September 3, 2005, 05:20 |
I am using Fedora core 3 on my
I am using Fedora core 3 on my P4.
I am installing openfoam-1.1 and followed everything that is given in documnetation and the read me file. But finally while running foamInstallationTest, i get the following result. [kanishka@localhost bin]$ ./foamInstallationTest Executing ./foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: localhost.localdomain OS: Linux version 2.6.9-1.667 User: kanishka User_config: /home/kanishka/.bashrc Foam_config: /home/kanishka/.OpenFOAM-1.1/bashrc sourced correctly. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/kanishka/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 3.4.2 WARNING: Conflicting installations: foam settings: /bin/gcc current path : /usr/bin/gcc CRITICAL ERROR java previous libgcj) WARNING: Conflicting installations: foam settings: /bin/java current path : /usr/bin/java gzip 1.3.3 /usr/bin/gzip tar 1.3.3 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- ...localhost.localdomain Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. ...can anyone tell me how to set environment variables and what exactly is the problem. |
September 4, 2005, 11:15 |
Under $HOME/OpenFOAM, d
Pei-Ying Hsieh
Rep Power: 18 |
Under $HOME/OpenFOAM, did you create a folder called linux, placed gcc, java, paraview tgz files under linux, and then unpack the tgz files there? The very first time I installed OpenFOAM, I put all the downloaded files under OpenFOAM and got similar errors. pei |
Setting Environment Variables | PETER P. | CFX | 1 | August 3, 2008 19:33 |
MPI Environment Variables | braennstroem | OpenFOAM Installation | 8 | February 8, 2008 10:19 |
What is the future CFD environment? | TP | Main CFD Forum | 3 | January 23, 2007 11:19 |
environment variables version 3.2 | F.K. | Siemens | 15 | June 28, 2004 13:41 |
home environment | john | FLUENT | 2 | May 24, 2004 06:55 |
