February 2, 2006, 11:59 |
hi all,
i have some problems
rafal zietara
Rep Power: 17 |
hi all,
i have some problems with instalation of OpenFOAM on unicomputer (Red Hat 8.0, pentium 4, user rights). If anyone have any idea how to bypass this problem, please help. Here is the output from Installation Test ----------------------------------------------------------- celw8:~ > foamInstallationTest Executing /home/expert/OpenFOAM/OpenFOAM-1.2/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: celw8.ce.umist.ac.uk OS: Linux version 2.4.18-14 User: expert User_config: /home/expert/.bashrc Foam_config: /home/expert/.OpenFOAM-1.2/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/expert/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/expert/OpenFOAM/expert-1.2 yes no $FOAM_JOB_DIR /home/expert/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/expert/OpenFOAM/OpenFOAM-1.2 yes yes yes $FOAM_USER_APPBIN ...rt-1.2/applications/bin/linuxGcc4Opt yes yes no $FOAM_APPBIN ...AM-1.2/applications/bin/linuxGcc4Opt yes yes yes $WM_DIR /home/expert/OpenFOAM/OpenFOAM-1.2/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH .../expert/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH ...c/mico-2.3.11/platforms/linuxGcc4Opt yes yes yes $LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...enFOAM/OpenFOAM-1.2/lib/linuxGcc4Opt yes yes yes $FOAM_USER_LIBBIN ...OpenFOAM/expert-1.2/lib/linuxGcc4Opt yes yes no $LAM_ARCH_PATH ...src/lam-7.1.1/platforms/linuxGcc4Opt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.0.1 /home/expert/OpenFOAM/linux/gcc-4.0.1/bin/gcc java 1.4.2_05 /home/expert/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.3 /usr/bin/gzip tar 1.3.3 /bin/tar icoFoam ...OAM/OpenFOAM-1.2/applications/bin/linuxGcc4Opt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- ..._celw8.ce.umist.ac.uk Successful yes Pinging_localHost Networking_cannot_reach_localHost yes WARNING: CRITICAL ERROR Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. celw8:~ > |
February 2, 2006, 12:24 |
does your tcp/ip stack working
stefan
Rep Power: 17 |
does your tcp/ip stack working? Are you able to ping your localhost (172.0.0.1). You get this error because the installation script is not able to ping you localhost. Are you in the right runlevel (3 or 5)?
Take care that you network setup is working and go ahead. |
February 2, 2006, 12:38 |
Thats true I cannot ping mysel
rafal zietara
Rep Power: 17 |
Thats true I cannot ping myself (i dont know why but i will sort this out with admin)
thanks |
February 2, 2006, 12:43 |
There are only two possibiliti
stefan
Rep Power: 17 |
There are only two possibilities:
- your tcp/ip stack is buggy - your tcp/ip stack is not loaded > check the loaded kernel modules > what is the output of ifconfig I am sure your Admin will fix this problem cheers Stefan |
OF15dev installation error | velan | OpenFOAM Installation | 11 | February 13, 2009 10:23 |
Help Error Installation of openfoam15dev | loneboard | OpenFOAM Installation | 4 | February 4, 2009 10:24 |
Installation error | sukratu | OpenFOAM Installation | 6 | September 16, 2007 23:46 |
Error after installation.. | Nari | Siemens | 5 | June 28, 2007 15:02 |
Fluent 6.2.16 installation with Error EOF | tuks | FLUENT | 3 | July 13, 2005 14:20 |
