December 28, 2005, 05:08 |
I want to install OpenFOAM-1.2
G Gruber
Rep Power: 17 |
I want to install OpenFOAM-1.2 on my Ubuntu 5.10 -Breezy Batcher-
So i download the Files: OpenFOAM-1.2.General.gtgz OpenFOAM-1.2.linuxGcc4Opt.gtgz and safe it in my home Directory. I unpack it and they are stored in the OpenFOAM-1.2 Directory. I modified my .bashrc-File and sourced it as described. But when i am runnig the InstallationTest i always get the Error that the "env variable not set": ggruber@nx6110:~/OpenFOAM/OpenFOAM-1.2/bin$ ./foamInstallationTest Executing ./foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: nx6110 OS: Linux version 2.6.12-9-386 User: ggruber User_config: /home/ggruber/.bashrc FATAL ERROR: /home/ggruber/.OpenFOAM-1.1/bashrc does not appear to be sourced from: /home/ggruber/.bashrc You need the following at the end of your /home/ggruber/.bashrc file: . /home/ggruber/OpenFOAM/OpenFOAM-1.1/.OpenFOAM-1.1/bashrc or equivalent depending on the location of the OpenFOAM installation. FATAL ERROR Foam install directory not set. Set correct path to installation 'WM_PROJECT_INST_DIR' in /home/ggruber/.foam2.3/bashrc ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR --------- env variable not set --------- yes $WM_PROJECT_USER_DIR --------- env variable not set --------- no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR --------- env variable not set --------- yes $FOAM_USER_APPBIN --------- env variable not set --------- no $FOAM_APPBIN --------- env variable not set --------- yes $WM_DIR --------- env variable not set --------- yes $FOAMX_PATH --------- env variable not set --------- yes $CEI_HOME --------- env variable not set --------- no $JAVA_PATH --------- env variable not set --------- no $MICO_ARCH_PATH --------- env variable not set --------- yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN --------- env variable not set --------- yes $FOAM_USER_LIBBIN --------- env variable not set --------- no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc *** not installed *** CRITICAL ERROR java 1.4.2 libgcj) WARNING: Conflicting installations: foam settings: /bin/java current path : /usr/bin/java gzip 1.3.5 /bin/gzip tar 1.3.5 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_nx6110 Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Unsuccessful_connection_refused* yes FATAL ERROR: No remote shell available. Foam1.1 enviroment requires either ssh and/or rsh. Contact your system administrator. ------------------------------------------------------------------------------- The system test has evoked 2 fatal error(s). The foam installation contains 2 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. Who can help ? |
December 29, 2005, 09:39 |
I set some variables manual in
G Gruber
Rep Power: 17 |
I set some variables manual in a terminal.
That works. example: export WM_PROJECT=OpenFOAM export WM_PROJECT_VERSION=1.2 export WM_PROJECT_LANGUAGE=c++ export WM_PROJECT_INST_DIR=$HOME/$WM_PROJECT exportWM_PROJECT_DIR=$WM_PROJECT_INST_DIR/$WM_PROJECT-$WM_PROJECT_VERSION export WM_PROJECT_USER_DIR=$HOME/$WM_PROJECT/$LOGNAME-$WM_PROJECT_VERSION . . Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/ggruber/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/ggruber/OpenFOAM/ggruber-1.2 yes no $FOAM_JOB_DIR --------- env variable not set --------- yes ------------------------------------------------------------------------------- . . |
December 29, 2005, 10:37 |
Now i add "echo bashrc sourced
G Gruber
Rep Power: 17 |
Now i add "echo bashrc sourced" at the end of the $HOME/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/bashrc File.
Every time i source my $HOME/.bashrc File or start a new Terminal i get the massage "bashrc sourced". But why are the variables not set ??? |
December 29, 2005, 11:27 |
Not sure - are you doung somet
Hrvoje Jasak
Rep Power: 33 |
Not sure - are you doung something special with your shells? Try opening a new tcsh and doing
source ~/.OpenFOAM-1.2/cshrc by hand. Then check that the variables are there. An equivalent for bash should work too; if I were you, I'd try the "other" shell, i.e. the one I'm not using all the time. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
December 29, 2005, 11:29 |
Yes, i've got it !
To add "$H
G Gruber
Rep Power: 17 |
Yes, i've got it !
To add "$HOME/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/bashrc" in the "$HOME/.bashrc" file is not enouth. You have to add "source $HOME/OpenFOAM/OpenFOAM-1.2/.OpenFOAM-1.2/bashrc" |
December 30, 2005, 05:27 |
Indeed. Read a bit (man bash)
Mattijs Janssens
Rep Power: 26 |
Indeed. Read a bit (man bash) about the difference between executing a shell script from another shell script or sourcing ('source', '.') it.
RP_Set_Real("variable-name", variable name) | bohis | FLUENT | 1 | March 9, 2009 08:44 |
My own variable | Maurice | CFX | 1 | June 12, 2007 04:48 |
a udf for new variable | Asghari | FLUENT | 2 | July 14, 2006 02:15 |
inner variable | Sas | Main CFD Forum | 0 | February 22, 2006 00:55 |
variable | dahuilang | Phoenics | 1 | September 24, 2001 04:22 |
