
Sorry that was an old log. Even when I was (correctly) on the .../tutorials/oodles dir, the message was the same. (And I did have #!/bin/bashrc in my script).
I tried to execute blockMesh from the node (avoiding qsub) and it issued these msgs:
[luizebs@n1 oodles]$ blockMesh . GL3
blockMesh: /lib/i686/libc.so.6: version `GLIBC_2.3' not found (required by /home/server/luizebs/OpenFOAM/linux/gcc-3.4.3/lib/libstdc++.so.6)
blockMesh: /lib/i686/libc.so.6: version `GLIBC_2.3.2' not found (required by /home/server/luizebs/OpenFOAM/OpenFOAM-1.1/src/lam-7.1.1/platforms/linuxOpt/lib/ libmpi.so.0)
blockMesh: /lib/i686/libc.so.6: version `GLIBC_2.3' not found (required by /home/server/luizebs/OpenFOAM/OpenFOAM-1.1/src/lam-7.1.1/platforms/linuxOpt/lib/ liblam.so.0)
blockMesh: /lib/i686/libpthread.so.0: version `GLIBC_2.3.2' not found (required by /home/server/luizebs/OpenFOAM/OpenFOAM-1.1/src/lam-7.1.1/platforms/linuxOpt/lib/ liblam.so.0)
[luizebs@n1 oodles]$ which gcc
~/OpenFOAM/linux/gcc-3.4.3/bin/gcc
Do you have any clue? Apparently gcc is pointing to the correct location.
Thanks,
Luiz
Old   June 14, 2005, 05:56
Default your linux version on the clus
niklas's Avatar
Niklas Nordin
your linux version on the cluster is too old, which version is it?
You need to recompile all of the source on the cluster. Submit the Allwmake script.
N
Old   June 14, 2005, 13:48
Default 2.4.20-30.7 When I recompil
diablo80@web.de
2.4.20-30.7
When I recompile (with ./Allwmake from $HOME/OpenFOAM/OpenFOAM-1.1 dir) it still complains about GLIBC_2.3
Here is the output:
SOURCE_DIR=.
SOURCE=foamDebugSwitches.C ; g++ -m32 -Dlinux -Wall -W -Wno-unused-parameter -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -I/home/server/luizebs/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxOpt/foamDebugSwitches.o
g++: /lib/i686/libc.so.6: version `GLIBC_2.3' not found (required by g++)
make: *** [Make/linuxOpt/foamDebugSwitches.o] Error 1
+ wmake foamInfoExec
Making dependency list for source file foamInfoExec.C
SOURCE_DIR=.
SOURCE=foamInfoExec.C ; g++ -m32 -Dlinux -Wall -W -Wno-unused-parameter -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -I/home/server/luizebs/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -pthread -c $SOURCE -o Make/linuxOpt/foamInfoExec.o
make: *** [Make/linuxOpt/foamInfoExec.o] Error 1
[luizebs@n22 OpenFOAM-1.1]$
Thanks again,
luiz
Old   June 14, 2005, 15:40
Default Sounds like you first need to
Mattijs Janssens
mattijs is on a distinguished road
Sounds like you first need to compile gcc for your os version.
Information on how to do that should be somewhere on the site.
(we do:
./configure --prefix=/usr/tmp/gcc-3.4.3 --enable-languages=c,c++ --enable-shared --enable-__cxa_atexit --disable-checking --with-system-zlib)
mattijs is offline   Reply With Quote
Old   June 15, 2005, 04:58
Default Yes and you will need to recom
niklas's Avatar
Niklas Nordin
Yes and you will need to recompile everything else too.
But now your in a tight spot, how will you do the post-processing?
I think you need to have two binary-versions on for the old cluster and one for the new workstation.
N
Old   June 17, 2005, 02:11
Default I tried to compile gcc and Foa
diablo80@web.de
I tried to compile gcc and Foam (with Allwmake), but it still complains about GLIBC-2.3.2.
Apparently gcc was installed with no problem, but ./Allwmake outputs a lot of messages like this:
/home/server/luizebs/OpenFOAM/OpenFOAM-1.1/src/lam-7.1.1/platforms/linuxOpt/lib/ liblam.so.0: undefined reference to `pthread_cond_signal@GLIBC_2.3.2'
Should I install this library separetely? (I thought it should come with gcc-3.4.3)
Where should it be?
What I have in /lib dir is:
$ ls /lib/libc*
/lib/libc-2.2.5.so /lib/libcap.so.1.10 /lib/libcrypt-2.2.5.so /lib/libcrypt.so.1
/lib/libcap.so /lib/libcom_err.so.2 /lib/libcrypto.so.0.9.6b /lib/libc.so.6
/lib/libcap.so.1 /lib/libcom_err.so.2.0 /lib/libcrypto.so.2
Thanks a lot again,
Luiz
Old   June 17, 2005, 20:12
Default Also, which version of GLIBC i
  #11
diablo80@web.de
Also, which version of GLIBC is required by Foam?
I googled about installing GLIBC and got a little scared... So, firstly I would like to be sure it is really the case, rather than anything else that i am missing...
Thanks,
luiz
Old   June 18, 2005, 12:04
Default It looks to me like you have s
  #12
niklas's Avatar
Niklas Nordin
It looks to me like you have some old libraries hanging around.
Did you remove the OpenFoam installation and install just the sources or did you just try to recompile with the old binaries installed?
The glibc-version is not something foam specific, but machine specific.
What it means is that you have compiled your library on a certain system and then running it on an other system where these libraries are missing/different.
N
Old   June 20, 2005, 18:16
Default Hi Niklas, I did not remove t
  #13
diablo80@web.de
Hi Niklas,
I did not remove the OpenFoam installation. I just ran ./Allwmake from top dir.
What exactly should I do?
(which directories should I leave and which ones should I remove before running ./Allwmake?)
If you can provide me more details, since I am not linux expert, I will be very very gratefull...
Thanks a lot again,
luiz
What is the best cluster file system to go with OF sampaio OpenFOAM Installation 4 March 17, 2011 05:10
Installation on IBM machine running AIX gellert OpenFOAM Installation 2 October 14, 2005 05:26
Running FineTurbo on a Linux Cluster Philipp Höfliger Fidelity CFD 3 May 6, 2004 09:47
Who is running Phoenics with a cluster? Maria Morabito Phoenics 2 January 4, 2004 06:07
Running CFX on a cluster jvk CFX 9 September 19, 2002 23:22
